I want to know, whether, constant bitrate rate (CBR) mode is supported in TK Hardware encoder (OMX.Nvidia.h264.encoder).
If so how can I set the bitrate mode to CBR. Below is the output GST inspect.
ubuntu@tegra-ubuntu:~$ gst-inspect-0.10 nv_omx_h264enc
Factory Details:
Long name: OpenMAX IL H.264/AVC video encoder
Class: Codec/Encoder/Video
Description: Encodes video in H.264/AVC format with OpenMAX IL
Author(s): Felipe Contreras
Rank: primary + 10 (266)
Plugin Details:
Description: OpenMAX IL
Filename: /usr/lib/arm-linux-gnueabihf/gstreamer-0.10/libgstomx.so
Version: 0.10.1
License: LGPL
Source module: gst-openmax
Binary package: gst-openmax source release
Origin URL: Unknown package origin
GObject
+----GstObject
+----GstElement
+----GstOmxBaseFilter
+----GstOmxBaseVideoEnc
+----GstOmxH264Enc
Implemented Interfaces:
GstImplementsInterface
GstOmx
Pad Templates:
SINK template: 'sink'
Availability: Always
Capabilities:
video/x-raw-yuv
width: [ 16, 4096 ]
height: [ 16, 4096 ]
framerate: [ 0/1, 2147483647/1 ]
format: { I420, NV12 }
video/x-nv-yuv
width: [ 16, 4096 ]
video/x-nvrm-yuv
width: [ 16, 4096 ]
SRC template: 'src'
Capabilities:
video/x-h264
width: [ 176, 2147483647 ]
height: [ 144, 2147483647 ]
stream-format: { byte-stream, avc }
alignment: { au }
Element Flags:
no flags set
Element Implementation:
Has change_state() function: 0xb6066694
Has custom save_thyself() function: gst_element_save_thyself
Has custom restore_thyself() function: gst_element_restore_thyself
Element has no clocking capabilities.
Element has no indexing capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Implementation:
Has custom eventfunc(): gst_pad_event_default
Has custom queryfunc(): gst_pad_query_default
Has custom iterintlinkfunc(): gst_pad_iterate_internal_links_default
Has getcapsfunc(): gst_pad_get_fixed_caps_func
Has acceptcapsfunc(): gst_pad_acceptcaps_default
Pad Template: 'src'
SINK: 'sink'
Implementation:
Has chainfunc(): 0xb606697c
Has custom eventfunc(): 0xb6065d50
Has setcapsfunc(): 0xb608ed24
Pad Template: 'sink'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "omxh264enc0"
component-name : Name of the OpenMAX IL component to use
flags: readable
String. Default: "OMX.Nvidia.h264.encoder"
component-role : Role of the OpenMAX IL component
flags: readable
String. Default: null
library-name : Name of the OpenMAX IL implementation library to use
flags: readable
String. Default: "libnvomx.so"
use-timestamps : Whether or not to use timestamps
Boolean. Default: true
input-buffers : The number of OMX input buffers
Unsigned Integer. Range: 1 - 10 Default: 6
output-buffers : The number of OMX output buffers
full-frame : Whether or not the data is full framed
bitrate : Encoding bit-rate
Unsigned Integer. Range: 0 - 4294967295 Default: 4000000
quality-level : Encoding quality-level
Unsigned Integer. Range: 0 - 2 Default: 2
rc-mode : Encoding rate control mode
Enum "GstOmxVideoEncRCModeType" Default: 2, "vbr2"
(0): cbr - GST_OMX_VIDENC_RCMODE_TYPE_CONSTANT
(1): vbr - GST_OMX_VIDENC_RCMODE_TYPE_VARIABLE
(2): vbr2 - GST_OMX_VIDENC_RCMODE_TYPE_VARIABLE2
iframeinterval : Encoding Intra Frame occurance frequency
Unsigned Integer. Range: 0 - 4294967295 Default: 60
qp-range : Qunatization range for P and I frame
temporal-tradeoff : Temporal Tradeoff value for encoder
Enum "GstOmxVideoEncTemporalTradeoffType" Default: 0, "30fps"
(0): 30fps - GST_OMX_VIDENC_FORCE_FRAMERATE_AS_FAST_AS_POSSIBLE
(1): 24fps - GST_OMX_VIDENC_FORCE_FRAMERATE_24
(2): 20fps - GST_OMX_VIDENC_FORCE_FRAMERATE_20
(3): 15fps - GST_OMX_VIDENC_FORCE_FRAMERATE_15
(4): 10fps - GST_OMX_VIDENC_FORCE_FRAMERATE_10
bit-packetization : Whether or not Packet size is based upon Number Of bits
Boolean. Default: false
insert-spsppsatidr : Whether or not insert SPS & PPS at every IDR
framerate : Frames per second
Integer. Range: 0 - 60 Default: 30
slice-header-spacing: Slice Header Spacing number of macroblocks/bits in one packet
Unsigned Long. Range: 0 - 4294967295 Default: 0
Element Actions:
"force-IDR" : void user_function (GstElement* object);
Is it " rc-mode" here means, bitrate mode? Though I set bitrate mode to GST_OMX_VIDENC_RCMODE_TYPE_CONSTANT, I am not getting constant bit rate from the encoder. I am getting variable bit rate only.
