Using AGx orin 64gb Jetpack 6.1 [LT4 36.4.0]
Ran 1st
jetson-containers run -e HUGGINGFACE_TOKEN=HF_MY TOKEN -e FORCE_BUILD=on dustynv/tensorrt_llm:0.12-r36.4.0 /opt/TensorRT-LLM/llama.sh
Then :- which produced following errors
python3 /opt/TensorRT-LLM/examples/apps/openai_server.py
/data/models/tensorrt_llm/Llama-2-7b-chat-hf-gptq
V4L2_DEVICES: --device /dev/video0 --device /dev/video1
DISPLAY environmental variable is already set: “:1”
localuser:root being added to access control list
- docker run --runtime nvidia -it --rm --network host --shm-size=8g --volume /tmp/argus_socket:/tmp/argus_socket --volume /etc/enctune.conf:/etc/enctune.conf --volume /etc/nv_tegra_release:/etc/nv_tegra_release --volume /tmp/nv_jetson_model:/tmp/nv_jetson_model --volume /var/run/dbus:/var/run/dbus --volume /var/run/avahi-daemon/socket:/var/run/avahi-daemon/socket --volume /var/run/docker.sock:/var/run/docker.sock --volume /home/paul/jetson-containers/data:/data -v /etc/localtime:/etc/localtime:ro -v /etc/timezone:/etc/timezone:ro --device /dev/snd -e PULSE_SERVER=unix:/run/user/1000/pulse/native -v /run/user/1000/pulse:/run/user/1000/pulse --device /dev/bus/usb -e DISPLAY=:1 -v /tmp/.X11-unix/:/tmp/.X11-unix -v /tmp/.docker.xauth:/tmp/.docker.xauth -e XAUTHORITY=/tmp/.docker.xauth --device /dev/video0 --device /dev/video1 --device /dev/i2c-0 --device /dev/i2c-1 --device /dev/i2c-2 --device /dev/i2c-3 --device /dev/i2c-4 --device /dev/i2c-5 --device /dev/i2c-6 --device /dev/i2c-7 --device /dev/i2c-8 --device /dev/i2c-9 -v /run/jtop.sock:/run/jtop.sock --name jetson_container_20241123_115929 dustynv/tensorrt_llm:0.12-r36.4.0 python3 /opt/TensorRT-LLM/examples/apps/openai_server.py /data/models/tensorrt_llm/Llama-2-7b-chat-hf-gptq
/usr/local/lib/python3.10/dist-packages/transformers/utils/hub.py:128: FutureWarning: UsingTRANSFORMERS_CACHE
is deprecated and will be removed in v5 of Transformers. UseHF_HOME
instead.
warnings.warn(
[TensorRT-LLM] TensorRT-LLM version: 0.12.0
Loading Model: [1/2] Loading TRT checkpoints to memory
Time: 0.169s
Loading Model: [2/2] Build TRT-LLM engine
Time: 282.760s
Loading model done.
Total latency: 282.929s
[TensorRT-LLM][INFO] Engine version 0.12.0 found in the config file, assuming engine(s) built by new builder API.
[TensorRT-LLM][INFO] Rank 0 is using GPU 0
[TensorRT-LLM][INFO] TRTGptModel maxNumSequences: 10
[TensorRT-LLM][INFO] TRTGptModel maxBatchSize: 10
[TensorRT-LLM][INFO] TRTGptModel maxBeamWidth: 1
[TensorRT-LLM][INFO] TRTGptModel maxSequenceLen: 512
[TensorRT-LLM][INFO] TRTGptModel maxDraftLen: 0
[TensorRT-LLM][INFO] TRTGptModel mMaxAttentionWindowSize: 512
[TensorRT-LLM][INFO] TRTGptModel enableTrtOverlap: 0
[TensorRT-LLM][INFO] TRTGptModel normalizeLogProbs: 0
[TensorRT-LLM][INFO] TRTGptModel maxNumTokens: 5120
[TensorRT-LLM][INFO] TRTGptModel maxInputLen: 511 = min(maxSequenceLen - 1, maxNumTokens) since context FMHA and usePackedInput are enabled
[TensorRT-LLM][INFO] TRTGptModel If model type is encoder, maxInputLen would be reset in trtEncoderModel to maxInputLen: min(maxSequenceLen, maxNumTokens).
[TensorRT-LLM][INFO] Capacity Scheduler Policy: GUARANTEED_NO_EVICT
[TensorRT-LLM][INFO] Context Chunking Scheduler Policy: None
[TensorRT-LLM][INFO] Loaded engine size: 3943 MiB
[TensorRT-LLM][INFO] [MemUsageChange] Allocated 415.00 MiB for execution context memory.
[TensorRT-LLM][INFO] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +0, now: CPU 0, GPU 3938 (MiB)
[TensorRT-LLM][INFO] [MemUsageChange] Allocated 1.36 MB GPU memory for runtime buffers.
[TensorRT-LLM][INFO] [MemUsageChange] Allocated 6.81 MB GPU memory for decoder.
[TensorRT-LLM][INFO] Memory usage when calculating max tokens in paged kv cache: total: 61.37 GiB, available: 43.44 GiB
[TensorRT-LLM][INFO] Number of blocks in KV cache primary pool: 1252
[TensorRT-LLM][INFO] Number of blocks in KV cache secondary pool: 0, onboard blocks to primary memory before reuse: true
[TensorRT-LLM][INFO] Max KV cache pages per sequence: 8
[TensorRT-LLM][INFO] Number of tokens per block: 64.
[TensorRT-LLM][INFO] [MemUsageChange] Allocated 39.12 GiB for max tokens in paged KV cache (80128).
