Trouble applying on Nvidia careers website
When applying through the Nvidia Workday portal I have an issue when clicking on “Save and continue” at the “My experience” step.
Each time it gives me an error code like this one : VPS|79003c4d-d86c-4307-943f-285cd559c76b
So I don’t know what is causing the issue.
Thank you for your help
Hi @matthieu.zajac
There are no other reports of this issue. Can you please try logging out and trying again? Maybe try from a different browser.
Hello, I am seeing the same error whenever I apply to NVIDIA. Usually it goes away when I click ‘Save and Continue’ the third time but this time the error remains even after many attempts. Ive tried restarting browser, deleting broswer history, clearing cache, restarting PC, logging and in - no luck.
I tried the same things as varrun did, even tried on another device but it still doesn’t work. If you have some way of getting the meaning of these error codes like the one below it could help a lot. Thank you.
Page Error
- Error Code: VPS|d8941b32-dede-4917-a144-9a088c7fbde6
Same issue – After hitting it three times it worked.
