I can get Llama’s model config by looking at its config.json, the config is just like following:
“_name_or_path”: “meta-llama/Llama-2-7b-hf”,
“architectures”: [
“LlamaForCausalLM”
“bos_token_id”: 1,
“eos_token_id”: 2,
“hidden_act”: “silu”,
“hidden_size”: 4096,
“initializer_range”: 0.02,
“intermediate_size”: 11008,
“max_position_embeddings”: 4096,
“model_type”: “llama”,
“num_attention_heads”: 32,
“num_hidden_layers”: 32,
“num_key_value_heads”: 32,
“pretraining_tp”: 1,
“rms_norm_eps”: 1e-05,
“rope_scaling”: null,
“tie_word_embeddings”: false,
“torch_dtype”: “float16”,
“transformers_version”: “4.31.0.dev0”,
“use_cache”: true,
“vocab_size”: 32000
However, how can I know the scale of Gemv calculation needed in this model’s inference?
