I have a machine with four V100-PCIe GPUs, and I want to understand the specific PCIe connectivity topology between them. The results obtained using nvidia-smi topo -m
are as follows:
GPU0 GPU1 GPU2 GPU3 NIC0 NIC1 CPU Affinity NUMA Affinity GPU NUMA ID
GPU0 X PIX SYS SYS PIX PIX 0-9,20-29 0 N/A
GPU1 PIX X SYS SYS PIX PIX 0-9,20-29 0 N/A
GPU2 SYS SYS X PIX SYS SYS 0-9,20-29 0 N/A
GPU3 SYS SYS PIX X SYS SYS 0-9,20-29 0 N/A
NIC0 PIX PIX SYS SYS X PIX
NIC1 PIX PIX SYS SYS PIX X
Legend:
X = Self
SYS = Connection traversing PCIe as well as the SMP interconnect between NUMA nodes (e.g., QPI/UPI)
NODE = Connection traversing PCIe as well as the interconnect between PCIe Host Bridges within a NUMA node
PHB = Connection traversing PCIe as well as a PCIe Host Bridge (typically the CPU)
PXB = Connection traversing multiple PCIe bridges (without traversing the PCIe Host Bridge)
PIX = Connection traversing at most a single PCIe bridge
NV# = Connection traversing a bonded set of # NVLinks
NIC Legend:
NIC0: mlx5_0
NIC1: mlx5_1
The SYS
in above result indicates that GPU0 and GPU1 are in the same NUMA node, while GPU1 and GPU2 are in another NUMA node. But the NUMA Affinity
field indicates all GPUs all in NUMA node 0.
The results obtained through lspci -tv
are as follows (I only kept the relevant part related to GPUs):"
+-[0000:3a]-+-00.0-[3b-41]----00.0-[3c-41]--+-04.0-[3d]----00.0 NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB]
| | +-08.0-[3e]--
| | +-0c.0-[3f]--
| | +-10.0-[40]----00.0 Xilinx Corporation Device d004
| | \-14.0-[41]----00.0 NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB]
+-[0000:17]-+-00.0-[18-1e]----00.0-[19-1e]--+-04.0-[1a]--+-00.0 Mellanox Technologies MT27800 Family [ConnectX-5]
| | | \-00.1 Mellanox Technologies MT27800 Family [ConnectX-5]
| | +-08.0-[1b]----00.0 NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB]
| | +-0c.0-[1c]--
| | +-10.0-[1d]--
| | \-14.0-[1e]----00.0 NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB]
This indicates that two GPUs are under bus3a, while the other two are under bus17.
Then I used dmesg | grep NUMA
to view the information about NUMA nodes, and the result is as follows:
[ 2.496394] pci_bus 0000:00: on NUMA node 0
[ 2.527717] pci_bus 0000:17: on NUMA node 0
[ 2.547933] pci_bus 0000:3a: on NUMA node 0
[ 2.554105] pci_bus 0000:5d: on NUMA node 0
[ 2.558604] pci_bus 0000:80: on NUMA node 1
[ 2.567157] pci_bus 0000:85: on NUMA node 1
[ 2.574463] pci_bus 0000:ae: on NUMA node 1
[ 2.579994] pci_bus 0000:d7: on NUMA node 1
This result indicates that bus3a and bus17 are in the same NUMA node, meaning that all four GPUs are in the same node. This contradicts the SYS
obtained from nvidia-smi topo -m
but agree with “NUMA Affinity” field.
I think the SYS
in nvidia-smi result should be NODE
. Is my understanding of the SYS
legend incorrect?
