im using an Jetson Xavier AGX with Jetpack 4.3. I converted a modified squeezenet caffemodel to an tensorrtengine with trtexec. I used following command:
./trtexec --deploy=deploy.prototxt --model=squeezenet.caffemodel --output=out1,out2 --fp16 --useDLACore=0 --allowGPUFallback --verbose
And got among others following output:
[02/31/2021-14:11:25] [V] [TRT] Applying generic optimizations to the graph for inference.
[02/31/2021-14:11:25] [V] [TRT] Original: 169 layers
[02/31/2021-14:11:25] [V] [TRT] After dead-layer removal: 169 layers
[02/31/2021-14:11:26] [W] [TRT] Internal DLA error for layer conv7_3. Switching to GPU fallback.
[02/31/2021-14:11:26] [W] [TRT] Internal DLA error for layer conv1_6. Switching to GPU fallback.
[02/31/2021-14:11:26] [V] [TRT] After DLA optimization: 11 layers
[02/31/2021-14:11:26] [V] [TRT] After scale fusion: 11 layers
[02/31/2021-14:11:26] [V] [TRT] After vertical fusions: 11 layers
[02/31/2021-14:11:26] [V] [TRT] After final dead-layer removal: 11 layers
[02/31/2021-14:11:26] [V] [TRT] After tensor merging: 11 layers
[02/31/2021-14:11:26] [V] [TRT] Eliminating concatenation concat_stage6
[02/31/2021-14:11:26] [V] [TRT] Generating copy for conv7_3 to concat6
[02/31/2021-14:11:26] [V] [TRT] Generating copy for conv4_4 to concat6
[02/31/2021-14:11:26] [V] [TRT] After concat removal: 13 layers
[02/31/2021-14:11:48] [V] [TRT] After reformat layers: 25 layers
My questions are the following:
- Is it possible that the network gets so dramatically reduced or could this be a hint for an error?
- What is the explanation for the different layer numbers?
- Does the outcoming network has 25 layers?
Thanks in advance.
