I am attempting to download CUDA 9.0 for the purpose of setting up Tensorflow-gpu. I have downloaded the file from the archive and used the following commands:
$ sudo chmod +x cuda_9.0.176_384.81_linux.run
$ ./cuda_9.0.176_384.81_linux.run --override
I agree to the terms and conditions, then I follow the prompts:
Do you accept the previously read EULA?
accept/decline/quit: Do you accept the previously read EULA?
accept/decline/quit: accept
You are attempting to install on an unsupported configuration. Do you wish to continue?
(y)es/(n)o [ default is no ]: y
Install NVIDIA Accelerated Graphics Driver for Linux-x86_64 384.81?
(y)es/(n)o/(q)uit: n
Install the CUDA 9.0 Toolkit?
(y)es/(n)o/(q)uit: y
Enter Toolkit Location
[ default is /usr/local/cuda-9.0 ]:
/usr/local/cuda-9.0 is not writable.
Do you wish to run the installation with ‘sudo’?
(y)es/(n)o: y
Please enter your password:
Do you want to install a symbolic link at /usr/local/cuda?
Install the CUDA 9.0 Samples?
Enter CUDA Samples Location
[ default is /home/belford_pm ]:
Installing the CUDA Toolkit in /usr/local/cuda-9.0 …
Installing the CUDA Samples in /home/belford_pm …
Copying samples to /home/belford_pm/NVIDIA_CUDA-9.0_Samples now…
Finished copying samples.
= Summary =
Driver: Not Selected
Toolkit: Installed in /usr/local/cuda-9.0
Samples: Installed in /home/belford_pm
Please make sure that
- PATH includes /usr/local/cuda-9.0/bin
- LD_LIBRARY_PATH includes /usr/local/cuda-9.0/lib64, or, add /usr/local/cuda-9.0/lib64 to /etc/ld.so.conf and run ldconfig as root
To uninstall the CUDA Toolkit, run the uninstall script in /usr/local/cuda-9.0/bin
Please see CUDA_Installation_Guide_Linux.pdf in /usr/local/cuda-9.0/doc/pdf for detailed information on setting up CUDA.
***WARNING: Incomplete installation! This installation did not install the CUDA Driver. A driver of version at least 384.00 is required for CUDA 9.0 functionality to work.
To install the driver using this installer, run the following command, replacing with the name of this run file:
sudo .run -silent -driver
There are a lot of errors here, but the one I do not understand is why a driver has not been selected. Typing ‘nvidia-smi’ shows me that I have a driver:
| NVIDIA-SMI 390.116 Driver Version: 390.116 |
| 0 Quadro P1000 Off | 00000000:01:00.0 Off | N/A |
| N/A 54C P0 N/A / N/A | 531MiB / 4040MiB | 1% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1128 G /usr/lib/xorg/Xorg 278MiB |
| 0 1401 G /usr/bin/gnome-shell 101MiB |
| 0 1831 G …quest-channel-token=1790166115024653071 117MiB |
| 0 3576 G …quest-channel-token=6160179458185199838 31MiB |
I have even tried to update/install the driver again (with no error messages.
If someone can help me with this, I would very much appreciate it.
