Description
At present, when I am accelerating my own model with tensorrt, I have encountered a problem, that is, when I use different data types to feed the network for inference, the inference speed and inference results of the network will be different, as follows:
the code as follows:
The impact of different data types on inference time:
different predictions:
the float32 (input data type)predict results:
the uint8(input data type) predict results:
In addition, I also compared the results of uint8 and float32 input data, as follows:
I found that the values are the same except for the data type!
Currently, my two prediction results use the same tensorrt-accelerated model based on the fp16 acceleration method.
Looking forward to your help, thanks a lot!
Environment
TensorRT Version: 8.2
GPU Type: 3060ti
Nvidia Driver Version: 510
CUDA Version: 11.3
CUDNN Version: 8.2
Operating System + Version: ubunt20.04
Python Version (if applicable): 3.7.9
TensorFlow Version (if applicable): no use
PyTorch Version (if applicable): 1.10.1+cu113
Baremetal or Container (if container which image + tag):
