The code that builds well in tensorRT 7.1.3 is
tensorRT 8.0.1 gives the following error:
How can we solve this problem?
/usr/include/aarch64-linux-gnu/NvInferRuntimeCommon.h:1222:18: error: overriding ‘virtual void nvinfer1::ILogger::log(nvinfer1::ILogger::Severity, const AsciiChar*) noexcept’
virtual void log(Severity severity, AsciiChar const* msg) noexcept = 0;
Thank you.
The ILogger API has slightly changed in TensorRT 8.0.
Please update it with a similar way as below:
#include "logger.h"
sample::Logger logger;
nvinfer1::IRuntime* runtime = nvinfer1::createInferRuntime(logger);
Which file do I have to modify?
Thank you.
Would you mind sharing the source of your app with us?
So we can check it for you?
It’s an open source.
URL: https://github.com/linghu8812/tensorrt_inference/tree/master/yolov5
I am getting the above error when building this project.
Can you please check what the problem is?
The method I found through the forum is at the URL below.
Hi @lukee2ni6 ,
I had the same error and was able to fix it by adding noexcept so the function looks like:
void Logger::log(Severity severity, const char* msg) noexcept
in the source file and
virtual void log(Severity severity, const char* msg) noexcept override;
in the header. The noexcept flag is in the declaration of log in ILogger in the NvInferRuntimeCommon.h file. This may have changed from the previous version and specifies that the function cannot thrown an exception, so is a pret…
It seems to be a temporary solution, can you find a more fundamental solution?
Thank you.
Please try to apply the following changes:
diff --git a/includes/common/common.hpp b/includes/common/common.hpp
index 398be37..dee73b9 100755
--- a/includes/common/common.hpp
+++ b/includes/common/common.hpp
@@ -5,6 +5,7 @@
#include <numeric>
#include <fstream>
#include <dirent.h>
+#include "NvInferRuntimeCommon.h"
#include "NvOnnxParser.h"
#include "logging.h"
@@ -42,14 +43,14 @@ inline int64_t volume(const nvinfer1::Dims& d)
return std::accumulate(d.d, d.d + d.nbDims, 1, std::multiplies<int64_t>());
-Logger gLogger{Logger::Severity::kINFO};
-LogStreamConsumer gLogVerbose{LOG_VERBOSE(gLogger)};
-LogStreamConsumer gLogInfo{LOG_INFO(gLogger)};
-LogStreamConsumer gLogWarning{LOG_WARN(gLogger)};
-LogStreamConsumer gLogError{LOG_ERROR(gLogger)};
-LogStreamConsumer gLogFatal{LOG_FATAL(gLogger)};
+sample::Logger gLogger{sample::Logger::Severity::kINFO};
+sample::LogStreamConsumer gLogVerbose{sample::LOG_VERBOSE(gLogger)};
+sample::LogStreamConsumer gLogInfo{sample::LOG_INFO(gLogger)};
+sample::LogStreamConsumer gLogWarning{sample::LOG_WARN(gLogger)};
+sample::LogStreamConsumer gLogError{sample::LOG_ERROR(gLogger)};
+sample::LogStreamConsumer gLogFatal{sample::LOG_FATAL(gLogger)};
-void setReportableSeverity(Logger::Severity severity)
+void setReportableSeverity(sample::Logger::Severity severity)
gLogger.setReportableSeverity(severity);
gLogVerbose.setReportableSeverity(severity);
diff --git a/includes/common/logging.h b/includes/common/logging.h
index 602b69f..a2934fe 100644
--- a/includes/common/logging.h
+++ b/includes/common/logging.h
@@ -1,5 +1,5 @@
- * Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
+ * Copyright (c) 2021, NVIDIA CORPORATION. All rights reserved.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
@@ -26,6 +26,9 @@
#include <sstream>
#include <string>
+namespace sample
using Severity = nvinfer1::ILogger::Severity;
class LogStreamConsumerBuffer : public std::stringbuf
@@ -40,6 +43,8 @@ public:
LogStreamConsumerBuffer(LogStreamConsumerBuffer&& other)
: mOutput(other.mOutput)
+ , mPrefix(other.mPrefix)
+ , mShouldLog(other.mShouldLog)
