Dear Sir,
My compile environment is set as follows:
export CROSS_COMPILE=/opt/gcc-linaro-5.4.1-2017.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
export CROSS32CC=/opt/gcc-linaro-5.4.1-2017.05-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc
export ARCH=arm64
export TEGRA_KERNEL_OUT=$basepath/images
export TEGRA_MODULES_OUT=$basepath/modules
if [ “$1” != “” ]; then
case $1 in
clean)
make -C kernel-4.4 mrproper
kernel)
make -C kernel-4.4 O=$TEGRA_KERNEL_OUT tegra21_defconfig
make -C kernel-4.4 O=$TEGRA_KERNEL_OUT Image
dtb)
make -C kernel-4.4 O=$TEGRA_KERNEL_OUT dtbs
When build kernel ,it is fail ,error message is :
No rule to make target firmware/audience/es755/audience-es755-fw.bin', needed by firmware/audience/es755/audience-es755-fw.bin.gen.o’. Stop.
Would you please help to give me some advice ,Thanks
