Good morning,
I try to explain the question as clearly as possible.
I need to calculate the sum of a row of a matrix with the following parameters:
- N rows (with N= blocks*threads)
- X columns
The result has to be an array of N elements containing the summations of each row.
The code works (I enclose the project), but my perplexity is another: the execution times.
To get more reliable results, I run 10,000 cycles and calculate the average of the execution times but the results don’t convince me very much.
How is it possible that there is a difference of almost 10% more between one-dim and multi results?
The calls I make to the kernel are in both one-dim and multi, and the times turn out to be these:
ONE-DIM: 8 - 8 MULTI: 4x2 - 4x2
Time ONE-DIM: 0.117128 (ms) Time Multi: 0.094554 (ms)
ONE-DIM: 16 - 16 MULTI: 4x4 - 4x4
Time ONE-DIM: 0.206620 (ms) Time Multi: 0.193303 (ms)
ONE-DIM: 32 - 16 MULTI: 8x4 - 4x4
Time ONE-DIM: 0.220927 (ms) Time Multi: 0.204934 (ms)
ONE-DIM: 16 - 32 MULTI: 4x4 - 8x4
Time ONE-DIM: 0.300701 (ms) Time Multi: 0.274282 (ms)
ONE-DIM: 16 - 32 MULTI: 4x4 - 4x8
Time ONE-DIM: 0.300746 (ms) Time Multi: 0.274242 (ms)
ONE-DIM: 64 - 32 MULTI: 8x8 - 8x4
Time ONE-DIM: 0.562803 (ms) Time Multi: 0.453662 (ms)
ONE-DIM: 64 - 64 MULTI: 8x8 - 8x8
Time ONE-DIM: 1.346480 (ms) Time Multi: 0.874964 (ms)
I understand that there must be a difference between one-dim and multi, but even in the last output the difference is 0.5 ms more, I don’t understand.
// Include
#include <stdio.h>
#include <assert.h>
#define N_BLOCK_ONE_DIM 32
#define N_THREAD_ONE_DIM 32
#define N_BLOCK_MULTI_X 4
#define N_BLOCK_MULTI_Y 8
#define N_THREAD_MULTI_X 4
#define N_THREAD_MULTI_Y 8
#define COLUMNS 10000
#define CICLI 10000
#define verbose 0
int b_one_dim[] = {8, 16, 32, 16, 16, 64, 64};
int t_one_dim[] = {8, 16, 16, 32, 32, 32, 64};
int b_multi_x[] = {4, 4, 8, 4, 4, 8, 8};
int b_multi_y[] = {2, 4, 4, 4, 4, 8, 8};
int t_multi_x[] = {4, 4, 4, 8, 4, 8, 8};
int t_multi_y[] = {2, 4, 4, 4, 8, 4, 8};
PROBLEMA
Calcolare la sommatoria di una riga di una matrice con i
seguenti parametri
- N righe, con N = n°blocchi * n°thread
- X colonne
il risultato è un array di N elementi contenente le sommatorie di ogni riga
//struttura della matrice da elaborare
typedef struct {
int width;
int height;
float* elements;
} Matrix;
//struttura array delle sommatorie
typedef struct {
int length;
float* elements;
} Sums;
//Kernels
__global__ void MatSumOneDimKernel(const Matrix, Sums);
__global__ void MatSumMultiKernel(const Matrix, Sums);
//Funzione di chiamata per i Kernel
void MatSum(const Matrix A, Sums S_one_dim, Sums S_multi, int index)
//array delle medie dei dati
float mediat_one_dim = 0.0;
float mediat_multi = 0.0;
Matrix d_A;
d_A.width = A.width; d_A.height = A.height;
size_t size = A.width * A.height * sizeof(float);
cudaMalloc((void**) &d_A.elements, size);
cudaMemcpy(d_A.elements, A.elements, size, cudaMemcpyHostToDevice);
Sums d_S;
d_S.length = S_one_dim.length;
size = S_one_dim.length * sizeof(float);
cudaMalloc((void**) &d_S.elements, size);
// WARMUP
//MatSumOneDimKernel<<<b_one_dim[index], t_one_dim[index]>>>(d_A, d_S);
//timer
cudaEvent_t start;
cudaEvent_t stop;
float msecTotal;
//-------ONE-DIM------------------
for(int j = 0; j<CICLI; ++j)
