Hi. I have a PC and I bought a Tesla P100-PCIE-16GB. I also have an Nvidia GTX1070 for video output. The motherboard is an ASUS X399-a and the Processor is AMD Threadripper 2920X and 64 GB RAM. I want to install the Tesla P100 on Windows 11 and use the GTX 1070 for video output. I installed the drivers from the Nvidia website for both cards but the Tesla card shows a warning triangle on the device manager. If I use TechPowerup GPU-Z I can see the GTX1070 with all its features but the Tesla shows only 8GB of RAM, and NOT CAPABLE of OpenCL, CUDA, DirectCompute, DirectML, PhysX, Vulkan and RayTracing and ONLY CAPABLE OF OpenGL4.6. How can I get it to work? Thanks
Do you mean you installed two different drivers? You should avoid that if possible. Both GPUs use Pascal architecture, so you should be fine with just one driver. Preferrably the Tesla specific one.
Can you share the output of nvidia-smi -q (please attach as text file)
Thank you Markus
I did install the 2 drivers. Tried installing only one but it wasn’t possible. At this point I have both cards looking fine in the device manager and GPU-Z, but it seems only the GTX 1070 is actually working because the temperature on the Tesla stays at around 35Celsius. Also, If I turn on HW-Info or GPU-Z everything becomes glitchy and irresponsive. I tried to run a simulation in Ansys, which is the main reason I got the Tesla card for, and it crashes. It did so several times and with different simulation models. I’m uploading the output of [nvidia-smi -q output.txt|attachment](upload://308RMKurbVw7OKqlZxNBelXPDY7.txt) (22.4 KB). Any further information, particularly if there’s some utility to see if the Tesla card actually works would be very much appreciated. Cheers!
text file contents… sorry I could’t upload the file
==============NVSMI LOG==============
Timestamp : Mon May 22 10:30:44 2023
Driver Version : 456.71
CUDA Version : 11.1
Attached GPUs : 2
GPU 00000000:0A:00.0
Product Name : Tesla P100-PCIE-16GB
Product Brand : Tesla
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : TCC
Pending : TCC
Serial Number : 0321817044785
GPU UUID : GPU-de8d6c77-30b7-7502-0ddd-9b4f4afad49c
Minor Number : N/A
VBIOS Version : 86.00.3A.00.03
MultiGPU Board : No
Board ID : 0xa00
GPU Part Number : 900-2H400-0300-031
Inforom Version
Image Version : H400.0201.00.08
OEM Object : 1.1
ECC Object : 4.1
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x0A
Device : 0x00
Domain : 0x0000
Device Id : 0x15F810DE
Bus Id : 00000000:0A:00.0
Sub System Id : 0x118F10DE
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
FB Memory Usage
Total : 16298 MiB
Used : 8 MiB
Free : 16290 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 2 MiB
Free : 16382 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
CBU : N/A
Total : 0
Double Bit
Device Memory : 2
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
CBU : N/A
Total : 2
Aggregate
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
CBU : N/A
Total : 0
Double Bit
Device Memory : 18
Register File : 0
L1 Cache : N/A
L2 Cache : 0
Texture Memory : 0
Texture Shared : 0
CBU : N/A
Total : 18
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 1
Pending Page Blacklist : Yes
Remapped Rows : N/A
Temperature
GPU Current Temp : 34 C
GPU Shutdown Temp : 85 C
GPU Slowdown Temp : 82 C
GPU Max Operating Temp : N/A
Memory Current Temp : N/A
Memory Max Operating Temp : N/A
Power Readings
Power Management : Supported
Power Draw : Unknown Error
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 125.00 W
Max Power Limit : 250.00 W
Clocks
Graphics : Unknown Error
SM : Unknown Error
Memory : 715 MHz
Video : Unknown Error
Applications Clocks
Graphics : 1189 MHz
Memory : 715 MHz
Default Applications Clocks
Graphics : 1189 MHz
Memory : 715 MHz
Max Clocks
Graphics : 1328 MHz
SM : 1328 MHz
Memory : 715 MHz
Video : 1328 MHz
Max Customer Boost Clocks
Graphics : 1328 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
GPU 00000000:41:00.0
Product Name : GeForce GTX 1070
Product Brand : GeForce
Display Active : Enabled
Driver Model
Current : WDDM
Pending : WDDM
Serial Number : N/A
GPU UUID : GPU-61f1dbf8-8119-749c-ebc5-468e1f6d202a
Minor Number : N/A
VBIOS Version : 86.04.50.40.4A
MultiGPU Board : No
Board ID : 0x4100
GPU Part Number : N/A
Inforom Version
Image Version : G001.0000.01.04
OEM Object : 1.1
ECC Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x41
Device : 0x00
Domain : 0x0000
Device Id : 0x1B8110DE
