Hi.
I exported a .tlt model and generated trt.engine on jetson nano. I get following error for inference:
[TensorRT] ERROR: 2: [pluginV2DynamicExtRunner.cpp::execute::115] Error Code 2: Internal Error (Assertion status == kSTATUS_SUCCESS failed.)
Hi.
Could you share more information about your use case?
Which model do you use? And please share the executed command with us as well.
Hi.
I use the yolov4 model and with this command, I generate the trt.engine:
./tao-converter -k $KEY -p Input,1x3x416x416,8x3x416x416,16x3x416x416 -d 3,416,416 -o BatchedNMS -i nchw -m 1 -c /home/jetsonuser/jp4.6/yolov4_export/cal.bin -e /home/jetsonuser/jp4.6/trt.engine -b 2 -t int8 -w 1073741824 /home/jetsonuser/jp4.6/yolov4_export/final_model.etlt
Inference code:
import tensorrt as trt
import numpy as np
from PIL import Image
import os
import cv2
import pycuda.driver as cuda
import pycuda.autoinit
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
class TrtEngine:
#Initializes TensorRT objects needed for model inference.
def __init__(self,engine_path, input_height, input_width, input_channels, max_batch_size, dtype):
self.engine_path = engine_path
self.input_height = input_height
self.input_width = input_width
self.input_channels = input_channels
self.dtype = dtype
self.logger = trt.Logger(trt.Logger.VERBOSE)
self.runtime = trt.Runtime(self.logger)
self.engine = self.load_engine(self.runtime, self.engine_path)
self.max_batch_size = max_batch_size
self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
self.context = self.engine.create_execution_context()
# Allocate memory for multiple usage [e.g. multiple batch inference]
# self.context.set_binding_shape(0, (self.max_batch_size , 3, self.input_height, self.input_width))
input_volume = trt.volume((self.input_channels, self.input_width, self.input_height))
self.numpy_array = np.zeros((self.engine.max_batch_size, input_volume))
@staticmethod
def load_engine(trt_runtime, engine_path):
trt.init_libnvinfer_plugins(None, "")
with open(engine_path, 'rb') as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
def allocate_buffers(self):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
for binding in self.engine:
size = trt.volume(self.engine.get_binding_shape(binding)) * -1
host_mem = cuda.pagelocked_empty(size, self.dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if self.engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def infer_batch(self, image_paths):
"""Infers model on batch of same sized images resized to fit the model.
Args:
image_paths (str): paths to images, that will be packed into batch
and fed into model
# Verify if the supplied batch size is not too big
max_batch_size = self.engine.max_batch_size
actual_batch_size = len(image_paths)
if actual_batch_size > max_batch_size:
raise ValueError(
"image_paths list bigger ({}) than engine max batch size ({})".format(actual_batch_size, max_batch_size))
# Load all images to CPU...
imgs = self._load_imgs(image_paths)
# ...copy them into appropriate place into memory...
# (self.inputs was returned earlier by allocate_buffers())
# print("check for more than 1 image")
# print(len(self.inputs))
np.copyto(self.inputs[0].host, imgs.ravel().astype(self.dtype))
# ...fetch model outputs...
input_shape = (1,3,self.img_height,self.img_width)
self.context.set_binding_shape(0, input_shape)
