TensorRT Model Optimizer INT8 quantization causes 2.7x performance regression on Jetson Orin Nano 4GB (ViT-S + DPT architecture)
Environment
  • Hardware: Jetson Orin Nano 4GB Developer Kit
  • L4T Version: R36.4.3 (Jan 8, 2025)
  • JetPack Version: 6.2
  • TensorRT Version: 10.3.0
  • Model Optimizer Versions Tested: 0.31, 0.35, 0.40
Conversion Pipeline
  1. Model exported to ONNX from PyTorch on desktop (x86)
  2. INT8 quantization applied using TensorRT Model Optimizer on desktop
  3. ONNX transferred to Jetson Orin Nano
  4. TensorRT engine built on-device using trtexec
Model Architecture
ViT-S + DPT encoder for dense feature extraction.
Input: 1x1x364x490 (grayscale image, batch of 2 processed together)
Output: Multi-scale feature maps (1x2x32x364x490 for full encoder, or per-layer features for ViT-S only)
Description
When quantizing the ViT-S + DPT encoder to INT8 using NVIDIA TensorRT Model Optimizer, the resulting engine exhibits:
  1. ~2.7x performance regression compared to FP16 baseline
  2. Compilation failure on ModelOpt 0.40 (latest version)
  3. Even with trtexec’s native `–fp16 --int8` flags (bypassing ModelOpt), INT8 shows minimal improvement over FP16 (~5% vs expected 20-50%)Results Summary
Full Encoder (ViT-S + DPT)
Precision Mode ModelOpt 0.31 ModelOpt 0.35 ModelOpt 0.40
FP16 only 41.8 ms 41.9 ms 42.7 ms
FP16+INT8 (trtexec flags) 39.7 ms 39.7 ms 40.4 ms
ModelOpt INT8 (--stronglyTyped) 114.5 ms 114.1 ms FAILS
ViT-S Only (ModelOpt 0.40)
Precision Mode Latency Throughput
FP16 only 30.75 ms 32.1 qps
FP16+INT8 (trtexec flags) 30.80 ms 32.5 qps
ModelOpt INT8 (--stronglyTyped) 30.34 ms 32.9 qps
Even the isolated ViT-S shows only ~1.3% improvement with INT8 quantization.
ModelOpt 0.40 Compilation Failure
trtexec \
  --onnx=model_backbone_modelopt40_int8.onnx \
  --stronglyTyped \
  --noDataTransfers \
  --useCudaGraph \
  --useSpinWait
Error:
[01/16/2026-16:22:07] [E] Error[2]: [weightsPtr.h::values::182] Error Code 2: Internal Error (Assertion type() == expectedDataType<T>() failed. )
[01/16/2026-16:22:07] [E] Engine could not be created from network
[01/16/2026-16:22:07] [E] Building engine failed
[01/16/2026-16:22:07] [E] Failed to create engine from model or file.
[01/16/2026-16:22:07] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v100300]
Steps to Reproduce
FP16 Baseline
trtexec \
  --onnx=model_backbone.onnx \
  --fp16 \
  --noDataTransfers \
  --useCudaGraph \
  --useSpinWait
ModelOpt INT8
python3 \
-m modelopt.onnx.quantization \
--onnx_path model_backbone.onnx \
--quantize_mode int8 \
--output_path model_backbone_int8.onnx
trtexec \
  --onnx=model_backbone_int8.onnx \
  --stronglyTyped \
  --noDataTransfers \
  --useCudaGraph \
  --useSpinWait
Drive folder with all the onnx
We quantize the model and run it with trtexec on Orin Nano and can get 41 qps.
Could you check if this can meet your requirement?
$  python3 -m modelopt.onnx.quantization --onnx_path vits.onnx --quantize_mode int8 --output_path int8_model.onnx
$ /usr/src/tensorrt/bin/trtexec --onnx=int8_model.onnx --int8 --fp16
[01/19/2026-05:19:40] [I] === Performance summary ===
[01/19/2026-05:19:40] [I] Throughput: 41.3892 qps
[01/19/2026-05:19:40] [I] Latency: min = 24.355 ms, max = 24.4976 ms, mean = 24.4676 ms, median = 24.4681 ms, percentile(90%) = 24.4811 ms, percentile(95%) = 24.4847 ms, percentile(99%) = 24.4958 ms
[01/19/2026-05:19:40] [I] Enqueue Time: min = 0.801758 ms, max = 1.14743 ms, mean = 0.850748 ms, median = 0.835938 ms, percentile(90%) = 0.894531 ms, percentile(95%) = 0.93103 ms, percentile(99%) = 1.09009 ms
[01/19/2026-05:19:40] [I] H2D Latency: min = 0.0443115 ms, max = 0.0612793 ms, mean = 0.0482149 ms, median = 0.0476074 ms, percentile(90%) = 0.0505981 ms, percentile(95%) = 0.0562744 ms, percentile(99%) = 0.06073 ms
[01/19/2026-05:19:40] [I] GPU Compute Time: min = 23.949 ms, max = 23.9971 ms, mean = 23.969 ms, median = 23.9688 ms, percentile(90%) = 23.9817 ms, percentile(95%) = 23.9851 ms, percentile(99%) = 23.9954 ms
[01/19/2026-05:19:40] [I] D2H Latency: min = 0.343262 ms, max = 0.456421 ms, mean = 0.450377 ms, median = 0.451202 ms, percentile(90%) = 0.453613 ms, percentile(95%) = 0.454376 ms, percentile(99%) = 0.456299 ms
[01/19/2026-05:19:40] [I] Total Host Walltime: 3.06844 s
[01/19/2026-05:19:40] [I] Total GPU Compute Time: 3.04406 s
Hey @AastaLLL, thanks for replying? I have a few questions:
  1. What tensorrt and model opt version are you using.
  2. Can you help compile the other model i uploaded (full encoder) as that is what we ultimately care about.
Also just want to confirm that our experiments are on Jetson Orin Nano 4GB.
