Hi Folks,
I modified, argus/samples/denoise example to preview output of two cameras on screen. I have been searching for an API to set frame rate of capture. I have been unable to find, one. Please help. Below is my code…
I am not able to find a method in IOutputStreamSettings class to set frame rate.
Thanks,
* Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "Error.h"
#include "EGLGlobal.h"
#include "GLContext.h"
#include "Window.h"
#include "Thread.h"
#include "PreviewConsumer.h"
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <unistd.h>
#include <stdlib.h>
using namespace Argus;
* This sample outputs capture requests to two streams, one of which has denoise algorithms
* enabled while the other does not, and then renders them to a split-screen window.
namespace ArgusSamples
// Constants.
static const uint32_t CAPTURE_TIME = 10; // In seconds.
static const Size STREAM_SIZE (1920, 1080);
static const NormalizedRect SOURCE_CLIP_RECT (0.4f, 0.4f, 0.6f, 0.6f);
// Globals.
UniqueObj<CameraProvider> g_cameraProvider;
EGLDisplayHolder g_display;
// Debug print macros.
#define PRODUCER_PRINT(...) printf("PRODUCER: " __VA_ARGS__)
static bool execute()
// Initialize the window and EGL display.
Window &window = Window::getInstance();
window.setWindowRect(0, 0, STREAM_SIZE.width, STREAM_SIZE.height);
PROPAGATE_ERROR(g_display.initialize(window.getEGLNativeDisplay()));
// Initialize the Argus camera provider.
UniqueObj<CameraProvider> cameraProvider(CameraProvider::create());
ICameraProvider *iCameraProvider = interface_cast<ICameraProvider>(cameraProvider);
if (!iCameraProvider)
ORIGINATE_ERROR("Failed to get ICameraProvider interface");
// Create a capture session using the first available device.
std::vector<CameraDevice*> cameraDevices;
if (iCameraProvider->getCameraDevices(&cameraDevices) != STATUS_OK)
ORIGINATE_ERROR("Failed to get CameraDevices");
if (cameraDevices.size() == 0)
ORIGINATE_ERROR("No CameraDevices available");
UniqueObj<CaptureSession> captureSession(
iCameraProvider->createCaptureSession(cameraDevices[0]));
ICaptureSession *iCaptureSession = interface_cast<ICaptureSession>(captureSession);
if (!iCaptureSession)
ORIGINATE_ERROR("Failed to create CaptureSession");
UniqueObj<CaptureSession> captureSession1(
iCameraProvider->createCaptureSession(cameraDevices[1]));
ICaptureSession *iCaptureSession1 = interface_cast<ICaptureSession>(captureSession1);
if (!iCaptureSession1)
// Create two output streams, one for unprocessed preview and one for denoise.
PRODUCER_PRINT("Creating output streams\n");
UniqueObj<OutputStreamSettings> streamSettings(iCaptureSession->createOutputStreamSettings());
IOutputStreamSettings *iStreamSettings = interface_cast<IOutputStreamSettings>(streamSettings);
if (!iStreamSettings)
ORIGINATE_ERROR("Failed to create OutputStreamSettings");
iStreamSettings->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings->setResolution(STREAM_SIZE);
iStreamSettings->setEGLDisplay(g_display.get());
UniqueObj<OutputStream> previewStream(iCaptureSession->createOutputStream(streamSettings.get()));
IStream *iPreviewStream = interface_cast<IStream>(previewStream);
if (!iPreviewStream)
ORIGINATE_ERROR("Failed to create preview stream");
UniqueObj<OutputStreamSettings> streamSettings1(iCaptureSession1->createOutputStreamSettings());
IOutputStreamSettings *iStreamSettings1 = interface_cast<IOutputStreamSettings>(streamSettings1);
if (!iStreamSettings1)
iStreamSettings1->setPixelFormat(PIXEL_FMT_YCbCr_420_888);
iStreamSettings1->setResolution(STREAM_SIZE);
iStreamSettings1->setEGLDisplay(g_display.get());
UniqueObj<OutputStream> previewStream1(iCaptureSession1->createOutputStream(streamSettings1.get()));
IStream *iPreviewStream1 = interface_cast<IStream>(previewStream1);
if (!iPreviewStream1)
//UniqueObj<OutputStream> denoiseStream(iCaptureSession->createOutputStream(streamSettings.get()));
//IStream *iDenoiseStream = interface_cast<IStream>(denoiseStream);
//if (!iDenoiseStream)
// ORIGINATE_ERROR("Failed to create denoise stream");
// Connect a PreviewConsumer to the streams to render a split-screen, side-by-side rendering.
