thank you for you answer, but i still have some questions.
I couldn’t find any information about these DMIC lines, i did find them in this document :
Jetson_TX1_Pin_and_Function_Names_Guide_Application_Note.pdf
but there was no information in the “Jetson TX1 System-on-Module Data Sheet”.
is there a document that have more information, details, configurations and explanations ?
plus i would like to verify the data i found, i does not correlate 100% with the data you gave me:
Pin D16 is A0_DMIC_IN_DAT (RSVD)
Pin E16 is A0_DMIC_IN_CLK(RSVD)"
both are in the Reserved pin list, are they active or not ?
G5 Pin is I2S2_CLK and is defined also as DMIC2_DAT
G6 Pin is I2S_SDIN and is defined also as DMIC1_DAT
H5 Pin is I2S2_LRCLK and is defined also as DMIC1_CLK
H6 Pin is I2S_SDOUT and is defined also as DMIC2_CLK
So there is no DMIC3_CLK or DMIC3_DATA, i guess it starts with 0
As to the way to connect the PDM lines,
from your answer i understand the the PDM data is the DMICX_DATA and PDM_CLK is the DMICX_CLK.
i should be able to read one mic on the rising edge and the other on the same line on the falling edge.
So please verify all this information, and if there is and document can you add a link ?
I think the Data sheet should be updated with more information than PDM reciever x 6 that is the only line regarding the PDM inputs.
Thank you very much for your help
