I found my old Xilinx Spartan 6 LX45T Development board SP605 and loaded the PCIE Demo image and have observed the same results as I did with my board namely that I achieved linkup on the Desktop and I didn’t achieve linkup on the TX1 devboard.
Here is the result of ‘lspci -d 10ee:0007 -vvv’ on the desktop with the SP605
03:00.0 RAM memory: Xilinx Corporation Default PCIe endpoint ID
Subsystem: Xilinx Corporation Default PCIe endpoint ID
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at fea00000 (32-bit, non-prefetchable)
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [58] Express (v1) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s, Exit Latency L0s unlimited, L1 unlimited
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
Capabilities: [100 v1] Device Serial Number 00-00-00-01-01-00-0a-35
I mentioned before that when I plug in my board (Artemis) into the TX1 devboard the TX1 does not boot but when I can keep the FPGA in reset until after it is part way through the boot I can see the PCIE Switch using ‘lspci’
When using the SP605 the TX1 boots fine, it doesn’t seem to recognize the SP605 at all.
I found a USB - UART cable and plugged in the serial console so I can observe the PCIE output within the bootloader:
Here is the known working USB3.0 PCIE card output
Some stuff before
TEGRA210
Model: NVIDIA P2371-2180
DRAM: 4 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
tegra-pcie: PCI regions:
tegra-pcie: I/O: 0x0000000012000000-0x0000000012010000
tegra-pcie: non-prefetchable memory: 0x0000000013000000-0x0000000020000000
tegra-pcie: prefetchable memory: 0x0000000020000000-0x0000000040000000
tegra-pcie: 4x1, 1x1 configuration
tegra-pcie: probing port 0, using 4 lanes
tegra-pcie: probing port 1, using 1 lanes
tegra-pcie: link 1 down, retrying
tegra-pcie: link 1 down, ignoring
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
948 bytes read in 72 ms (12.7 KiB/s)
p2371-2180 eMMC boot options
1: primary kernel
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
19003224 bytes read in 487 ms (37.2 MiB/s)
append: fbcon=map:0 console=tty0 console=ttyS0,115200n8 androidboot.modem=none androidboot.serialno=P2180A00P00940c003fd androidboot.security=non-secure tegraid=21.1.2.0.0 ddr_die=2048M@2048M ddr_die=2048M@4096M section=256M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff2bf000 nvdumper_reserved=0xff23f000 core_edp_mv=1125 core_edp_ma=4000 gpt android.kerneltype=normal androidboot.touch_vendor_id=0 androidboot.touch_panel_id=63 androidboot.touch_feature=0 androidboot.bootreason=pmc:software_reset,pmic:0x0 root=/dev/mmcblk0p1 rw rootwait
Retrieving file: /boot/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb
248081 bytes read in 227 ms (1 MiB/s)
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000082000000, end 000000008203f910
Starting kernel ...
[ 2.943834] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 2.945453] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.947519] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 3.384350] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 3.790406] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.196457] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.202994] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 4.207634] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 4.214670] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 4.221504] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 4.228773] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.234242] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 4.240901] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.260392] pci 0000:00:01.0: BAR 8: assigned [mem 0x13000000-0x130fffff]
[ 4.265198] pci 0000:01:00.0: BAR 0: assigned [mem 0x13000000-0x13000fff]
[ 4.271979] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 4.276897] pci 0000:00:01.0: bridge window [mem 0x13000000-0x130fffff]
[ 4.283676] PCI: enabling device 0000:00:01.0 (0140 -> 0143)
[ 4.289513] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 4.296241] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 4.302988] PCI: enabling device 0000:01:00.0 (0140 -> 0142)
When I reached the console I used a similar lspci command: “lspci -s 01:00.0 -vvv” and here is the output
01:00.0 USB controller: VIA Technologies, Inc. VL80x xHCI USB 3.0 Controller (rev 03) (prog-if 30 [XHCI])
Subsystem: VIA Technologies, Inc. VL80x xHCI USB 3.0 Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Interrupt: pin A routed to IRQ 547
Region 0: Memory at 13000000 (32-bit, non-prefetchable)
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 000000017ef69000 Data: 0000
Capabilities: [c4] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s <512ns, L1 <16us
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM not supported, Exit Latency L0s <2us, L1 <16us
ClockPM+ Surprise- LLActRep- BwNot-
LnkSta: Speed 5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Kernel driver in use: xhci_hcd
Here is what the SP605 output looks like:
Some stuff before
TEGRA210
DRAM: 4 GiB
tegra-pcie: link 0 down, retrying
tegra-pcie: link 0 down, ignoring
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
1: primary kernel
Starting kernel ...
