Description
I am using TensorRT on the NVIDIA Jetson Xavier NX to run multiple models in multiple processes (I am using ROS).
Each time I start a process with a new model, that process allocates around 1.2GB over the CPU memory (I know, it is shared). I read from the forum that this load may be related to the cuBLAS/cuDNN/TensorRT libraries (Very large CPU RAM Usage in TensorRT).
Is there a way to load these libraries once for all the models?
Some details about memory usage:
0 Models CPU: 1.2GB GPU: 27.9MB
1 Models CPU: 2.3GB GPU: 357.3MB
2 Models CPU: 3.8GB GPU: 868.6MB
3 Models CPU: 5.0GB GPU: 1.2 GB
Thank you in advance!
Environment
Device: NVIDIA Jetson Xavier NX
Jetpack 4.6 [L4T 32.6.1]
Docker image: l4t-ml:r32.6.1-py3
TensorRT Version: (From Python) ‘8.0.1.6’
Relevant Files
To load the model I am using the TRTLite class.
I use import pycuda.autoinit where I create the TRTLite instance.
# Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
# Licensed under the Apache License, Version 2.0 (the "License");
# you may not use this file except in compliance with the License.
# You may obtain a copy of the License at
# http://www.apache.org/licenses/LICENSE-2.0
# Unless required by applicable law or agreed to in writing, software
# distributed under the License is distributed on an "AS IS" BASIS,
# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
# See the License for the specific language governing permissions and
# limitations under the License.
from functools import reduce
import tensorrt
import pycuda.driver as cuda
import numpy as np
class TrtLite:
def __init__(self, build_engine_proc = None, build_engine_params = None, engine_file_path = None):
logger = tensorrt.Logger(tensorrt.Logger.INFO)
if engine_file_path is None:
with tensorrt.Builder(logger) as builder:
if build_engine_params is not None:
self.engine = build_engine_proc(builder, *build_engine_params)
else:
self.engine = build_engine_proc(builder)
else:
with open(engine_file_path, 'rb') as f, tensorrt.Runtime(logger) as runtime:
self.engine = runtime.deserialize_cuda_engine(f.read())
self.context = self.engine.create_execution_context()
def __del__(self):
self.engine = None
self.context = None
def save_to_file(self, engine_file_path):
with open(engine_file_path, 'wb') as f:
f.write(self.engine.serialize())
def get_io_info(self, input_desc):
def to_numpy_dtype(trt_dtype):
tb = {
tensorrt.DataType.BOOL: np.dtype('bool'),
tensorrt.DataType.FLOAT: np.dtype('float32'),
tensorrt.DataType.HALF: np.dtype('float16'),
tensorrt.DataType.INT32: np.dtype('int32'),
tensorrt.DataType.INT8: np.dtype('int8'),
return tb[trt_dtype]
if isinstance(input_desc, dict):
if self.engine.has_implicit_batch_dimension:
print('Engine was built with static-shaped input so you should provide batch_size instead of i2shape')
return
i2shape = input_desc
for i, shape in i2shape.items():
self.context.set_binding_shape(i, shape)
return [(self.engine.get_binding_name(i), self.engine.binding_is_input(i),
self.context.get_binding_shape(i), to_numpy_dtype(self.engine.get_binding_dtype(i))) for i in range(self.engine.num_bindings)]
batch_size = input_desc
(batch_size,) + tuple(self.context.get_binding_shape(i)), to_numpy_dtype(self.engine.get_binding_dtype(i))) for i in range(self.engine.num_bindings)]
def allocate_io_buffers(self, input_desc, on_gpu):
io_info = self.get_io_info(input_desc)
if io_info is None:
return
if on_gpu:
return [cuda.mem_alloc(reduce(lambda x, y: x * y, i[2]) * i[3].itemsize) for i in io_info]
else:
return [np.zeros(i[2], i[3]) for i in io_info]
def execute(self, bindings, input_desc, stream_handle = 0, input_consumed = None):
self.context.execute_async_v2(bindings, stream_handle, input_consumed)
return
self.context.execute_async(batch_size, bindings, stream_handle, input_consumed)
def print_info(self):
print("Batch dimension is", "implicit" if self.engine.has_implicit_batch_dimension else "explicit")
for i in range(self.engine.num_bindings):
print("input" if self.engine.binding_is_input(i) else "output",
self.engine.get_binding_name(i), self.engine.get_binding_dtype(i),
self.engine.get_binding_shape(i),
-1 if -1 in self.engine.get_binding_shape(i) else reduce(
lambda x, y: x * y, self.engine.get_binding_shape(i)) * self.engine.get_binding_dtype(i).itemsize)
