I was trying to implement a VGG16 model on TX1 using TensorRT1.0. With the help of built-in tutorial of GIE, I modified it for my own use. It works well for DataType::kFLOAT, but when I tried to use DataType::kHALF to speedup the process, it failed to pass the assertion, which seems to be some problems from dimension match.
Error message below:
caffe_parser: cudnnReformatLayer.cpp:31: virtual void nvinfer1::cudnn::ReformatLayer::execute(const nvinfer1::cudnn::CommonContext&): Assertion `in.getDimensions() == out.getDimensions()’ failed.
Can someone help?
Leo
Interesting findings!
I designed a smaller model which is actually a part of my original model, I found that it would work if we only have one output for this model when using Half2. Is this a bug?
Regards.
Leo
Looks like your model has some not-supported format in fp16 mode.
Could you paste your prototxt file for us debugging?
input: “data”
input_shape {
dim: 1
dim: 3
dim: 321
dim: 321
layer {
bottom: “data”
top: “conv1_1”
type: “Convolution”
convolution_param {
num_output: 21
pad: 1
kernel_size: 3
layer {
bottom: “conv1_1”
top: “conv1_1”
type: “ReLU”
layer {
bottom: “conv1_1”
top: “conv1_2”
type: “Convolution”
convolution_param {
num_output: 26
pad: 1
kernel_size: 3
layer {
bottom: “conv1_2”
top: “conv1_2”
type: “ReLU”
layer {
bottom: “conv1_2”
top: “pool1”
type: “Pooling”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: “pool1”
top: “conv2_1”
type: “Convolution”
convolution_param {
num_output: 22
pad: 1
kernel_size: 3
layer {
bottom: “conv2_1”
top: “conv2_1”
type: “ReLU”
layer {
bottom: “conv2_1”
top: “conv2_2”
type: “Convolution”
convolution_param {
num_output: 28
pad: 1
kernel_size: 3
layer {
bottom: “conv2_2”
top: “conv2_2”
type: “ReLU”
layer {
bottom: “conv2_2”
top: “pool2”
type: “Pooling”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: “pool2”
top: “conv3_1”
type: “Convolution”
convolution_param {
num_output: 24
pad: 1
kernel_size: 3
layer {
bottom: “conv3_1”
top: “conv3_1”
type: “ReLU”
layer {
bottom: “conv3_1”
top: “conv3_2”
type: “Convolution”
convolution_param {
num_output: 17
pad: 1
kernel_size: 3
layer {
bottom: “conv3_2”
top: “conv3_2”
type: “ReLU”
layer {
bottom: “conv3_2”
top: “conv3_3”
type: “Convolution”
convolution_param {
num_output: 13
pad: 1
kernel_size: 3
layer {
bottom: “conv3_3”
top: “conv3_3”
type: “ReLU”
layer {
bottom: “conv3_3”
top: “pool3”
type: “Pooling”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: “pool3”
top: “Fea_P3”
type: “Convolution”
convolution_param {
num_output: 18
pad: 1
kernel_size: 3
layer {
bottom: “Fea_P3”
top: “Fea_P3”
type: “ReLU”
layer {
bottom: “pool3”
top: “conv4_1”
type: “Convolution”
convolution_param {
num_output: 33
pad: 1
kernel_size: 3
layer {
bottom: “conv4_1”
top: “conv4_1”
type: “ReLU”
layer {
bottom: “conv4_1”
top: “conv4_2”
type: “Convolution”
convolution_param {
num_output: 20
pad: 1
kernel_size: 3
layer {
bottom: “conv4_2”
top: “conv4_2”
type: “ReLU”
layer {
bottom: “conv4_2”
top: “conv4_3”
type: “Convolution”
convolution_param {
num_output: 18
pad: 1
kernel_size: 3
layer {
bottom: “conv4_3”
top: “conv4_3”
type: “ReLU”
layer {
bottom: “conv4_3”
top: “pool4”
type: “Pooling”
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
bottom: “pool4”
top: “Fea_P4”
type: “Convolution”
convolution_param {
num_output: 28
pad: 1
kernel_size: 3
layer {
bottom: “Fea_P4”
top: “Fea_P4”
type: “ReLU”
Here I mark both Fea_P4 and Fea_P3 as output.
Sorry for keeping you waiting.
This issue is fixed in our next release.
Please pay attention to our announcement and update.