some stuff
[ 2.944068] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 2.945681] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.947746] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 3.350287] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 3.756334] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 4.162211] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 4.168692] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 4.574318] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.980195] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.386246] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 5.392739] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 5.397197] tegra-pcie 1003000.pcie-controller: PCIE: no ports detected
[ 5.404168] tegra-pcie 1003000.pcie-controller: PCIE: Disable power rails
Continue to terminal...
Here is Artemis:
Some stuff before
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 0:1...
1: primary kernel
Starting kernel ...
some stuff
[ 2.944187] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 2.945811] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes and lane map as 0x14
[ 2.947883] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes and lane map as 0x14
[ 3.650134] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.056180] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.464405] tegra-pcie 1003000.pcie-controller: link 1 down, retrying
[ 4.470890] tegra-pcie 1003000.pcie-controller: link 1 down, ignoring
[ 4.475530] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 4.482566] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 4.489389] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 4.496688] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 4.502139] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 4.508805] pci 0000:00:01.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 4.522410] PCI: bus1: Fast back to back transfers enabled
[ 4.525960] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 4.530885] PCI: enabling device 0000:00:01.0 (0140 -> 0143)
[ 4.536704] pcieport 0000:00:01.0: Signaling PME through PCIe PME interrupt
[ 4.547802] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.553681] tegra-pcie 1003000.pcie-controller: PCIE: No Link speed change happened
[ 4.563074] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 4.564152] tsec tsec: initialized
[ 4.565395] tsec tsecb: initialized
[ 4.567705] nvdec nvdec: initialized
[ 4.570997] falcon vic03: initialized
[ 4.572648] falcon msenc: initialized
[ 4.574033] falcon nvjpg: initialized
[ 4.575595] tegradc tegradc.1: Display dc.54240000 registered with id=0
[ 4.575750] display board info: id 0x0, fab 0x0
[ 4.576253] panel_select fail by _node_status
[ 4.576326] display board info: id 0x0, fab 0x0
[ 4.576645] panel_select fail by _node_status
[ 4.576657] parse_tmds_config: No tmds-config node
[ 4.576798] of_dc_parse_platform_data: could not find vrr-settings node
[ 4.576803] of_dc_parse_platform_data: could not find SD settings node
[ 4.576809] of_dc_parse_platform_data: could not find cmu node
[ 4.576813] of_dc_parse_platform_data: could not find cmu node for adobeRGB
[ 4.576831] tegradc tegradc.1: DT parsed successfully
[ 4.653228] display board info: id 0x0, fab 0x0
[ 4.654278] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 4.655798] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 4.658016] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.661501] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 4.662293] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 4.663401] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 4.664778] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664797] pcieport 0000:00:01.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, id=0008(Receiver ID)
[ 4.664805] pcieport 0000:00:01.0: device [10de:0fae] error status/mask=00000001/00002000
[ 4.664812] pcieport 0000:00:01.0: [ 0] Receiver Error
[ 4.664829] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664851] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664873] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664894] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664915] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664937] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664959] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.664980] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665002] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665023] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665044] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665065] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665087] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665108] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665130] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665151] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665172] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665193] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665215] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665236] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665257] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665278] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665744] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665766] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.665787] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.711579] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.711642] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.711685] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.757339] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.757488] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
[ 4.757510] pcieport 0000:00:01.0: AER: Multiple Corrected error received: id=0010
Spiral to AER oblivion :(
I didn’t want to put the entire boot logs into the code windows so I put in the parts I thought were important. If you would like to view the entire boot logs they are available here:
Artemis Not Working
SP605 Not Working
USB 3.0 Working
Any ideas?
Thanks,
Dave
