The container stops in between TAO training
I am training a model using the TAO Toolkit in WSL2 with GPU support, but when i start the training the container automatically stops after 1-2 epochs, also the training speed is relatively slow.
My setup is as follows:
WSL2 Distribution: Ubuntu 20.04 (Version: 2)
CUDA Toolkit Version: 12.2
NVIDIA Driver Version: 535.183.01
GPU: NVIDIA GeForce RTX 4090
This is my specs file:
random_seed: 42
ssd_config {
aspect_ratios_global: “[1.0, 2.0, 0.5, 3.0, 1.0/3.0]”
scales: “[0.05, 0.1, 0.25, 0.4, 0.55, 0.7, 0.85]”
two_boxes_for_ar1: true
clip_boxes: false
variances: “[0.1, 0.1, 0.2, 0.2]”
arch: “resnet”
nlayers: 18
freeze_bn: false
freeze_blocks: 0
training_config {
batch_size_per_gpu: 1
num_epochs: 100
enable_qat: false
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-5
max_learning_rate: 2e-2
soft_start: 0.15
annealing: 0.8
regularizer {
type: L1
weight: 3e-5
eval_config {
validation_period_during_training: 10
average_precision_mode: SAMPLE
batch_size: 1
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.01
clustering_iou_threshold: 0.6
top_k: 200
augmentation_config {
output_width: 1920
output_height: 1080
output_channel: 3
dataset_config {
data_sources: {
#tfrecords_path: “/workspace/tao-experiments/data/tfrecords/kitti_train*”
image_directory_path: “/workspace/tao-experiments/data/training/image”
label_directory_path: “/workspace/tao-experiments/data/training/label”
include_difficult_in_training: true
target_class_mapping {
key: “person”
value: “person”
key: “car”
value: “car”
key: “heavy_vehicle”
value: “heavy_vehicle”
key: “motor”
value: “motor”
key: “tricycle”
value: “tricycle”
validation_data_sources: {
label_directory_path: “/workspace/tao-experiments/data/val/label”
image_directory_path: “/workspace/tao-experiments/data/val/image”
and this is the resultant issue:
!tao model ssd train --gpus 1 --gpu_index=$GPU_INDEX \
            -e $SPECS_DIR/ssd_train_resnet18_kitti.txt \
            -r $USER_EXPERIMENT_DIR/experiment_dir_unpruned \
            -k $KEY \
            -m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/ssd_resnet18_epoch_001.hdf5 \
            --initial_epoch 3
Total params: 13,402,472
Trainable params: 13,379,624
Non-trainable params: 22,848
2024-12-07 03:47:51,360 [TAO Toolkit] [INFO] main 356: Number of images in the training dataset: 1634
2024-12-07 03:47:51,360 [TAO Toolkit] [INFO] main 358: Number of images in the validation dataset: 163
2024-12-07 03:47:51,844 [TAO Toolkit] [INFO] nvidia_tao_tf1.cv.common.logging.logging 197: Log file already exists at /workspace/tao-experiments/ssd/experiment_dir_unpruned/status.json
2024-12-07 03:47:53,883 [TAO Toolkit] [INFO] root 2102: Starting Training Loop.
Epoch 3/100
1634/1634 [==============================] - 2537s 2s/step - loss: 14.7520
[1733545829.422149] [9e597e0f07e8:249 :f] vfs_fuse.c:424 UCX WARN failed to connect to vfs socket ‘’: Invalid argument
Epoch 00003: saving model to /workspace/tao-experiments/ssd/experiment_dir_unpruned/weights/ssd_resnet18_epoch_003.hdf5
2024-12-07 04:30:44,682 [TAO Toolkit] [INFO] root 2102: Training loop in progress
Epoch 4/100
710/1634 [============>…] - ETA: 19:09 - loss: 13.8059Execution status: FAIL
2024-12-07 10:15:44,050 [TAO Toolkit] [INFO] nvidia_tao_cli.components.docker_handler.docker_handler 363: Stopping container.
I would appreciate any insights into what might be causing this issue.
Actually WSL is not mentioned in the TAO user guide and not sure to run smoothly for every network. For your case, I am afraid it is due to OOM. You can set lower input size and retry.
ok,thanks
