I am using tensorrt to deploy model on windows10, but I find the inference time is much longer than expected. Here is how I convert the model and do the inference.
First, I use pytorch to train my model, then export to onnx model, then use onnxsim to simplify it (using dynamic-axis):
inputs = ["input"]
outputs = ["output"]
dynamic_axes = {"input": {0: 'batch'}, "output": {0: 'batch'}}
torch.onnx.export(pth_model,
x,
export_onnx_file,
opset_version=12,
# do_constant_folding=False,
input_names=inputs,
output_names=outputs,
verbose=False,
dynamic_axes=dynamic_axes,
# example_outputs=torch.randn(1, 3, 192, 2048),
operator_export_type=torch.onnx.OperatorExportTypes.ONNX
onnx_model = onnx.load(export_onnx_file)
onnx.checker.check_model(onnx_model, full_check=True)
if args.print:
print(onnx.helper.printable_graph(onnx_model.graph))
# onnx_sim_model, flag = onnxsim.simplify(onnx_model)
onnx_sim_model, flag = onnxsim.simplify(onnx_model, input_shapes={"input":(batch_size, 1, 192, 2048)})
onnx.save_model(onnx_sim_model, export_onnxsim_file)
Then, I convert the simplified onnx model to tensorrt plan, by following this toturial: https://developer.nvidia.com/blog/speeding-up-deep-learning-inference-using-tensorrt/
nvinfer1::ICudaEngine* SpiderONNXModelLoader::CreateCudaEngine(string const& onnxModelPath, int batchSize)
unique_ptr<nvinfer1::IBuilder, Destroy<nvinfer1::IBuilder>> builder{ nvinfer1::createInferBuilder(g_logger_) };
const auto explicitBatch = 1U << static_cast<uint32_t>(nvinfer1::NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
unique_ptr<nvinfer1::INetworkDefinition, Destroy<nvinfer1::INetworkDefinition>> network{ builder->createNetworkV2(explicitBatch) };
unique_ptr<nvonnxparser::IParser, Destroy<nvonnxparser::IParser>> parser{ nvonnxparser::createParser(*network, g_logger_) };
unique_ptr<nvinfer1::IBuilderConfig, Destroy<nvinfer1::IBuilderConfig>> config{ builder->createBuilderConfig() };
if (!parser->parseFromFile(onnxModelPath.c_str(), static_cast<int>(ILogger::Severity::kINFO)))
qWarning() << "ERROR: could not parse input engine.";
return nullptr;
builder->setMaxBatchSize(batchSize);
config->setMaxWorkspaceSize((1 << 60));
config->setFlag(BuilderFlag::kFP16);
//builder->setFp16Mode(builder->platformHasFastFp16());
auto profile = builder->createOptimizationProfile();
profile->setDimensions(network->getInput(0)->getName(), OptProfileSelector::kMIN, Dims4{ 1, 1, 192 , 2048 });
profile->setDimensions(network->getInput(0)->getName(), OptProfileSelector::kOPT, Dims4{ 1, 1, 192 , 2048 });
profile->setDimensions(network->getInput(0)->getName(), OptProfileSelector::kMAX, Dims4{ batchSize, 1, 192 , 2048 });
config->addOptimizationProfile(profile);
return builder->buildEngineWithConfig(*network, *config);
The comparision of time consumption is between libtorch and tensorrt C++ (same input size: batch: 19, channels: 1, height: 192, width: 2048):
libtorch: around 60ms
tensorrt: around 140ms
# code for tensorrt
qint64 begin3 = QDateTime::currentMSecsSinceEpoch();
bool flag1 = context->enqueueV2(bindings, stream, nullptr);
cudaStreamSynchronize(stream);
qWarning() << QString::fromStdString("Enqueue") + " Time:" << QString::number(
QDateTime::currentMSecsSinceEpoch() - begin3);
# code for libtorch
tensor_out = pt_model.forward(tensor_inputs).toTensor();
c10::cuda::CUDAStream stream = c10::cuda::getCurrentCUDAStream();
AT_CUDA_CHECK(cudaStreamSynchronize(stream));
qWarning() << QString::fromStdString("Inference") + " Time:" << QString::number(
Environment:
pytorch/libtorch: 1.5
tnesorrt: 7.2.1
cuda: 10.2
cudnn: 8.0.4
onnx: 1.7
GPU: RTX 2060
The model files can be found here: google drive
Thanks a lot
