The CUDA function "cudaEventRecord()" put a error
Could you tell me why the CUDA function “cudaEventRecord()” a error message “invalid resource handle” ?
In order to get timing information on echo GPU, I use the CUDA function “cudaEventRecord()”.
However I got a error message "FILE: test.cuf LINE: 72 Error: invalid resource handle ".
When I ran on one GPU, there was no problem.
However when I ran more than two GPUs, the CUDA function “cudaEventRecord()” put the error message.
I suppose it is not possible for me to pass variables with the attribute dimension to the CUDA function “cudaEventRecord()”.
Here is the test program.
#define CHECK(err) _CHECK(err,FILE,LINE)
module EventTest
use cudafor
implicit none
contains
subroutine _CHECK(err, filename, linenum)
integer(kind=4),intent(in) :: err
character(kind=1,len=*), optional :: filename
integer(kind=4), optional :: linenum
if( err /= cudaSuccess ) then
if(present(filename) .and. present(linenum)) then
write(,‘(“FILE:”,1x,a,1x,“LINE:”,1x,i10,1x,“Error:”,1x,a)’),filename,linenum,cudaGetErrorString(err)
else
write(
,‘(“Error:”,1x,a)’)cudaGetErrorString(err)
end if
stop
end if
end subroutine _CHECK
attributes(global) subroutine gpu_kernel(n,d_a)
integer,intent(in),value :: n
integer,dimension(n),intent(out),device :: d_a
integer :: idx
idx = threadIdx%x + (blockIdx%x - 1) * blockDim%x
if( ( idx < 1 ) .or. ( idx > n ) ) return
d_a(idx) = idx
end subroutine gpu_kernel
end module EventTest
program EventTestMain
use EventTest
integer,parameter :: n = 10000000
integer,parameter :: tbx = 128
integer :: devnum
integer :: devId
integer,dimension(:,:),pointer,device :: d_a
type(dim3) :: grid,tblock
type(cudaEvent),dimension(:),pointer :: startEvent, stopEvent
tblock = dim3(tbx,1,1)
grid = dim3( (n + tblock%x - 1) / tblock%x ,1,1)
! Number of GPUs
call CHECK ( cudaGetDeviceCount(devnum) )
allocate( d_a(n,0:devnum -1) )
allocate( startEvent(0:devnum -1) )
allocate( stopEvent(0:devnum -1) )
! Create Events
do devId = 0,devnum - 1
call CHECK( cudaEventCreate(startEvent(devId)) )
call CHECK( cudaEventCreate(stopEvent(devId)) )
end do
! Start Event
call CHECK( cudaDeviceSynchronize() )
call CHECK( cudaEventRecord(startEvent(devId),0) )
call CHECK( cudaSetDevice(devId) )
call gpu_kernel<<<grid,tblock>>>(n,d_a(:,devId))
! Stop Event
call CHECK( cudaEventRecord(stopEvent(devId),0) )
end do
! Timing information
call CHECK( cudaEventElapsedTime(time,startEvent(devId),stopEvent(devId)) )
write(*,‘(“Device Id:”,3x,i2,3x,“Elapsed Time:”,3x,f10.8)’)devId,time
end do
! Destroy Events
call CHECK( cudaEventDestroy(startEvent(devId)) )
call CHECK( cudaEventDestroy(stopEvent(devId)) )
end do
deallocate(startEvent)
deallocate(stopEvent)
deallocate(d_a)
end program EventTestMain
The problem here is that you’re not setting the device number before creating the events, hence both are being created on the default device. Hence when you access the event on the wrong device you get the error.
You’re also going to have issues with the “d_a” array. When you allocate the array, all the data will be created on the default device. The second dimension is not going to implicitly create part of the array on one device and part on the other. Instead, you need to create an array of a type on the host where the data member is a device array.
#define CHECK(err) _CHECK(err,__FILE__,__LINE__)
 module EventTest
 use cudafor
 implicit none
 contains
 write(*,'("FILE:",1x,a,1x,"LINE:",1x,i10,1x,"Error:",1x,a)'),filename,linenum,cudaGetErrorString(err)
 else
 write(*,'("Error:",1x,a)')cudaGetErrorString(err)
 end if
 stop
 end if
 integer :: idx
 d_a(idx) = idx
 use EventTest
 integer :: devnum
 integer :: devId
 type devarray
   integer,dimension(:),allocatable :: h_a
   integer,dimension(:),allocatable,device :: d_a
 end type devarray
 type(devarray), allocatable, dimension(:) :: a
 ! Number of GPUs
 allocate( a(0:devnum -1) )
 ! Create Events
 allocate(a(devId)%d_a(n))
 allocate(a(devId)%h_a(n))
 end do
 ! Start Event
 call gpu_kernel<<<grid,tblock>>>(n,a(devId)%d_a(:))
 a(devId)%h_a =  a(devId)%d_a
 print *, a(devId)%h_a(1:10)
 ! Stop Event
 end do
 write(*,'("Device Id:",3x,i2,3x,"Elapsed Time:",3x,f15.10)')devId,time
 end do
 ! Destroy Events
 end do
   deallocate(a(devId)%d_a)
   deallocate(a(devId)%h_a)
 enddo
 deallocate(a)
% pgfortran -Mcuda=cc35 -fast test.CUF
% a.out
            1            2            3            4            5            6
            7            8            9           10
            1            2            3            4            5            6
            7            8            9           10
            1            2            3            4            5            6
            7            8            9           10
            1            2            3            4            5            6
            7            8            9           10
Device Id:    0   Elapsed Time:     17.8769283295
Device Id:    1   Elapsed Time:     16.3900794983
Device Id:    2   Elapsed Time:     17.1248321533
Device Id:    3   Elapsed Time:     17.7438392639
Hope this helps,
Mat
Dear Mat-san,
Thank you for your advice. It make sense.
Thing about this a bit more, you might want to do something like the following so the kernels are running on each device at the same time. Currently, they are running sequentially.
  ! Start Event
 end do
  ! Start Event
  ! Stop Event
  end do
