The language be kept consistent
Please provide the following information when creating a topic:
  • Hardware Platform (GPU model and numbers)
    8 * H20
  • System Memory
    1TB
  • Ubuntu Version
    rhel9.4
    gpu operator→25.3.0, driver→570.124.06
    new requirements
The prompt uses Chinese, but the generated summary is a mix of Chinese and English, which is not user-friendly. It is recommended that the language be kept consistent.
  • Are you using llama-70b model or llama-8b model? If multilingual support is required, please use the llama-70b model.
  • You should add “have to summarize in Chinese only” at the last of each prompt.
  • You shoud add “have to answer the question in Chinese only” at the last of each chat question.