PRODUCER_PRINT("Launching consumer thread\n");
std::vector<EGLStreamKHR> eglStreams;
eglStreams.push_back(iPreviewStream->getEGLStream());
eglStreams.push_back(iPreviewStream1->getEGLStream());
PreviewConsumerThread consumerThread(g_display.get(), eglStreams,
PreviewConsumerThread::LAYOUT_SPLIT_VERTICAL,
true /* Sync stream frames */);
PROPAGATE_ERROR(consumerThread.initialize());
//consumerThread.setLineWidth(1);
//consumerThread.setLineColor(1.0f, 0.0f, 0.0f);
// Wait until the consumer is connected to the streams.
PROPAGATE_ERROR(consumerThread.waitRunning());
// Create capture request and enable output streams.
UniqueObj<Request> request(iCaptureSession->createRequest());
IRequest *iRequest = interface_cast<IRequest>(request);
if (!iRequest)
ORIGINATE_ERROR("Failed to create Request");
iRequest->enableOutputStream(previewStream.get());
UniqueObj<Request> request1(iCaptureSession1->createRequest());
IRequest *iRequest1 = interface_cast<IRequest>(request1);
if (!iRequest1)
iRequest1->enableOutputStream(previewStream1.get());
// Use small source clip rects to zoom the image to make noise more visible.
IStreamSettings *previewStreamSettings =
interface_cast<IStreamSettings>(iRequest->getStreamSettings(previewStream.get()));
if (!previewStreamSettings)
ORIGINATE_ERROR("Failed to get preview stream settings interface");
IStreamSettings *previewStreamSettings1 =
interface_cast<IStreamSettings>(iRequest1->getStreamSettings(previewStream1.get()));
if (!previewStreamSettings1)
ORIGINATE_ERROR("Failed to get denoise stream settings interface");
//previewStreamSettings->setSourceClipRect(SOURCE_CLIP_RECT);
//previewStreamSettings1->setSourceClipRect(SOURCE_CLIP_RECT);
// Enable denoise for the request.
//IDenoiseSettings *denoiseSettings = interface_cast<IDenoiseSettings>(request);
//if (!denoiseSettings)
// ORIGINATE_ERROR("Failed to get DenoiseSettings interface");
//denoiseSettings->setDenoiseMode(DENOISE_MODE_FAST);
//denoiseSettings->setDenoiseStrength(1.0f);
// Disable all post-processing (including denoise) for the preview stream (enabled by default).
previewStreamSettings->setPostProcessingEnable(false);
previewStreamSettings1->setPostProcessingEnable(false);
// Submit capture requests.
PRODUCER_PRINT("Starting repeat capture requests.\n");
if (iCaptureSession->repeat(request.get()) != STATUS_OK)
ORIGINATE_ERROR("Failed to start repeat capture request");
if (iCaptureSession1->repeat(request1.get()) != STATUS_OK)
// Wait for CAPTURE_TIME seconds.
PROPAGATE_ERROR(window.pollingSleep(CAPTURE_TIME));
// Stop the repeating request and wait for idle.
iCaptureSession->stopRepeat();
iCaptureSession->waitForIdle();
iCaptureSession1->stopRepeat();
iCaptureSession1->waitForIdle();
// Destroy the output streams and wait for the consumer thread to complete.
previewStream.reset();
previewStream1.reset();
//denoiseStream.reset();
PROPAGATE_ERROR(consumerThread.shutdown());
// Shut down Argus.
g_cameraProvider.reset();
// Shut down the window (destroys window's EGLSurface).
window.shutdown();
// Cleanup the EGL display
PROPAGATE_ERROR(g_display.cleanup());
PRODUCER_PRINT("Done -- exiting.\n");
return true;
}; // namespace ArgusSamples
int main(int argc, const char *argv[])
if (!ArgusSamples::execute())
return EXIT_FAILURE;
return EXIT_SUCCESS;
