this is my latest config file for the secondary model:
config.txt (793 Bytes)
Sorry what do you mean by avi file? I can convert the mp4 video of inference with tracker bboxes to avi? Or did you mean something else?
See Issue with image classification tutorial and testing with deepstream-app - #24 by Morganh
gst-launch-1.0 multifilesrc location=“/tmp/%d.jpg” caps=“image/jpeg,framerate=30/1” ! jpegdec ! x264enc ! avimux ! filesink location=“out.avi”
The avi file is better than mp4 file for inference.
More, in other topic mentioned above, the end user can run inference well with TLT classification model. So, please refer to the config file https://forums.developer.nvidia.com/uploads/short-url/rk4x7xqir6N1nl3QpfxBcTTE6FA.txt in Issue with image classification tutorial and testing with deepstream-app - #21 by Morganh to narrow down.
For example, process-mode=1
etc.
sorry can you describe the process to make the avi file? I can run the command you sent but do I need a folder of images (cropouts)?
Yes, for below way, it will generate avi file from jpg files.
ok I will try this. My cropouts are all different sizes though- am I supposed to resize and pad them to the same size to make the .avi? If so how? bilinear interpolation and then pad bottom right?
You can generate jpg files via ffmpeg.
$ ffmpeg -i xxx.mp4 folder/%d.jpg
It is not needed to resize/pad.
what is this .avi file for? I already have a video to run inference on. I thought the idea was to make an .avi video consisting of cropouts so that I can run classification as a primary model?
Also- after primary inference the cropouts that are sent to the secondary model- what are they supposed to look like? Resized and padded bottom right?
If you already have avi file, please directly use it. I thought you have mp4 file only.
Can you follow Issue with image classification tutorial and testing with deepstream-app - #21 by Morganh to run inference with only one GIE. In this case, there is not 2nd gie.
hello, I ran the classification resnet18 tlt on the avi file (as the only GIE) and I get bad performance. What do you think could be the issue?
Also what are the processing steps between the primary and secondary GIE normally? Can you describe what happens with the bbox cropouts please?
Firstly, please make sure tlt classification inference
can run well. Please double check, and try to run more test images. If it is good, that means your tlt model can run inference well against the test image.
Then you can export this tlt model to etlt model, and run inference with this etlt model in deepstream. As we synced above, pay attention to the config file. You can just use primary GIE only. It will detect the whole test image (process-mode=1) . In this case, it did not crop bboxes.
when I try to run the .etlt model I get this error:
Linking elements in the Pipeline
linking recording pipeline
Opening in BLOCKING MODE
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvdcf.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvDCF][Warning] minTrackingConfidenceDuringInactive
is deprecated
[NvDCF] Initialized
0:00:01.951649466 21660 0x558f83a950 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
ERROR: Uff input blob name is empty
ERROR: Failed to create network using custom network creation function
ERROR: Failed to get cuda engine from custom library API
0:00:03.594655486 21660 0x558f83a950 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1736> [UID = 1]: build engine file failed
Segmentation fault (core dumped)
Can you share the full command, config files?
I can confirm that tlt classification inference runs well.
I managed to run deepstream with the .etlt model but the performance is not good on my test video. What could be the reason for this? My config is as follows:
[property]
gpu-id=0
net-scale-factor=1.0
model-color-format=1
offsets=103.939;116.779;123.68
num-detected-classes=13
output-blob-names=predictions/Softmax
#model-engine-file=path/to/engine
tlt-encoded-model=path/to/etlt
tlt-model-key=mykey
labelfile-path=path/to/labels
network-mode=2
process-mode=1
gie-unique-id=1
operate-on-gie-id=1
classifier-async-mode=0
classifier-threshold=0.1
interval=0
batch-size=16
scaling-filter=5
network-type=1
workspace-size=4096
infer-dims=3;144;256
maintain-aspect-ratio=0
enable-dla=1
use-dla-core=0
uff-input-blob-name=input_1
[class-attrs-all]
If possible, can you share your tlt, etlt model along with the avi video file, test images?
yes but I can’t post it here- can I email you?
also, I just noticed these warnings when I convert the .tlt to .etlt- do you think this could make a difference?
Matplotlib created a temporary config/cache directory at /tmp/matplotlib-1dbyo_5x because the default path (/.config/matplotlib) is not a writable directory; it is highly recommended to set the MPLCONFIGDIR environment variable to a writable directory, in particular to speed up the import of Matplotlib and to better support multiprocessing.
Using TensorFlow backend.
WARNING:tensorflow:Deprecation warnings have been disabled. Set TF_ENABLE_DEPRECATION_WARNINGS=1 to re-enable them.
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
DEBUG: convert reshape to flatten node
DEBUG [/usr/local/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py:96] Marking [‘predictions/Softmax’] as outputs
You can upload the files to a google drive folder, then I can request access to it.
More, please disable dla as below. This may result in accuracy drop.
enable-dla=0
