now getting this :
trtexec --onnx=best.onnx --fp16 --buildOnly --saveEngine=yolov8_vids.engine
&&&& RUNNING TensorRT.trtexec [TensorRT v8201] # trtexec --onnx=best.onnx --fp16 --buildOnly --saveEngine=yolov8_vids.engine
[04/24/2023-12:38:53] [I] === Model Options ===
[04/24/2023-12:38:53] [I] Format: ONNX
[04/24/2023-12:38:53] [I] Model: best.onnx
[04/24/2023-12:38:53] [I] Output:
[04/24/2023-12:38:53] [I] === Build Options ===
[04/24/2023-12:38:53] [I] Max batch: explicit batch
[04/24/2023-12:38:53] [I] Workspace: 16 MiB
[04/24/2023-12:38:53] [I] minTiming: 1
[04/24/2023-12:38:53] [I] avgTiming: 8
[04/24/2023-12:38:53] [I] Precision: FP32+FP16
[04/24/2023-12:38:53] [I] Calibration:
[04/24/2023-12:38:53] [I] Refit: Disabled
[04/24/2023-12:38:53] [I] Sparsity: Disabled
[04/24/2023-12:38:53] [I] Safe mode: Disabled
[04/24/2023-12:38:53] [I] DirectIO mode: Disabled
[04/24/2023-12:38:53] [I] Restricted mode: Disabled
[04/24/2023-12:38:53] [I] Save engine: yolov8_vids.engine
[04/24/2023-12:38:53] [I] Load engine:
[04/24/2023-12:38:53] [I] Profiling verbosity: 0
[04/24/2023-12:38:53] [I] Tactic sources: Using default tactic sources
[04/24/2023-12:38:53] [I] timingCacheMode: local
[04/24/2023-12:38:53] [I] timingCacheFile:
[04/24/2023-12:38:53] [I] Input(s)s format: fp32:CHW
[04/24/2023-12:38:53] [I] Output(s)s format: fp32:CHW
[04/24/2023-12:38:53] [I] Input build shapes: model
[04/24/2023-12:38:53] [I] Input calibration shapes: model
[04/24/2023-12:38:53] [I] === System Options ===
[04/24/2023-12:38:53] [I] Device: 0
[04/24/2023-12:38:53] [I] DLACore:
[04/24/2023-12:38:53] [I] Plugins:
[04/24/2023-12:38:53] [I] === Inference Options ===
[04/24/2023-12:38:53] [I] Batch: Explicit
[04/24/2023-12:38:53] [I] Input inference shapes: model
[04/24/2023-12:38:53] [I] Iterations: 10
[04/24/2023-12:38:53] [I] Duration: 3s (+ 200ms warm up)
[04/24/2023-12:38:53] [I] Sleep time: 0ms
[04/24/2023-12:38:53] [I] Idle time: 0ms
[04/24/2023-12:38:53] [I] Streams: 1
[04/24/2023-12:38:53] [I] ExposeDMA: Disabled
[04/24/2023-12:38:53] [I] Data transfers: Enabled
[04/24/2023-12:38:53] [I] Spin-wait: Disabled
[04/24/2023-12:38:53] [I] Multithreading: Disabled
[04/24/2023-12:38:53] [I] CUDA Graph: Disabled
[04/24/2023-12:38:53] [I] Separate profiling: Disabled
[04/24/2023-12:38:53] [I] Time Deserialize: Disabled
[04/24/2023-12:38:53] [I] Time Refit: Disabled
[04/24/2023-12:38:53] [I] Skip inference: Enabled
[04/24/2023-12:38:53] [I] Inputs:
[04/24/2023-12:38:53] [I] === Reporting Options ===
[04/24/2023-12:38:53] [I] Verbose: Disabled
[04/24/2023-12:38:53] [I] Averages: 10 inferences
[04/24/2023-12:38:53] [I] Percentile: 99
[04/24/2023-12:38:53] [I] Dump refittable layers:Disabled
[04/24/2023-12:38:53] [I] Dump output: Disabled
[04/24/2023-12:38:53] [I] Profile: Disabled
[04/24/2023-12:38:53] [I] Export timing to JSON file:
[04/24/2023-12:38:53] [I] Export output to JSON file:
[04/24/2023-12:38:53] [I] Export profile to JSON file:
[04/24/2023-12:38:53] [I] === Device Information ===
[04/24/2023-12:38:53] [I] Selected Device: Xavier
[04/24/2023-12:38:53] [I] Compute Capability: 7.2
[04/24/2023-12:38:53] [I] SMs: 6
[04/24/2023-12:38:53] [I] Compute Clock Rate: 1.109 GHz
[04/24/2023-12:38:53] [I] Device Global Memory: 15825 MiB
[04/24/2023-12:38:53] [I] Shared Memory per SM: 96 KiB
[04/24/2023-12:38:53] [I] Memory Bus Width: 256 bits (ECC disabled)
[04/24/2023-12:38:53] [I] Memory Clock Rate: 1.109 GHz
[04/24/2023-12:38:53] [I] TensorRT version: 8.2.1
[04/24/2023-12:38:55] [I] [TRT] [MemUsageChange] Init CUDA: CPU +362, GPU +0, now: CPU 381, GPU 6567 (MiB)
[04/24/2023-12:38:56] [I] [TRT] [MemUsageSnapshot] Begin constructing builder kernel library: CPU 381 MiB, GPU 6597 MiB
[04/24/2023-12:38:56] [I] [TRT] [MemUsageSnapshot] End constructing builder kernel library: CPU 486 MiB, GPU 6726 MiB
[04/24/2023-12:38:56] [I] Start parsing network model
[04/24/2023-12:38:56] [I] [TRT] ----------------------------------------------------------------
[04/24/2023-12:38:56] [I] [TRT] Input filename: best.onnx
[04/24/2023-12:38:56] [I] [TRT] ONNX IR version: 0.0.6
[04/24/2023-12:38:56] [I] [TRT] Opset version: 11
[04/24/2023-12:38:56] [I] [TRT] Producer name: pytorch
[04/24/2023-12:38:56] [I] [TRT] Producer version: 2.0.0
[04/24/2023-12:38:56] [I] [TRT] Domain:
[04/24/2023-12:38:56] [I] [TRT] Model version: 0
[04/24/2023-12:38:56] [I] [TRT] Doc string:
[04/24/2023-12:38:57] [W] [TRT] onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[04/24/2023-12:38:57] [I] Finish parsing network model
[04/24/2023-12:38:57] [I] [TRT] ---------- Layers Running on DLA ----------
[04/24/2023-12:38:57] [I] [TRT] ---------- Layers Running on GPU ----------
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.0/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.0/act/Sigmoid), /model.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.1/act/Sigmoid), /model.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.2/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.2/cv1/act/Sigmoid), /model.2/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.2/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.2/m.0/cv1/act/Sigmoid), /model.2/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.2/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(PWN(/model.2/m.0/cv2/act/Sigmoid), /model.2/m.0/cv2/act/Mul), /model.2/m.0/Add)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.2/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.2/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.2/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.2/cv2/act/Sigmoid), /model.2/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.3/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.3/act/Sigmoid), /model.3/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.4/cv1/act/Sigmoid), /model.4/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.4/m.0/cv1/act/Sigmoid