Hello everyone,
I’m new in using TensorRT Python API.
Could you help me to migrate simple angle prediction model from Keras framework to TensorRT via ONNX?
Environment
TensorRT Version: 7.2.3.4
GPU Type: GeForce GTX 1060 6 GB
Nvidia Driver Version: 440.33.01
CUDA Version: 10.2
CUDNN Version: 7.1
Operating System + Version: Ubuntu 18.04
Python Version (if applicable): 3.6
TensorFlow Version (if applicable): 2.3.1
Input data:
- Trained ONNX model which can predict parked car rotation angle. INT64 weights
- .png file with 3(RGB) channels, size: 64*64. Image with parked car.
Minimal target: predict car rotation angle
To be more simple I’ve used Nvidia example and reworked some stages:
Workflow:
Python image preprocessing:
shapes = np.array([i.shape[:-1] for i in x_batch]) / 300
x_shapes = np.append(shapes, (shapes.T[0] / shapes.T[1])[:, None], axis=1)
x_imgs = np.array([cv2.resize(i, (64, 64)) for i in x_batch])
x_batch - list of croped images. -
Now I have this error trace:
[TensorRT] ERROR: engine.cpp (780) - Cuda Error in reportTimes: 700 (an illegal memory access was encountered)
[TensorRT] ERROR: INTERNAL_ERROR: std::exception
[TensorRT] ERROR: engine.cpp (1036) - Cuda Error in executeInternal: 700 (an illegal memory access was encountered)
[TensorRT] ERROR: FAILED_EXECUTION: std::exception
[TensorRT] ERROR: engine.cpp (169) - Cuda Error in ~ExecutionContext: 700 (an illegal memory access was encountered)
[TensorRT] ERROR: Parameter check failed at: safeContext.cpp::terminateCommonContext::216, condition: cudnnDestroy(context.cudnn) failure.
[TensorRT] ERROR: Parameter check failed at: safeContext.cpp::terminateCommonContext::221, condition: cudaEventDestroy(context.start) failure.
[TensorRT] ERROR: Parameter check failed at: safeContext.cpp::terminateCommonContext::226, condition: cudaEventDestroy(context.stop) failure.
[TensorRT] ERROR: …/rtSafe/safeRuntime.cpp (32) - Cuda Error in free: 700 (an illegal memory access was encountered)
terminate called after throwing an instance of ‘nvinfer1::CudaError’
what(): std::exception
Aborted (core dumped) -
Allocate buffers:
h_input_1 = cuda.pagelocked_empty(batch_size * trt.volume(engine.get_binding_shape(0)), dtype=trt.nptype(data_type))
h_output = cuda.pagelocked_empty(batch_size * trt.volume(engine.get_binding_shape(1)), dtype=trt.nptype(data_type))
d_input_1 = cuda.mem_alloc(h_input_1.nbytes)
d_output = cuda.mem_alloc(h_output.nbytes)
stream = cuda.Stream() -
ONNX created with trtexec
trtexec --explicitBatch --onnx=apm.onnx --minShapes=input:2x2 --optShapes=input:1x3x64x64 --maxShapes=input:1x3x64x64 --shapes=input:1x3x64x64 --saveEngine=apm.plan
