• Hardware (Nano)
• Deepstream(5.0.1)Due to client’s specific needs
• Network Type (Detectnet_v2 and Peoplenet)
• TLT Version (Due to client’s specific needs I’m using TLT2.0:Container Link: http://nvcr.io/nvidia/tlt-streamanalytics:v2.0_py3)
• Training spec file for smartphone ONLY
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/tlt-experiments/smartphone/data/tfrecords/kitti_trainval/*"
image_directory_path: "/workspace/tlt-experiments/smartphone/data/training"
image_extension: "jpg"
target_class_mapping {
key: "smartphone"
value: "smartphone"
validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 1248
output_image_height: 384
min_bbox_width: 0.5
min_bbox_height: 2.0
output_image_channel: 3
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "smartphone"
value {
clustering_config {
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 0.0500000007451
minimum_bounding_box_height: 20
model_config {
pretrained_model_file: "/workspace/tlt-experiments/smartphone/pretrained_resnet18/tlt_pretrained_detectnet_v2_vresnet18/resnet18.hdf5"
num_layers: 18
use_batch_norm: true
freeze_blocks:0
freeze_blocks:1
freeze_blocks:2
freeze_bn:false
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
training_precision {
backend_floatx: FLOAT32
arch: "resnet"
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
minimum_detection_ground_truth_overlap {
key: "smartphone"
value: 0.2
evaluation_box_config {
key: "smartphone"
value {
minimum_height: 20
maximum_height: 9999
minimum_width: 10
maximum_width: 9999
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: true
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 4
num_epochs: 300
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-06
max_learning_rate: 5e-04
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
checkpoint_interval: 10
bbox_rasterizer_config {
key: "smartphone"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.40000000596
cov_radius_y: 0.40000000596
bbox_min_radius: 1.0
deadzone_radius: 0.400000154972
• Training spec file for 2 classes
random_seed: 42
dataset_config {
data_sources {
key: "smartphone"
value: "smartphone"
key: "brita"
value: "brita"
validation_fold: 0
preprocessing {
min_bbox_width: 0.5
zoom_min: 1.0
zoom_max: 1.0
key: "smartphone"
value {
clustering_config {
key: "brita"
value {
clustering_config {
dbscan_eps: 0.15000000596
model_config {
num_layers: 18
freeze_blocks: 0
freeze_blocks: 1
freeze_blocks: 2
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
arch: "resnet"
evaluation_config {
key: "smartphone"
value: 0.2
key: "brita"
value: 0.2
key: "smartphone"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
key: "brita"
value {
minimum_height: 20
minimum_width: 10
maximum_width: 9999
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 10.0
target_classes {
class_weight: 1.0
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
weight_target: 1.0
training_config {
num_epochs: 300
learning_rate {
regularizer {
type: L1
optimizer {
adam {
cost_scaling {
increment: 0.005
decrement: 1.0
key: "smartphone"
value {
cov_center_x: 0.5
cov_center_y: 0.5
key: "brita"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 1.0
cov_radius_y: 1.0
Hi Everyone,
I’m trying to fine-tune DetectNet and Peoplenet to detect my smartphone with my own dataset(30 images) using DEEPSTREAM5.0 on my Jetson, but it seems to not be working. The training procedures I took were…
Train with the config file above(the one with only “smartphones”)
Prune
Retrain with epoch 100
INT8 Calibration
Export and Run on Jetson Nano
Oddly, When I added another class named “brita” with 25 images and did the same procedures, the output video was able to find my smartphone.
Does this mean that when using DetectNet or PeopleNet, you need at least 2 classes…?