), /model.4/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(PWN(/model.4/m.0/cv2/act/Sigmoid), /model.4/m.0/cv2/act/Mul), /model.4/m.0/Add)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/m.1/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.4/m.1/cv1/act/Sigmoid), /model.4/m.1/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/m.1/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(PWN(/model.4/m.1/cv2/act/Sigmoid), /model.4/m.1/cv2/act/Mul), /model.4/m.1/Add)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/m.0/Add_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.4/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.4/cv2/act/Sigmoid), /model.4/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.5/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.5/act/Sigmoid), /model.5/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.6/cv1/act/Sigmoid), /model.6/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.6/m.0/cv1/act/Sigmoid), /model.6/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(PWN(/model.6/m.0/cv2/act/Sigmoid), /model.6/m.0/cv2/act/Mul), /model.6/m.0/Add)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/m.1/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.6/m.1/cv1/act/Sigmoid), /model.6/m.1/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/m.1/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(PWN(/model.6/m.1/cv2/act/Sigmoid), /model.6/m.1/cv2/act/Mul), /model.6/m.1/Add)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/m.0/Add_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.6/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.6/cv2/act/Sigmoid), /model.6/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.7/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.7/act/Sigmoid), /model.7/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.8/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.8/cv1/act/Sigmoid), /model.8/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.8/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.8/m.0/cv1/act/Sigmoid), /model.8/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.8/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(PWN(/model.8/m.0/cv2/act/Sigmoid), /model.8/m.0/cv2/act/Mul), /model.8/m.0/Add)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.8/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.8/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.8/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.8/cv2/act/Sigmoid), /model.8/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.9/cv1/act/Sigmoid), /model.9/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/m/MaxPool
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/m_1/MaxPool
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/m_2/MaxPool
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/cv1/act/Mul_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/m/MaxPool_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/m_1/MaxPool_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/m_2/MaxPool_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.9/cv2/act/Sigmoid), /model.9/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.10/Resize
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.10/Resize_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.12/cv1/act/Sigmoid), /model.12/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.12/m.0/cv1/act/Sigmoid), /model.12/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.12/m.0/cv2/act/Sigmoid), /model.12/m.0/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.12/cv2/act/Sigmoid), /model.12/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.13/Resize
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.13/Resize_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.15/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.15/cv1/act/Sigmoid), /model.15/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.15/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.15/m.0/cv1/act/Sigmoid), /model.15/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.15/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.15/m.0/cv2/act/Sigmoid), /model.15/m.0/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.15/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.15/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.15/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.15/cv2/act/Sigmoid), /model.15/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.16/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.0/cv3.0.0/conv/Conv || /model.22/cv2.0/cv2.0.0/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.16/act/Sigmoid), /model.16/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv2.0/cv2.0.0/act/Sigmoid), /model.22/cv2.0/cv2.0.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv3.0/cv3.0.0/act/Sigmoid), /model.22/cv3.0/cv3.0.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.12/cv2/act/Mul_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv2.0/cv2.0.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.0/cv3.0.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.18/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv2.0/cv2.0.1/act/Sigmoid), /model.22/cv2.0/cv2.0.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv3.0/cv3.0.1/act/Sigmoid), /model.22/cv3.0/cv3.0.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.18/cv1/act/Sigmoid), /model.18/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv2.0/cv2.0.2/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.0/cv3.0.2/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.18/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Reshape
