I tried installing PyTorch on my JetBot (I’m new to this forum so correct me If I’m wrong) using the pip command, pip install torch, and it gives me the following error:
Collecting torch Using cached torch-0.1.2.post2.tar.gz (128 kB) ERROR: Command errored out with exit status 1: command: /usr/bin/python -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-gEAVA7/torch/setup.py'"'"'; __file__='"'"'/tmp/pip-install-gEAVA7/torch/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-XmtaIM cwd: /tmp/pip-install-gEAVA7/torch/ Complete output (8 lines): running egg_info creating /tmp/pip-pip-egg-info-XmtaIM/torch.egg-info writing requirements to /tmp/pip-pip-egg-info-XmtaIM/torch.egg-info/requires.txt writing /tmp/pip-pip-egg-info-XmtaIM/torch.egg-info/PKG-INFO writing top-level names to /tmp/pip-pip-egg-info-XmtaIM/torch.egg-info/top_level.txt writing dependency_links to /tmp/pip-pip-egg-info-XmtaIM/torch.egg-info/dependency_links.txt writing manifest file '/tmp/pip-pip-egg-info-XmtaIM/torch.egg-info/SOURCES.txt' error: package directory 'torch/cuda' does not exist ---------------------------------------- ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
But when I do pip3 install torch, it gives me something different:
Collecting torch
Cache entry deserialization failed, entry ignored
Using cached https://files.pythonhosted.org/packages/f8/02/880b468bd382dc79896eaecbeb8ce95e9c4b99a24902874a2cef0b562cea/torch-0.1.2.post2.tar.gz
Complete output from command python setup.py egg_info:
running egg_info
creating pip-egg-info/torch.egg-info
writing pip-egg-info/torch.egg-info/PKG-INFO
writing dependency_links to pip-egg-info/torch.egg-info/dependency_links.txt
writing requirements to pip-egg-info/torch.egg-info/requires.txt
writing top-level names to pip-egg-info/torch.egg-info/top_level.txt
writing manifest file ‘pip-egg-info/torch.egg-info/SOURCES.txt’
error: package directory ‘torch/cuda’ does not exist
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-biqdk0si/torch/
I tried one of the .whl files in the PyTorch for Jetson post, but they do not seem to open.
I’m pretty sure I’m missing something basic here, where have I gone wrong?
