Throwing error "No Error"
Edit:
Found the answer. In my code, I had a semi-colon after the if-conditional, which made the following block execute regardless of the truth value.
I’m new.
I’m following the tutorial over at Dr. Dobbs that can be found here:
http://www.ddj.com/hpc-high-performance-computing/207603131
When it comes to this block, the “if” conditional is getting executed:
[codebox]void checkCUDAError(const char *msg)
cudaError_t err = cudaGetLastError();
if( cudaSuccess != err)
    fprintf(stderr, "Cuda error: %s: %s.\n", msg,
                              cudaGetErrorString( err) );
    exit(EXIT_FAILURE);
}[/codebox]
When I run the program, the output is:
“Cuda error: kernel invocation: no error.”
What kind of error is “no error”? Why is it not equal to cudaSuccess?