# [detection_out, keep_count_out] = do_inference(
# context=self.context, bindings=self.bindings, inputs=self.inputs,
# outputs=self.outputs, stream=self.stream)
# # ...and return results.
# return detection_out, keep_count_out
outputs = do_inference(
return outputs
def _load_image_into_numpy_array(self, image):
# (im_width, im_height) = image.size
# return np.array(image).reshape(
# (im_height, im_width, self.input_channels)
# ).astype(np.uint8)
return np.array(image, dtype=self.dtype, order='C')
def _load_imgs(self, image_paths):
# batch_size = self.engine.max_batch_size
for idx, image_path in enumerate(image_paths):
img_np = self._load_img(image_path)
self.numpy_array[idx] = img_np
return self.numpy_array
def _load_img(self, image_path):
image = Image.open(image_path)
r, g, b = image.split()
image = Image.merge('RGB', (b, g, r))
model_input_width = self.input_width
model_input_height = self.input_width
# Note: Bilinear interpolation used by Pillow is a little bit
# different than the one used by Tensorflow, so if network receives
# an image that is not 300x300, the network output may differ
# from the one output by Tensorflow
image_resized = image.resize(
size=(model_input_width, model_input_height),
resample=Image.BICUBIC
img_np = self._load_image_into_numpy_array(image_resized)
# HWC -> CHW
img_np = img_np.transpose((2, 0, 1))
# Normalize to [-1.0, 1.0] interval (expected by model)
img_np = img_np / 255.0
# img_np = (2.0 / 255.0) * img_np - 1.0
img_np = img_np.ravel()
return img_np
# This function is generalized for multiple inputs/outputs.
# inputs and outputs are expected to be lists of HostDeviceMem objects.
def do_inference(context, bindings, inputs, outputs, stream, batch_size=1):
# Transfer input data to the GPU.
[cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
# Run inference.
context.execute_async(batch_size=batch_size, bindings=bindings, stream_handle=stream.handle)
# Transfer predictions back from the GPU.
[cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
# Synchronize the stream
stream.synchronize()
# Return only the host outputs.
return [out.host for out in outputs]
Could you share the TLT model with us as well?
File size is large and can not be uploaded here. This is the link to download the model file:
Sorry, could you please help me?
Sorry for the delay.
We are checking this internally.
Will share more information with you later.
Hi
Could it be because the board is legacy and I have to use an older jetpack version? I used jetpack 4.6
I am having the similar error when I run the inference on the engine file.
The engine file is for object detection model ‘ssd_mobilenet_v2_fpnlite_320x320_coco17_tpu-8’.
Error:
Versions which I use:
TensorRT version: 8.0.1.6
onnx version: 1.10.2
Jetpack: 4.6
I have uploaded my onnx and trt engine file for the model and the script I am using for inference.
model.trt (12.4 MB)
model.onnx (10.4 MB)
inference.py (5.2 KB)
Please have a look.
Thank you.
It seems that you tried to convert an INT8 TensorRT engine on Nano.
Please note that INT8 operation is only supported on the Xavier series currently.
Could you try to convert an fp32 or fp16 to see if it works?
Hi, randhar
Since you are not using a TLT model, the cause should be different.
Would you mind filing a new topic specified for your issue?
yes I understand but I get the same error with fp32 and fp16.
Sure. Thanks
We want to reproduce this issue internally.
Could you share the $KEY value with us?
Sure,
KEY = ‘bnJ0OG1xcHVrb3N2MGU5b21nZHR2a3ZrMXI6NTkzYjE3YjAtNzllNy00MTk3LTkyNmUtNmJhM2QxNTAyOGEw’
We try the tao-converter with the key shared above but meet some error.
It seem that the key is incorrect. Could you double-check it?
$ ./tao-converter -k $KEY -p Input,1x3x416x416,8x3x416x416,16x3x416x416 -d 3,416,416 -o BatchedNMS -i nchw -m 16 -e trt.engine -w 1073741824 final_model.tlt
[INFO] [MemUsageChange] Init CUDA: CPU +353, GPU +0, now: CPU 614, GPU 17956 (MiB)
[ERROR] UffParser: Could not parse MetaGraph from /tmp/filebHgqqX
[ERROR] Failed to parse the model, please check the encoding key to make sure it's correct
[ERROR] 4: [network.cpp::validate::2411] Error Code 4: Internal Error (Network must have at least one output)
[ERROR] Unable to create engine
Hi.
I am sure the $KEY is correct. I think you should write final_model.etlt instead of final_model.tlt
This is my command:
./tao-converter -k $KEY -p Input,1x3x416x416,8x3x416x416,16x3x416x416 -d 3,416,416 -o BatchedNMS -i nchw -m 1 -e /home/jetsonuser/jp4.6/trt.engine -t fp32 -w 1073741824 /home/jetsonuser/jp4.6/yolov4_export/final_model.etlt
final_model.tlt is the file name downloaded from the previous comment:
Do you use the same file?