[11/23/2024-12:04:36] [TRT-LLM] [E] Failed to load tokenizer from /tmp/tmpofbqzwkkllm-workspace/tmp.engine: Unrecognized model in /tmp/tmpofbqzwkkllm-workspace/tmp.engine. Should have a model_type
key in its config.json, or contain one of the following strings in its name: albert, align, altclip, audio-spectrogram-transformer, autoformer, bark, bart, beit, bert, bert-generation, big_bird, bigbird_pegasus, biogpt, bit, blenderbot, blenderbot-small, blip, blip-2, bloom, bridgetower, bros, camembert, canine, chameleon, chinese_clip, chinese_clip_vision_model, clap, clip, clip_text_model, clip_vision_model, clipseg, clvp, code_llama, codegen, cohere, conditional_detr, convbert, convnext, convnextv2, cpmant, ctrl, cvt, dac, data2vec-audio, data2vec-text, data2vec-vision, dbrx, deberta, deberta-v2, decision_transformer, deformable_detr, deit, depth_anything, deta, detr, dinat, dinov2, distilbert, donut-swin, dpr, dpt, efficientformer, efficientnet, electra, encodec, encoder-decoder, ernie, ernie_m, esm, falcon, falcon_mamba, fastspeech2_conformer, flaubert, flava, fnet, focalnet, fsmt, funnel, fuyu, gemma, gemma2, git, glm, glpn, gpt-sw3, gpt2, gpt_bigcode, gpt_neo, gpt_neox, gpt_neox_japanese, gptj, gptsan-japanese, granite, granitemoe, graphormer, grounding-dino, groupvit, hiera, hubert, ibert, idefics, idefics2, idefics3, imagegpt, informer, instructblip, instructblipvideo, jamba, jetmoe, jukebox, kosmos-2, layoutlm, layoutlmv2, layoutlmv3, led, levit, lilt, llama, llava, llava_next, llava_next_video, llava_onevision, longformer, longt5, luke, lxmert, m2m_100, mamba, mamba2, marian, markuplm, mask2former, maskformer, maskformer-swin, mbart, mctct, mega, megatron-bert, mgp-str, mimi, mistral, mixtral, mllama, mobilebert, mobilenet_v1, mobilenet_v2, mobilevit, mobilevitv2, moshi, mpnet, mpt, mra, mt5, musicgen, musicgen_melody, mvp, nat, nemotron, nezha, nllb-moe, nougat, nystromformer, olmo, olmoe, omdet-turbo, oneformer, open-llama, openai-gpt, opt, owlv2, owlvit, paligemma, patchtsmixer, patchtst, pegasus, pegasus_x, perceiver, persimmon, phi, phi3, phimoe, pix2struct, pixtral, plbart, poolformer, pop2piano, prophetnet, pvt, pvt_v2, qdqbert, qwen2, qwen2_audio, qwen2_audio_encoder, qwen2_moe, qwen2_vl, rag, realm, recurrent_gemma, reformer, regnet, rembert, resnet, retribert, roberta, roberta-prelayernorm, roc_bert, roformer, rt_detr, rt_detr_resnet, rwkv, sam, seamless_m4t, seamless_m4t_v2, segformer, seggpt, sew, sew-d, siglip, siglip_vision_model, speech-encoder-decoder, speech_to_text, speech_to_text_2, speecht5, splinter, squeezebert, stablelm, starcoder2, superpoint, swiftformer, swin, swin2sr, swinv2, switch_transformers, t5, table-transformer, tapas, time_series_transformer, timesformer, timm_backbone, trajectory_transformer, transfo-xl, trocr, tvlt, tvp, udop, umt5, unispeech, unispeech-sat, univnet, upernet, van, video_llava, videomae, vilt, vipllava, vision-encoder-decoder, vision-text-dual-encoder, visual_bert, vit, vit_hybrid, vit_mae, vit_msn, vitdet, vitmatte, vits, vivit, wav2vec2, wav2vec2-bert, wav2vec2-conformer, wavlm, whisper, xclip, xglm, xlm, xlm-prophetnet, xlm-roberta, xlm-roberta-xl, xlnet, xmod, yolos, yoso, zamba, zoedepth
File “/opt/TensorRT-LLM/examples/apps/openai_server.py”, line 451, in
entrypoint()
File “/usr/local/lib/python3.10/dist-packages/click/core.py”, line 1157, in call
return self.main(*args, **kwargs)
File “/usr/local/lib/python3.10/dist-packages/click/core.py”, line 1078, in main
rv = self.invoke(ctx)
File “/usr/local/lib/python3.10/dist-packages/click/core.py”, line 1434, in invoke
return ctx.invoke(self.callback, **ctx.params)
File “/usr/local/lib/python3.10/dist-packages/click/core.py”, line 783, in invoke
return __callback(*args, **kwargs)
File “/opt/TensorRT-LLM/examples/apps/openai_server.py”, line 441, in entrypoint
hf_tokenizer = AutoTokenizer.from_pretrained(tokenizer or model_dir)
File “/usr/local/lib/python3.10/dist-packages/transformers/models/auto/tokenization_auto.py”, line 877, in from_pretrained
config = AutoConfig.from_pretrained(
File “/usr/local/lib/python3.10/dist-packages/transformers/models/auto/configuration_auto.py”, line 1049, in from_pretrained
raise ValueError(
ValueError: Unrecognized model in /data/models/tensorrt_llm/Llama-2-7b-chat-hf-gptq. Should have a model_type
Error in sys.excepthook:
File “/usr/local/lib/python3.10/dist-packages/tensorrt_llm/hlapi/utils.py”, line 319, in call
obj.shutdown()
AttributeError: ‘LLM’ object has no attribute ‘shutdown’. Did you mean: ‘_shutdown’?
Original exception was:
entrypoint()
raise ValueError(
