Dear all,
when I was running the cv2
with JetPack v4.4
on AGX, I got this error.
Gtk-ERROR **: 12:02:01.858: GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported
When I used this command:
pkg-config --libs gtk+-2.0
or pkg-config --libs gtk+-3.0
Output :
Package gtk+-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gtk+-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'gtk+-2.0' found
or
Package gtk+-3.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `gtk+-3.0.pc'
No package 'gtk+-3.0' found
I searched it. (Reference: pkg-config not finding gtk±3.0)
Command:
dpkg -l libgtk* | grep -e '^i' | grep -e 'libgtk-*[0-9]'
Output:
zsh: no matches found: libgtk*
Hence, I installed these libraries.
sudo apt-get install libwebkit2gtk-4.0-dev libgtk-3-dev libglib2.0-dev autogen autoconf libtool m4 automake pkg-config libtool intltool-debian
So I can find something…
Command:
Outuput:
-lgtk-3 -lgdk-3 -lpangocairo-1.0 -lpango-1.0 -latk-1.0 -lcairo-gobject -lcairo -lgdk_pixbuf-2.0 -lgio-2.0 -lgobject-2.0 -lglib-2.0
But I still get the same error. Cannot fix it.
Someone suggested that we can downgrade the opencv version to fix it.
The JetPack v4.4 default opencv version is 4.1.1
However, this opencv version can work on my pc (linux).
As I have another Jetson device (TX2) which was installed by 3.2.0
with JetPack v4.3
and it can work my script without any error.
So I wonder is it better to downgrade the opencv version on AGX device? or any other method to fix this bug?
Thank you.
Environment
TensorRT Version : 7.1 with Jetpack 4.4
GPU Type : (Jetson AGX Xavier)
Nvidia Driver Version : Jetpack 4.4
CUDA Version : 10.2
CUDNN Version : 8.0
Operating System + Version : Jetpack 4.4 (Costimized Ubuntu 18.04)
Python Version (if applicable) : 3.6
PyTorch Version (if applicable) : 1.5.0
cmake version : 3.13.0
opencv version : 4.1.1
