We are pleased to announce the release of Thrust v1.2, an open-source template library for developing CUDA applications. Modeled after the C++ Standard Template Library (STL), Thrust brings a familiar abstraction layer to the realm of GPU computing.
Version 1.2 adds several new features, including:
[*]support for multicore CPUs via OpenMP
[*]support for CUDA 3.0 and new GPUs based on the Fermi architecture
[*]support for the Ocelot virtual machine
[*]pseudo random number generation
[*]and more!
As the following code example shows, Thrust programs are concise and readable.
#include <thrust/device_vector.h>
#include <thrust/iterator/constant_iterator.h>
#include <thrust/reduce.h>
#include <string>
// This example computes a run-length code for an array
// of characters using a key-value (or segmented) reduction
int main(void)
// input data on the host
std::string data = "aaabbbbbcddeeeeeeeeeff";
size_t N = data.size();
// copy input data to the device
thrust::device_vector<char> input(data.begin(), data.end());
// allocate storage for output data and run lengths
thrust::device_vector<char> output(N);
thrust::device_vector<int> lengths(N);
// compute run lengths
size_t num_runs =
thrust::reduce_by_key(input.begin(), input.end(), // input key sequence
thrust::constant_iterator<int>(1), // input value sequence
output.begin(), // output key sequence
lengths.begin() // output value sequence
).first - output.begin(); // compute the output size
// output is now [a,b,c,d,e,f]
// lengths is now [3,5,1,2,9,2]
return 0;
Get started with Thrust today! First download Thrust v1.2 and then follow the online quick-start guide. Refer to the online documentation for a complete list of features. Many concrete examples and a set of introductory slides are also available.
Thrust is open-source software distributed under the OSI-approved Apache License v2.0.
Acknowledgments
[*]Thanks to Gregory Diamos for contributing a CUDA implementation of set_intersection
[*]Thanks to Ryuta Suzuki & Gregory Diamos for rigorously testing Thrust’s unit tests and examples against Ocelot
[*]Thanks to Tom Bradley for contributing an implementation of normal_distribution
[*]Thanks to Joseph Rhoads for contributing the example summary_statistics
