Hi, we have run /tensorrt/samples/sampleINT8API/sampleINT8API.cpp on GPU and DLA, both can be successfully executed.
So, we try replace my onnx model, it’s like MobilenetV2, it can be successfully executed on GPU.
But when we enable DLA is faled.
log information is as follows:
&&&& RUNNING TensorRT.sample_int8_api # ./../../bin/sample_int8_api
[01/13/2020-13:59:47] [I] Please follow README.md to generate missing input files.
[01/13/2020-13:59:47] [I] Validating input parameters. Using following input files for inference.
[01/13/2020-13:59:47] [I] Model File: /home/nvidia/xavierRT/tensorrt/bin/data/int8_api/AIRD_0203_notanh-simplify-pruning.onnx
[01/13/2020-13:59:47] [I] Image File: /home/nvidia/xavierRT/tensorrt/bin/data/int8_api/0009_23.ppm
[01/13/2020-13:59:47] [I] Reference File: /home/nvidia/xavierRT/tensorrt/data/int8_api/reference_labels.txt
[01/13/2020-13:59:47] [I] Dynamic Range File: /home/nvidia/xavierRT/tensorrt/bin/data/int8_api/FRD_dynamic_range.txt
[01/13/2020-13:59:47] [I] Building and running a INT8 GPU inference engine for /home/nvidia/xavierRT/tensorrt/bin/data/int8_api/AIRD_0203_notanh-simplify-pruning.onnx
******set dlaCore
[01/13/2020-13:59:48] [I] Setting Per Layer Computation Precision
[01/13/2020-13:59:48] [W] [TRT] Calling isShapeTensor before the entire network is constructed may result in an inaccurate result.
[01/13/2020-13:59:48] [I] Setting Per Tensor Dynamic Range
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 62) [Shuffle] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 63) [Constant] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 64) [Constant] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 65) [Matrix Multiply] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 68) [Identity] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 69) [Identity] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 70) [Constant] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 71) [Constant] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 72) [Matrix Multiply] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Default DLA is enabled but layer (Unnamed Layer* 74) [Softmax] is not supported on DLA, falling back to GPU.
[01/13/2020-13:59:48] [W] [TRT] Calibrator is not being used. Users must provide dynamic range for all tensors that are not Int32.
[01/13/2020-13:59:48] [W] [TRT] DLA allows only same dimensions inputs to Elementwise.
[01/13/2020-13:59:48] [W] [TRT] Internal DLA error for layer (Unnamed Layer* 66) [ElementWise]. Switching to GPU fallback.
[01/13/2020-13:59:48] [F] [TRT] Assertion failed: begin >= 0 && end <= dims.nbDims && begin <= end
../builder/symbolicDims.cpp:502
Aborting...
[01/13/2020-13:59:48] [E] [TRT] ../builder/symbolicDims.cpp (502) - Assertion Error in axisRange: 0 (begin >= 0 && end <= dims.nbDims && begin <= end)
[01/13/2020-13:59:48] [E] Unable to build cuda engine.
&&&& FAILED TensorRT.sample_int8_api # ./../../bin/sample_int8_api
What is the problem?
