The Throughput is too slow in Nvidia jetson AGX ORin DLA
detail log
dla.log (320.5 KB)
gpu.log (3.5 MB)
env
(base) orin@orin-root:~/workspace/DeepStream-Yolo$ jetson_release
Software part of jetson-stats 4.2.4 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin Developer Kit - Jetpack 5.1.2 [L4T 35.4.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
 - P-Number: p3701-0005
 - Module: NVIDIA Jetson AGX Orin (64GB ram)
Platform:
 - Distribution: Ubuntu 20.04 focal
 - Release: 5.10.120-tegra
jtop:
 - Version: 4.2.4
 - Service: Active
Libraries:
 - CUDA: 11.4.315
 - cuDNN: 8.6.0.166
 - TensorRT: 5.1.2
 - VPI: 2.3.9
 - Vulkan: 1.3.204
 - OpenCV: 4.6.0 - with CUDA: YES
Based on your log, the inference only runs on DLA0.
$ trtexec ... --useDLACore=0 ...
Please create another console and run the trtexec with --useDLACore=1 to deploy the inference on the other DLA core concurrently.
Only through simple calculations
two dla core - > 60 x2 → 120 qps
gpu → 210 qps
Is It reasonable?
You can compare to our benchmark results below:
On Orin 64GB with MAXN mode:
GPU sparse INT8 peak DL performance: 171 TOPs
2x DLA sparse INT8 peak performance: 105 TOPs
