I am trying to use CUDA (12.3) & cuDNN (8.9.7) so my Nvidia 4050 RTX is actually used when I train Machine Learning models in my code.
-Installed CUDA 12.3 & cuDNN 8.9.7 (Verified CUDA installation)
- I have put the cuDNN files in my CUDA 12.3 directory (bin, lib, and libnvvp)
- I set the env variables with C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\bin as CUDA_PATH and I have put C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\bin & C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.3\libnvvp into Path (Verified with cmd commands)
- Set Nvidia drivers up to date
- installed tensorflow using pip install tensorflow (everything said "Requirment already satisfied)
But even after all this, I ran this program:
import tensorflow as tf
from tensorflow.python.client import device_lib
print(“TensorFlow version:”, tf.version)
print("Num GPUs Available: ", len(tf.config.experimental.list_physical_devices(‘GPU’)))
print(device_lib.list_local_devices())
if tf.test.gpu_device_name():
print(‘Default GPU Device: {}’.format(tf.test.gpu_device_name()))
else:
print(“Please install GPU version of TensorFlow”)
and its returning that the GPU isnt used:
TensorFlow version: 2.16.1
Num GPUs Available: 0
[name: “/device:CPU:0”
device_type: “CPU”
memory_limit: 268435456
locality {
incarnation: 15945025555237357829
xla_global_id: -1
