I installed CUDA enabled pytorch with:
pip3 install --no-cache https://developer.download.nvidia.com/compute/redist/jp/v60/pytorch/torch-2.4.0a0+07cecf4168.nv24.05.14710581-cp310-cp310-linux_aarch64.whl
and get at the end:
ERROR: pip’s dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
torchvision 0.19.0 requires torch==2.4.0, but you have torch 2.4.0a0+07cecf4168.nv24.5 which is incompatible.
Successfully installed torch-2.4.0a0+07cecf4168.nv24.5
When i ran my code i get:
File “/home/spacer/FlareRemoval/Flare7K/test_large.py”, line 3, in
import torchvision
File “/home/spacer/FlareRemoval/venv/lib/python3.10/site-packages/torchvision/init.py”, line 10, in
from torchvision import _meta_registrations, datasets, io, models, ops, transforms, utils # usort:skip
File “/home/spacer/FlareRemoval/venv/lib/python3.10/site-packages/torchvision/_meta_registrations.py”, line 163, in
@torch.library.register_fake(“torchvision::nms”)
AttributeError: module ‘torch.library’ has no attribute ‘register_fake’
It seems a compatibility issue according to the error i got on the pytorch installation but i dont know the corresponding torchvision version needed.
nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Aug_15_22:08:11_PDT_2023
Cuda compilation tools, release 12.2, V12.2.140
Build cuda_12.2.r12.2/compiler.33191640_0
cat /etc/nv_tegra_release
R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
KERNEL_VARIANT: oot
TARGET_USERSPACE_LIB_DIR=nvidia
TARGET_USERSPACE_LIB_DIR_PATH=usr/lib/aarch64-linux-gnu/nvidia
