Hello! I using code from book CUDA-By-Example-master (chapter 4):
#include "../common/book.h"
#include "../common/cpu_bitmap.h"
#define DIM 1000
struct cuComplex {
float r;
float i;
__device__ cuComplex(float a, float b) : r(a), i(b) {}
__device__ float magnitude2(void) {
return r * r + i * i;
__device__ cuComplex operator*(const cuComplex& a) {
return cuComplex(r*a.r - i * a.i, i*a.r + r * a.i);
__device__ cuComplex operator+(const cuComplex& a) {
return cuComplex(r + a.r, i + a.i);
__device__ int julia(int x, int y) {
const float scale = 1.5;
float jx = scale * (float)(DIM / 2 - x) / (DIM / 2);
float jy = scale * (float)(DIM / 2 - y) / (DIM / 2);
cuComplex c(-0.8, 0.156);
cuComplex a(jx, jy);
int i = 0;
for (i = 0; i < 200; i++) {
a = a * a + c;
if (a.magnitude2() > 1000)
return 0;
return 1;
__global__ void kernel(unsigned char *ptr) {
// map from blockIdx to pixel position
int x = blockIdx.x;
int y = blockIdx.y;
int offset = x + y * gridDim.x;
// now calculate the value at that position
int juliaValue = julia(x, y);
ptr[offset * 4 + 0] = 255 * juliaValue;
ptr[offset * 4 + 1] = 0;
ptr[offset * 4 + 2] = 0;
ptr[offset * 4 + 3] = 255;
// globals needed by the update routine
struct DataBlock {
unsigned char *dev_bitmap;
int main(void) {
DataBlock data;
CPUBitmap bitmap(DIM, DIM, &data);
HANDLE_ERROR(cudaMalloc((void**)&dev_bitmap, bitmap.image_size()));
data.dev_bitmap = dev_bitmap;
dim3 grid(DIM, DIM);
kernel <<<grid, 1 >>> (dev_bitmap);
HANDLE_ERROR(cudaMemcpy(bitmap.get_ptr(), dev_bitmap,
bitmap.image_size(),
cudaMemcpyDeviceToHost)); // line 87
HANDLE_ERROR(cudaFree(dev_bitmap));
bitmap.display_and_exit();
But i am getting error in console: the launch timed out and was terminated in D:/jul_cpu/jul_cpu/kernel.cu at line 87.
What I should do?