cudaEventCreate(&start);
cudaEventRecord(start, NULL);
// Invoke kernel one-dim
// stop and destroy timer
cudaEventCreate(&stop);
cudaEventRecord(stop, NULL);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&msecTotal, start, stop);
//printf( "\n\nTime ONE-DIM %f (ms)\n\n", msecTotal);
mediat_one_dim += msecTotal;
if(verbose)
cudaMemcpy(S_one_dim.elements, d_S.elements, size, cudaMemcpyDeviceToHost);
//------BIDIMENSIONALE-------------------
dim3 dimGrid(b_multi_x[index],b_multi_y[index]);
dim3 dimBlock(t_multi_x[index], t_multi_y[index]);
// Invoke kernel multi
MatSumMultiKernel<<<dimGrid, dimBlock>>>(d_A, d_S);
//printf( "\n\nTime Multi: %f (ms)\n\n", msecTotal);
mediat_multi += msecTotal;
if(verbose)
cudaMemcpy(S_multi.elements, d_S.elements, size, cudaMemcpyDeviceToHost);
cudaFree(d_A.elements);
cudaFree(d_S.elements);
printf( "\n\nONE-DIM: %d - %d\t\tMULTI: %dx%d - %dx%d\n\n", b_one_dim[index], t_one_dim[index], b_multi_x[index], b_multi_y[index],
printf( "\n\nTime One-dim: %f (ms)\t\tTime Multi: %f (ms)\n\n", mediat_one_dim/(float)CICLI, mediat_multi/(float)CICLI);
//Kernel ONE-DIM
__global__ void MatSumOneDimKernel(const Matrix A, Sums S)
//ogni thread calcola la sommatoria di una riga di A
float Svalue= 0;
int index = blockIdx.x * blockDim.x + threadIdx.x;
int row = (blockIdx.x * blockDim.x + threadIdx.x) * COLUMNS;
for (int i=0; i<COLUMNS; i++)
Svalue += A.elements[row + i];
S.elements[index] = Svalue;
//Kernel BIDIMENSIONALE
__global__ void MatSumMultiKernel(const Matrix A, Sums S)
float Svalue= 0;
int index = (blockIdx.x + blockIdx.y * gridDim.x) * (blockDim.x + blockDim.y) + threadIdx.x + threadIdx.y * blockDim.x;
int row = ((blockIdx.x + blockIdx.y * gridDim.x) * (blockDim.x + blockDim.y) + threadIdx.x + threadIdx.y * blockDim.x) * COLUMNS;
//Main
int main(int argc, char** argv)
for(int index = 0; index<7; ++index)
//Matrice
Matrix h_A;
h_A.width = COLUMNS; h_A.height = b_one_dim[index]*t_one_dim[index];
size_t size = h_A.width*h_A.height*sizeof(float);
h_A.elements = (float*)malloc(size);
//Vettore sommatorie per kernel ONE-DIM
Sums h_S_one_dim;
h_S_one_dim.length = b_one_dim[index]*t_one_dim[index];
size = b_one_dim[index]*t_one_dim[index]*sizeof(float);
h_S_one_dim.elements = (float*)malloc(size);
//Vettore sommatorie per kernel BIDIMENSIONALE
Sums h_S_multi;
h_S_multi.length = b_one_dim[index]*t_one_dim[index];
h_S_multi.elements = (float*)malloc(size);
//Inizializzazione della matrice
int i = 0;
for(int y=0; y<h_A.height; y++)
for(int x=0; x<h_A.width; x++) {
h_A.elements[y*h_A.width+x] = i;
i++;
//Stampa di A
if(verbose){
printf("\nh_A\n");
for(int y=0; y<h_A.height; y++){
printf("\n");
printf("%f ", h_A.elements[y*h_A.width+x]);
//Inizializzazione dei vettori
for(int i=0; i<h_S_one_dim.length; i++)
h_S_one_dim.elements[i] = 0.0;
h_S_multi.elements[i] = 0.0;
MatSum(h_A, h_S_one_dim, h_S_multi, index);
//Stampa dei Vettori
if(verbose)
printf("\n\n\nh_S_one_dim");
for(int i = 0; i< h_S_one_dim.length; i++)
printf("\n");
printf("%f ", h_S_one_dim.elements[i]);
printf("\n\n\nh_S_multi");
for(int i = 0; i< h_S_multi.length; i++)
printf("\n");
printf("%f ", h_S_multi.elements[i]);
//checker
if(h_S_multi.elements[i]-h_S_one_dim.elements[i] != 0.0)
printf("\n\n\nERRORE DATI DISCORDANTI");