@@ -81,11 +86,11 @@ public:
// std::stringbuf::str() gets the string contents of the buffer
// insert the buffer contents pre-appended by the appropriate prefix into the stream
mOutput << mPrefix << str();
- // set the buffer to empty
- str("");
- // flush the stream
- mOutput.flush();
+ // set the buffer to empty
+ str("");
+ // flush the stream
+ mOutput.flush();
void setShouldLog(bool shouldLog)
@@ -225,7 +230,7 @@ public:
//! TODO Once all samples are updated to use this method to register the logger with TensorRT,
//! we can eliminate the inheritance of Logger from ILogger
- nvinfer1::ILogger& getTRTLogger()
+ nvinfer1::ILogger& getTRTLogger() noexcept
return *this;
@@ -236,7 +241,7 @@ public:
//! Note samples should not be calling this function directly; it will eventually go away once we eliminate the
//! inheritance from nvinfer1::ILogger
- void log(Severity severity, const char* msg) override
+ void log(Severity severity, const char* msg) noexcept override
LogStreamConsumer(mReportableSeverity, severity) << "[TRT] " << std::string(msg) << std::endl;
@@ -305,8 +310,10 @@ public:
//! \return a TestAtom that can be used in Logger::reportTest{Start,End}().
static TestAtom defineTest(const std::string& name, int argc, char const* const* argv)
+ // Append TensorRT version as info
+ const std::string vname = name + " [TensorRT v" + std::to_string(NV_TENSORRT_VERSION) + "]";
auto cmdline = genCmdlineString(argc, argv);
- return defineTest(name, cmdline);
+ return defineTest(vname, cmdline);
@@ -425,7 +432,9 @@ private:
for (int i = 0; i < argc; i++)
if (i > 0)
ss << " ";
ss << argv[i];
return ss.str();
@@ -487,7 +496,7 @@ inline LogStreamConsumer LOG_ERROR(const Logger& logger)
//! \brief produces a LogStreamConsumer object that can be used to log messages of severity kINTERNAL_ERROR
-// ("fatal" severity)
+//! ("fatal" severity)
//! Example usage:
@@ -500,4 +509,6 @@ inline LogStreamConsumer LOG_FATAL(const Logger& logger)
} // anonymous namespace
+} // namespace sample */
#endif // TENSORRT_LOGGING_H
includes/common/common.h:31:8: error: ‘Logger’ does not name a type; did you mean ‘getLogger’?
static Logger gLogger{Logger::Severity::kINFO};
getLogger
includes/common/common.h:32:8: error: ‘LogStreamConsumer’ does not name a type
static LogStreamConsumer gLogVerbose{LOG_VERBOSE(gLogger)};
includes/common/common.h:33:8: error: ‘LogStreamConsumer’ does not name a type
static LogStreamConsumer gLogInfo{LOG_INFO(gLogger)};
includes/common/common.h:34:8: error: ‘LogStreamConsumer’ does not name a type
static LogStreamConsumer gLogWarning{LOG_WARN(gLogger)};
includes/common/common.h:35:8: error: ‘LogStreamConsumer’ does not name a type
static LogStreamConsumer gLogError{LOG_ERROR(gLogger)};
includes/common/common.h:36:8: error: ‘LogStreamConsumer’ does not name a type
static LogStreamConsumer gLogFatal{LOG_FATAL(gLogger)};
includes/common/common.h:57:28: error: variable or field ‘setReportableSeverity’ declared void
void setReportableSeverity(Logger::Severity severity);
includes/common/common.h:57:28: error: ‘Logger’ has not been declared
includes/common/common.cpp:8:28: error: variable or field ‘setReportableSeverity’ declared void
includes/common/common.cpp:8:28: error: ‘Logger’ has not been declared
Can you tell me how to resolve these errors?
Thank you.
Dear @forumuser ,
Have you applied the changes given in #7 . Also, could you make changes to Logger class varaibles in common.h same as in common.hpp(like use sample::Logger instead of Logger, use sample::LogStreamConsumer instead of LogStreamConsumer etc) and confirm if it helps?
system
Closed
April 27, 2022, 3:35am
12