Bus Id : 00000000:41:00.0
Sub System Id : 0x37721458
GPU Link Info
PCIe Generation
Max : 3
Current : 1
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Rx Throughput : 2000 KB/s
Fan Speed : 0 %
Performance State : P8
Idle : Active
FB Memory Usage
Total : 8192 MiB
Used : 1217 MiB
Free : 6975 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 229 MiB
Free : 27 MiB
Utilization
Gpu : 12 %
Memory : 18 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : N/A
Pending : N/A
ECC Errors
Volatile
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Aggregate
Single Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Double Bit
Device Memory : N/A
Register File : N/A
L1 Cache : N/A
L2 Cache : N/A
CBU : N/A
Total : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows : N/A
Temperature
GPU Current Temp : 45 C
GPU Shutdown Temp : 99 C
GPU Slowdown Temp : 96 C
Power Readings
Power Draw : 13.38 W
Power Limit : 180.00 W
Default Power Limit : 180.00 W
Enforced Power Limit : 180.00 W
Min Power Limit : 90.00 W
Max Power Limit : 200.00 W
Clocks
Graphics : 139 MHz
SM : 139 MHz
Memory : 405 MHz
Video : 544 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Graphics : N/A
Memory : N/A
Max Clocks
Graphics : 1999 MHz
SM : 1999 MHz
Memory : 4004 MHz
Video : 1708 MHz
Graphics : N/A
Clock Policy
Auto Boost : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 1308
Type : C+G
Name : Insufficient Permissions
Used GPU Memory : Not available in WDDM driver model
Process ID : 3212
Type : C+G
Process ID : 5340
Type : C
Process ID : 6840
Type : C+G
Name : C:\Program Files\WindowsApps\Microsoft.WindowsTerminal_1.16.10262.0_x64__8wekyb3d8bbwe\WindowsTerminal.exe
Process ID : 8576
Type : C+G
Process ID : 9044
Type : C+G
Process ID : 9396
Type : C+G
Process ID : 10216
Type : C+G
Name : C:\Windows\SystemApps\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy\StartMenuExperienceHost.exe
Process ID : 12256
Type : C+G
Name : C:\Windows\SystemApps\MicrosoftWindows.Client.CBS_cw5n1h2txyewy\TextInputHost.exe
Process ID : 13608
Type : C+G
Name : C:\Program Files\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
Process ID : 14896
Type : C+G
Process ID : 15136
Type : C+G
Name : C:\Program Files\Google\Drive File Stream\75.0.2.0\GoogleDriveFS.exe
Process ID : 15408
Type : C+G
Name : C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe
Process ID : 16840
Type : C+G
Process ID : 17664
Type : C+G
Process ID : 18048
Type : C+G
Name : C:\Program Files (x86)\Microsoft\EdgeWebView\Application\113.0.1774.50\msedgewebview2.exe
Process ID : 18088
Type : C+G
Process ID : 18752
Type : C+G
Name : C:\Program Files\Mozilla Firefox\firefox.exe
Process ID : 19068
Type : C+G
In what way? If you download the driver directly you should be able to install it manually. Make sure to remove any residual driver installation first. (Clear uninstall with something like DDU should work). Then install the Tesla driver. The 1070 should still work nicely.
In any case, first make sure your BIOS is updated and you have “Above 4G decoding” enabled! The P100 has a BAR setting of 16GB so it will need the BIOS support to work correctly.
It is not surprising that the GPU is idling right now, because Windows will use the 1070 as the main GPU since it has Display outputs. Windows as such will not know what to do with the second card. You need your Software to be multi-GPU aware. That means for example Ansys needs to be able to use the secondary GPU specifically. nvidia-smi is showing it as active and available, but aside from the potential BAR issue above you also need to make sure the SW you use is aware of it.
One way of testing this is to try the CUDA samples, especially the ones about choosing and enumerating CUDA devices. If you get those working correctly, the GPU is fine. If not and it cannot be a driver or BIOS problem, then your GPU itself might have an issue.
I mentioned this before in a different thread, P100 is NOT meant to be used as a Desktop PC GPU, so there is no guarantee that it will work at all.
I tried to remove the drivers with DDU in safe mode and reinstall with only one and it wasn’t possible. I did use Above 4G decoding in the BIOS but no joy… My guess is that I received a damaged product and I decided to return it. In any case, thank you very much for your help! Cheers!
Thank you for the update!
I am sorry to hear that you had to return the GPU. But yes, sometimes the Hardware itself is at fault.