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.18/m.0/cv1/act/Sigmoid), /model.18/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.18/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.18/m.0/cv2/act/Sigmoid), /model.18/m.0/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.18/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.18/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.18/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.18/cv2/act/Sigmoid), /model.18/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.19/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.1/cv3.1.0/conv/Conv || /model.22/cv2.1/cv2.1.0/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.19/act/Sigmoid), /model.19/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv2.1/cv2.1.0/act/Sigmoid), /model.22/cv2.1/cv2.1.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv3.1/cv3.1.0/act/Sigmoid), /model.22/cv3.1/cv3.1.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.9/cv2/act/Mul_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv2.1/cv2.1.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.1/cv3.1.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.21/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv2.1/cv2.1.1/act/Sigmoid), /model.22/cv2.1/cv2.1.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv3.1/cv3.1.1/act/Sigmoid), /model.22/cv3.1/cv3.1.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.21/cv1/act/Sigmoid), /model.21/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv2.1/cv2.1.2/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.1/cv3.1.2/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.21/m.0/cv1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Reshape_1
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.21/m.0/cv1/act/Sigmoid), /model.21/m.0/cv1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.21/m.0/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.21/m.0/cv2/act/Sigmoid), /model.21/m.0/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.21/Split_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.21/Split_output_1 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.21/cv2/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.21/cv2/act/Sigmoid), /model.21/cv2/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.2/cv3.2.0/conv/Conv || /model.22/cv2.2/cv2.2.0/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv2.2/cv2.2.0/act/Sigmoid), /model.22/cv2.2/cv2.2.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv3.2/cv3.2.0/act/Sigmoid), /model.22/cv3.2/cv3.2.0/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv2.2/cv2.2.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.2/cv3.2.1/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv2.2/cv2.2.1/act/Sigmoid), /model.22/cv2.2/cv2.2.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(PWN(/model.22/cv3.2/cv3.2.1/act/Sigmoid), /model.22/cv3.2/cv3.2.1/act/Mul)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv2.2/cv2.2.2/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/cv3.2/cv3.2.2/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Reshape_2
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Reshape_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Reshape_1_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Reshape_2_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Split
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Split_8
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/dfl/Reshape + /model.22/dfl/Transpose
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] (Unnamed Layer* 228) [Shuffle]
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/dfl/Softmax
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] (Unnamed Layer* 230) [Shuffle] + /model.22/dfl/Transpose_1
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/dfl/conv/Conv
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/dfl/Reshape_1
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Slice
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Slice_1
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Constant_9_output_0
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Sub
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Constant_10_output_0
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Add_1
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(/model.22/Constant_11_output_0 + (Unnamed Layer* 292) [Shuffle], PWN(/model.22/Add_2, /model.22/Div_1))
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Sub_1
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Div_1_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Sub_1_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Constant_12_output_0 + (Unnamed Layer* 297) [Shuffle]
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Mul_2
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] PWN(/model.22/Sigmoid)
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Mul_2_output_0 copy
[04/24/2023-12:38:57] [I] [TRT] [GpuLayer] /model.22/Sigmoid_output_0 copy
[04/24/2023-12:38:58] [I] [TRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +227, GPU +324, now: CPU 763, GPU 7184 (MiB)
[04/24/2023-12:39:00] [I] [TRT] [MemUsageChange] Init cuDNN: CPU +307, GPU +452, now: CPU 1070, GPU 7636 (MiB)
[04/24/2023-12:39:00] [I] [TRT] Local timing cache in use. Profiling results in this builder pass will not be stored.
[04/24/2023-12:39:00] [E] Error[2]: [utils.cpp::checkMemLimit::380] Error Code 2: Internal Error (Assertion upperBound != 0 failed. Unknown embedded device detected. Please update the table with the entry: {{1794, 6, 16}, 12660},)
[04/24/2023-12:39:00] [E] Error[2]: [builder.cpp::buildSerializedNetwork::609] Error Code 2: Internal Error (Assertion enginePtr != nullptr failed. )
[04/24/2023-12:39:00] [E] Engine could not be created from network
[04/24/2023-12:39:00] [E] Building engine failed
[04/24/2023-12:39:00] [E] Failed to create engine from model.
[04/24/2023-12:39:00] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec [TensorRT v8201] # trtexec --onnx=best.onnx --fp16 --buildOnly --saveEngine=yolov8_vids.engine
