TensorRT Version : 8.0.1.6-1+cuda10.2 GPU Type : Jetson Xavier NX Developer Kit GPU Nvidia Driver Version : Cannot find it but it should be the one with the OS image of NX developer kit CUDA Version : 10.2 CUDNN Version : 8.2.1.32-1+cuda10.2 Operating System + Version : Ubuntu 18.04.5 LTS Python Version (if applicable) : 2.7.17 TensorFlow Version (if applicable) : N/A PyTorch Version (if applicable) : N/A Baremetal or Container (if container which image + tag) : Baremetal Jetson Xavier NX Developer Kit
Relevant Files
Refrence graphs of DeepStream SDK 6.0 are installed and many of them work fine following the instructions in README files.
Steps To Reproduce
Fresh install of Xavier NX with JetPack 4.6
Install DeepStream SDK 6
Install Graph Composer runtime for Jetson
Install Graph Composer reference apps
Install triton prerequisites for triton reference graph
Run the below:
cd /opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-triton
/opt/nvidia/graph-composer/execute_graph.sh deepstream-triton.yaml deepstream-triton.parameters.jetson.yaml -d target_triton_aarch64.yaml
The following is emitted to the terminal and the error messages are near the end of the snippet below:
Graphs: deepstream-triton.yaml,deepstream-triton.parameters.jetson.yaml
Target: target_triton_aarch64.yaml
Running deepstream-triton.yaml
[INFO] Writing manifest to /tmp/ds.deepstream-triton/manifest.yaml
2021-11-22 21:40:13.374 INFO gxf/gxe/gxe.cpp@98: Creating context
2021-11-22 21:40:13.413 INFO gxf/gxe/gxe.cpp@85: Loading app: '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-triton/deepstream-triton.yaml'
2021-11-22 21:40:13.413 INFO gxf/std/yaml_file_loader.cpp@59: Loading GXF entities from YAML file '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-triton/deepstream-triton.yaml'...
2021-11-22 21:40:13.424 INFO gxf/gxe/gxe.cpp@85: Loading app: '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-triton/deepstream-triton.parameters.jetson.yaml'
2021-11-22 21:40:13.424 INFO gxf/std/yaml_file_loader.cpp@59: Loading GXF entities from YAML file '/opt/nvidia/deepstream/deepstream-6.0/reference_graphs/deepstream-triton/deepstream-triton.parameters.jetson.yaml'...
2021-11-22 21:40:13.426 INFO gxf/gxe/gxe.cpp@153: Initializing...
2021-11-22 21:40:13.479 INFO extensions/nvdsbase/nvds_scheduler.cpp@266: This program is linked against GStreamer 1.14.5
2021-11-22 21:40:13.480 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux nv_ds_stream_mux337..7710
2021-11-22 21:40:13.480 INFO extensions/nvdstriton/nvinferserverbin.hpp@23: initialize: nvinferserverbin nv_ds_triton341..fba8
2021-11-22 21:40:13.481 INFO extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin nv_ds_osd345..e4e0
2021-11-22 21:40:13.481 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@24: initialize: nvvideorenderersinkbin nv_ds_video_renderer349..28d0
2021-11-22 21:40:13.481 INFO extensions/nvdsvisualization/nvtilerbin.hpp@23: initialize: nvtilerbin nv_ds_tiler352..fc88
2021-11-22 21:40:13.482 INFO gxf/gxe/gxe.cpp@160: Running...
2021-11-22 21:40:13.482 INFO extensions/nvdsbase/nvds_scheduler.cpp@117: Scheduling 6 elements and 1 components
2021-11-22 21:40:13.482 INFO extensions/nvdssource/multi_uri_src_bin.cpp@333: create_element: NvDsMultiSrcInput nv_ds_multi_src_input334..71d0
2021-11-22 21:40:13.482 INFO extensions/nvdssource/multi_uri_src_bin.cpp@379: bin_add: bin nv_ds_multi_src_input334..71d0
2021-11-22 21:40:13.483 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux nv_ds_stream_mux337..7710
2021-11-22 21:40:13.518 INFO extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux nv_ds_stream_mux337..7710
2021-11-22 21:40:13.519 INFO extensions/nvdstriton/nvinferserverbin.hpp@31: create_element: nvinferserverbin nv_ds_triton341..fba8
2021-11-22 21:40:13.614 INFO extensions/nvdstriton/nvinferserverbin.hpp@55: bin_add: nvinferserverbin nv_ds_triton341..fba8
(gxe:13418): GLib-GObject-CRITICAL **: 21:40:13.614: g_object_setv: assertion 'G_IS_OBJECT (object)' failed
2021-11-22 21:40:13.614 INFO extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin nv_ds_osd345..e4e0
2021-11-22 21:40:13.620 INFO extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin nv_ds_osd345..e4e0
2021-11-22 21:40:13.620 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@32: create_element: nvvideorenderersinkbin nv_ds_video_renderer349..28d0
2021-11-22 21:40:13.620 INFO extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@54: bin_add: nvvideorenderersinkbin nv_ds_video_renderer349..28d0
2021-11-22 21:40:13.621 INFO extensions/nvdsvisualization/nvtilerbin.hpp@31: create_element: nvtilerbin nv_ds_tiler352..fc88
2021-11-22 21:40:13.622 INFO extensions/nvdsvisualization/nvtilerbin.hpp@55: bin_add: nvtilerbin nv_ds_tiler352..fc88
2021-11-22 21:40:13.622 ERROR extensions/nvdsbase/nvds_io.cpp@23: Could not get static pad 'sink' from 'NvDsTriton..fe10/nv_ds_triton341..fba8'
2021-11-22 21:40:13.622 ERROR gxf/std/program.cpp@310: Couldn't run async. Deactivating...
2021-11-22 21:40:13.624 ERROR gxf/core/runtime.cpp@907: Graph run failed with error: GXF_FAILURE
2021-11-22 21:40:13.624 ERROR gxf/gxe/gxe.cpp@163: GxfGraphRunAsync Error: GXF_FAILURE
End deepstream-triton.yaml
[INFO] Graph installation directory /tmp/ds.deepstream-triton and manifest /tmp/ds.deepstream-triton/manifest.yaml retained
I tried to use containers but faced some issues as well so would like to stick with classic host execution. The instructions of that refrence graph README have something about installing Triton backend which I presume is Triton Inference Server. So not sure why to do another explicit install.
If you are sure the triton backend is intalled correctly. Please use “rm -rf ~/.cache/gstreamer-1.0/” to clear the gstreamer registry table and run “gst-inspect-1.0 nvinferserver” again.
Frame rate of the output is around 6fps. I can imagine Triton would be a bit slower than TRT plus the fact of using a bigger model (ssd_inception_v2_coco_2018_01_28). Still was hoping to get something faster than that but neverthless happy it’s working now.
