TLT, classification, How to set the number of classes for training the custom dataset
I am trying to train with ImageNet 1k which has 1000 classes with resnet18 from NGC.
How can I change the number of output of it to 1000.
I got an error which the number of label is not matched.
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/training.py", line 789, in _standardize_user_data
    exception_prefix='target')
  File "/usr/local/lib/python3.6/dist-packages/keras/engine/training_utils.py", line 138, in standardize_input_data
    str(data_shape))
ValueError: Error when checking target: expected predictions to have shape (176,) but got array with shape (1000,)
printed network is like the below
block_4c_relu (Activation)      (None, 2048, 14, 14) 0           add_16[0][0]
avg_pool (AveragePooling2D)     (None, 2048, 1, 1)   0           block_4c_relu[0][0]
flatten (Flatten)               (None, 2048)         0           avg_pool[0][0]
predictions (Dense)             (None, 176)          360624      flatten[0][0]
command
$ tlt-train classification -e i1k_r18_train.cfg -r /workspace/test1/ -k 1103
i1k_r18_train.cfg
model_config {
  arch: "resnet"
  n_layers: 18
  use_bias: True
  use_batch_norm: True
  all_projections: True
  use_pooling: False
  freeze_bn: False
  freeze_blocks: 0
  freeze_blocks: 1
  input_image_size: "3,224,224"
eval_config {
  eval_dataset_path: "/dataset/ILSVRC2012/val"
  model_path: "/workspace/test1"
  top_k: 3
  batch_size: 256
  n_workers: 8
train_config {
  train_dataset_path: "/dataset/ILSVRC2012/train"
  pretrained_model_path: "/workspace/tlt_pretrained_classification_vresnet18/resnet_18.hdf5"
  optimizer: "sgd"
  batch_size_per_gpu: 64
  n_epochs: 3
  n_workers: 16
  # regularizer
  reg_config {
    type: "L2"
    scope: "Conv2D,Dense"
    weight_decay: 0.00005
  lr_config {
    scheduler: "soft_anneal"
    learning_rate: 0.005
    soft_start: 0.056
    annealing_points: "0.3, 0.6, 0.8"
    annealing_divider: 10
Can you make sure your dataset contains 1000 folder?
According to the log of tlt-train, there are 1000 classes in the directory.
2021-01-18 21:25:15,116 [INFO] iva.makenet.scripts.train: Loading experiment spec at i1k_r18_train.cfg.
Found 1281167 images belonging to 1000 classes.
2021-01-18 21:26:56,969 [INFO] iva.makenet.scripts.train: Processing dataset (train): /dataset/ILSVRC2012/train
Found 50000 images belonging to 1000 classes.
2021-01-18 21:27:00,119 [INFO] iva.makenet.scripts.train: Processing dataset (validation): /dataset/ILSVRC2012/val
Please check your dataset again.
For example, if your dataset contains 256x256x3 image, the log is similar to below.
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 256, 256) 0
conv1 (Conv2D) (None, 64, 128, 128) 9408 input_1[0][0]
bn_conv1 (BatchNormalization) (None, 64, 128, 128) 256 conv1[0][0]
activation_1 (Activation) (None, 64, 128, 128) 0 bn_conv1[0][0]
block_1a_conv_1 (Conv2D) (None, 64, 64, 64) 36864 activation_1[0][0]
activation_17 (Activation) (None, 512, 16, 16) 0 add_8[0][0]
avg_pool (AveragePooling2D) (None, 512, 1, 1) 0 activation_17[0][0]
flatten (Flatten) (None, 512) 0 avg_pool[0][0]
predictions (Dense) (None, 1000) 513000 flatten[0][0]
Total params: 12,055,464
Trainable params: 12,043,816
Non-trainable params: 11,648
The number of classes depends on your training folders quantity.
Please remove pretrained_model_path: "/workspace/tlt_pretrained_classification_vresnet18/resnet_18.hdf5" in your spec.
