I am trying to use lpdnet in python with a tensorrt model. The following code successfully runs inference but I cannot interpret the output.
import os
import time
import cv2
#import matplotlib.pyplot as plt
import numpy as np
import pycuda.autoinit
import pycuda.driver as cuda
import tensorrt as trt
import pdb
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
def load_engine(trt_runtime, engine_path):
with open(engine_path, "rb") as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
# Allocates all buffers required for an engine, i.e. host/device inputs/outputs.
def allocate_buffers(engine, batch_size=1):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
for binding in engine:
# pdb.set_trace()
size = trt.volume(engine.get_binding_shape(binding)) * batch_size
dtype = trt.nptype(engine.get_binding_dtype(binding))
# Allocate host and device buffers
host_mem = cuda.pagelocked_empty(size, dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
# Append the device buffer to device bindings.
bindings.append(int(device_mem))
# Append to the appropriate list.
if engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
print(f"input: shape:{engine.get_binding_shape(binding)} dtype:{engine.get_binding_dtype(binding)}")
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
print(f"output: shape:{engine.get_binding_shape(binding)} dtype:{engine.get_binding_dtype(binding)}")
return inputs, outputs, bindings, stream
def do_inference(context, bindings, inputs, outputs, stream, batch_size=1):
# Transfer input data to the GPU.
[cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
# Run inference.
context.execute_async(
batch_size=batch_size, bindings=bindings, stream_handle=stream.handle
# Transfer predictions back from the GPU.
[cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
# Synchronize the stream
stream.synchronize()
# Return only the host outputs.
return [out.host for out in outputs]
# TensorRT logger singleton
os.environ["CUDA_VISIBLE_DEVICES"] = "1"
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
trt_engine_path = "lpd.trt"
trt_runtime = trt.Runtime(TRT_LOGGER)
# pdb.set_trace()
trt_engine = load_engine(trt_runtime, trt_engine_path)
# Execution context is needed for inference
context = trt_engine.create_execution_context()
# This allocates memory for network inputs/outputs on both CPU and GPU
inputs, outputs, bindings, stream = allocate_buffers(trt_engine)
# pdb.set_trace()
image = cv2.imread("car.jpg")
image = cv2.resize(image, (640, 480))
np.copyto(inputs[0].host, image.ravel())
outputs = do_inference(context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream)
test1 = np.reshape(outputs[0], (4, 30, 40))
test2 = np.reshape(outputs[1], (1, 30, 40))
# cv2.imshow("1", test1)
cv2.imshow("2", test2)
cv2.waitKey()
print(outputs)
The output defined by the engine is as follows:
output: shape:(4, 30, 40) dtype:DataType.FLOAT
output: shape:(1, 30, 40) dtype:DataType.FLOAT
From the documentation
The usa
prunedmodels are intended for easy deployment to the edge using DeepStream SDK or TensorRT. They accept640x480x3dimension input tensors and outputs40x30x12bbox coordinate tensor and40x30x3class confidence tensor.
The tensorrt engine was made with the following command:
tlt-converter -k nvidia_tlt -d 3,480,640 -p image_input,1x3x480x640,4x3x480x640,16x3x480x640 usa_pruned.etlt -t fp16 -e lpr_engine.trt
The problem is that the confidence and bbox arrays have different shapes than expected. How do I go about drawing the bounding boxes on the image after inference?
Simon