Hi
Our Orin Nano 8GB device is set up with JetPack 6.2.1, so the TensorRT version is 10.3.
We pull the latest Model Optimizer directly.
What is the difference between the models?
We test the vits.onnx model only, since other files seem to have been quantized with Model Optimizer already.
Hey @AastaLLL,
  1. As i mentioned in the ticket, we are trying to run these models on Orin Nano 4GB.
  2. The vits.onnx is a smaller version of the actual model we want to convert. We were able to run this with int8 precision but we notice no speedup in doing so. The actual model doesn’t even convert with the latest modelopt.
  3. The quantized modelopt models are provided so you can reproduce the error on your end and debug the compilation failure further.
Could you also attach the original actual model?
Okay, the models are present on the drive. Each modelopt version requires a slightly different min onnx so the models are different for 31,35 and 40.
Thanks for explaining this.
Sorry that we originally thought the backbone model was the converted output from Model Optimizer.
So only test the ViT-S one.
We will check this further and get back to you soon.
Thanks for your patience.
Here are our recent updates for you.
1.
We quantize the model with Mode Optimizer 0.41.0.
The int8 model cannot work with the default TensorRT 10.3, with the following error:
[01/27/2026-16:04:12] [E] Error[2]: [weightsPtr.h::values::182] Error Code 2: Internal Error (Assertion type() == expectedDataType<T>() failed. )
But it can work normally with our internal TensorRT release.
So please wait for our future TensorRT release for the fix.
2.
With the above int8 model, we don’t see the 2.7x performance regression.
Instead, the performance between int8 and fp16 are quite similiar:
FP16
[02/12/2026-01:56:53] [I] Throughput: 28.1819 qps
[02/12/2026-01:56:53] [I] Latency: min = 36.4265 ms, max = 36.7357 ms, mean = 36.6772 ms, median = 36.6803 ms, percentile(90%) = 36.7141 ms, percentile(95%) = 36.715 ms, percentile(99%) = 36.7357 ms
[02/12/2026-01:56:53] [I] Enqueue Time: min = 1.01276 ms, max = 1.71167 ms, mean = 1.08244 ms, median = 1.05368 ms, percentile(90%) = 1.16745 ms, percentile(95%) = 1.20776 ms, percentile(99%) = 1.71167 ms
[02/12/2026-01:56:53] [I] H2D Latency: min = 0.0428467 ms, max = 0.0772705 ms, mean = 0.0500337 ms, median = 0.0484543 ms, percentile(90%) = 0.0579834 ms, percentile(95%) = 0.0625 ms, percentile(99%) = 0.0772705 ms
[02/12/2026-01:56:53] [I] GPU Compute Time: min = 35.0419 ms, max = 35.1392 ms, mean = 35.0837 ms, median = 35.0845 ms, percentile(90%) = 35.1147 ms, percentile(95%) = 35.1243 ms, percentile(99%) = 35.1392 ms
[02/12/2026-01:56:53] [I] D2H Latency: min = 1.30298 ms, max = 1.55908 ms, mean = 1.54347 ms, median = 1.54611 ms, percentile(90%) = 1.55139 ms, percentile(95%) = 1.552 ms, percentile(99%) = 1.55908 ms
[02/12/2026-01:56:53] [I] Total Host Walltime: 3.12257 s
[02/12/2026-01:56:53] [I] Total GPU Compute Time: 3.08737 s
INT8:
[02/12/2026-02:40:54] [I] Throughput: 29.0629 qps
[02/12/2026-02:40:54] [I] Latency: min = 35.3667 ms, max = 35.4888 ms, mean = 35.4452 ms, median = 35.4452 ms, percentile(90%) = 35.4648 ms, percentile(95%) = 35.4738 ms, percentile(99%) = 35.4888 ms
[02/12/2026-02:40:54] [I] Enqueue Time: min = 1.48633 ms, max = 1.89337 ms, mean = 1.54987 ms, median = 1.53223 ms, percentile(90%) = 1.59692 ms, percentile(95%) = 1.63062 ms, percentile(99%) = 1.89337 ms
[02/12/2026-02:40:54] [I] H2D Latency: min = 0.046936 ms, max = 0.065918 ms, mean = 0.0508698 ms, median = 0.0501709 ms, percentile(90%) = 0.0534668 ms, percentile(95%) = 0.0595703 ms, percentile(99%) = 0.065918 ms
[02/12/2026-02:40:54] [I] GPU Compute Time: min = 33.9907 ms, max = 34.0718 ms, mean = 34.0271 ms, median = 34.0264 ms, percentile(90%) = 34.0444 ms, percentile(95%) = 34.0532 ms, percentile(99%) = 34.0718 ms
[02/12/2026-02:40:54] [I] D2H Latency: min = 1.30103 ms, max = 1.37488 ms, mean = 1.36725 ms, median = 1.36804 ms, percentile(90%) = 1.37134 ms, percentile(95%) = 1.37207 ms, percentile(99%) = 1.37488 ms
[02/12/2026-02:40:54] [I] Total Host Walltime: 3.09673 s
[02/12/2026-02:40:54] [I] Total GPU Compute Time: 3.06244 s
3.
We also analyze whether it is possible to get further improvement with int8.
But for this particular case, the gain of the underlying kernel from INT8 is limited.
So we don’t think it is possible to improve further.
