I am working using a TX2 on a custom carrier board using a yocto distribution based on the tegra-demo-distro.
I am looking into enabling the denver cores but facing many issues.
I cannot turn them on using nvpmodel or by echoing 1 into /sys/devices/system/cpu/cpu1/online
The first attempt returns -sh: echo: write error: Bad address
Any subsequent attempts return -sh: echo: write error: File exists
When using stock Jetpack I am able to enable them, confirming they work, but this is not a suitable solution for my application.
Any help pointing towards where the issue might be would be greatly appreciated.
My kernel command line args are as follows
console=none console=tty0 fbcon=map:0 isolcpus= OS=l4t console=ttyS0,115200n8 console=tty0 fbcon=map:0 isolcpus= OS=l4t video=tegrafb nvdumper_reserved=0x2772e0000 gpt rootfs.slot_suffix= tegra_fbmem2=0x800000@0x96085000 lut_mem2=0x2008@0x96081000 usbcore.old_scheme_first=1 tegraid=18.1.2.0.0 maxcpus=6 no_console_suspend boot.slot_suffix= boot.ratchetvalues=0.2031647.1 vpr_resize bl_prof_dataptr=0x10000@0x275840000 sdhci_tegra.en_boot_part_access=1
Looking at the journal I get the following after the first attempt
Apr 28 17:44:35 device kernel: CPU1: Booted secondary processor [4e0f0030]
Apr 28 17:44:35 device kernel: CPU1: shutdown
Apr 28 17:44:35 device kernel: psci: CPU1 killed (polled 0 ms)
And I get the following after all subsequent attempts
Apr 28 17:44:38 device kernel: sysfs: cannot create duplicate filename '/devices/system/cpu/cpu1/topology'
Apr 28 17:44:38 device kernel: ------------[ cut here ]------------
Apr 28 17:44:38 device kernel: WARNING: CPU: 4 PID: 4028 at fs/sysfs/dir.c:30 sysfs_warn_dup+0x5c/0x80
Apr 28 17:44:38 device kernel: Modules linked in: bluedroid_pm nvgpu
Apr 28 17:44:38 device kernel: CPU: 4 PID: 4028 Comm: sh Tainted: G O 4.9.337-l4t-r32.7.6+gd4116ecb5c13 #1
Apr 28 17:44:38 device kernel: Hardware name: quill (DT)
Apr 28 17:44:38 device kernel: task: 00000000e511d3fa task.stack: 000000007026a762
Apr 28 17:44:38 device kernel: PC is at sysfs_warn_dup+0x5c/0x80
Apr 28 17:44:38 device kernel: LR is at sysfs_warn_dup+0x5c/0x80
Apr 28 17:44:38 device kernel: pc : [<ffffff80083f932c>] lr : [<ffffff80083f932c>] pstate: 40400145
Apr 28 17:44:38 device kernel: sp : ffffffc1c6ddfa90
Apr 28 17:44:38 device kernel: x29: ffffffc1c6ddfa90 x28: ffffffc1f669d9c8
Apr 28 17:44:38 device kernel: x27: 00000041ed307000 x26: 0000000000000000
Apr 28 17:44:38 device kernel: x25: ffffff80093969c8 x24: 0000000000000001
Apr 28 17:44:38 device kernel: x23: 0000000000000003 x22: 0000000000000000
Apr 28 17:44:38 device kernel: x21: ffffff8008e06c78 x20: ffffffc1ebf015a0
Apr 28 17:44:38 device kernel: x19: ffffffc1ec14f000 x18: ffffffffffffffff
Apr 28 17:44:38 device kernel: x17: 0000000000000000 x16: 0000000000000000
Apr 28 17:44:38 device kernel: x15: ffffff808969f5ef x14: 0000000000000006
Apr 28 17:44:38 device kernel: x13: ffffff800969f5f7 x12: ffffffc1c6ddf7a0
Apr 28 17:44:38 device kernel: x11: 0000000000000301 x10: ffffff800969f000
Apr 28 17:44:38 device kernel: x9 : 0000000000086ebc x8 : 7570632f6d657473
Apr 28 17:44:38 device kernel: x7 : 0000000000000001 x6 : 0000000000000000
Apr 28 17:44:38 device kernel: x5 : 0000000000000000 x4 : ffffffc1f66dfbd8
Apr 28 17:44:38 device kernel: x3 : ffffffc1f66e4778 x2 : ffffffc1f66dfbd8
Apr 28 17:44:38 device kernel: x1 : ffffffc1e4d4ee40 x0 : 000000000000004b
Apr 28 17:44:38 device kernel: ---[ end trace 97eabc39bf25e349 ]---
Apr 28 17:44:38 device kernel: Call trace:
Apr 28 17:44:38 device kernel: [<000000006aeb5b00>] sysfs_warn_dup+0x5c/0x80
Apr 28 17:44:38 device kernel: [<000000006eac4f6b>] internal_create_group+0x10c/0x120
Apr 28 17:44:38 device kernel: [<00000000323854b9>] sysfs_create_group+0x14/0x20
Apr 28 17:44:38 device kernel: [<000000006efc8fc3>] topology_cpu_callback+0x54/0xc0
Apr 28 17:44:38 device kernel: [<0000000024cb66ff>] notifier_call_chain+0x54/0xa0
Apr 28 17:44:38 device kernel: [<0000000005e9dab9>] __raw_notifier_call_chain+0xc/0x20
Apr 28 17:44:38 device kernel: [<00000000e979072f>] notify_prepare+0x3c/0xb0
Apr 28 17:44:38 device kernel: [<000000009cb0af6c>] cpuhp_invoke_callback+0x70/0x180
Apr 28 17:44:38 device kernel: [<00000000b0a637fa>] cpuhp_up_callbacks+0x34/0x130
Apr 28 17:44:38 device kernel: [<00000000228df0d6>] _cpu_up+0xf4/0x170
Apr 28 17:44:38 device kernel: [<0000000048f89e6a>] do_cpu_up+0x98/0xd0
Apr 28 17:44:38 device kernel: [<00000000560d7dbe>] cpu_up+0x10/0x20
Apr 28 17:44:38 device kernel: [<00000000ad18c5ad>] cpu_subsys_online+0x10/0x20
Apr 28 17:44:38 device kernel: [<00000000dcb166a7>] device_online+0x6c/0x90
Apr 28 17:44:38 device kernel: [<000000007aa38357>] online_store+0x90/0xc0
Apr 28 17:44:38 device kernel: [<000000004d56eacb>] dev_attr_store+0x18/0x30
Apr 28 17:44:38 device kernel: [<00000000d17ef6be>] sysfs_kf_write+0x40/0x50
Apr 28 17:44:38 device kernel: [<00000000c4a189a0>] kernfs_fop_write+0xb4/0x1d0
Apr 28 17:44:38 device kernel: [<000000005228a696>] __vfs_write+0x18/0x110
Apr 28 17:44:38 device kernel: [<0000000043e2ce0a>] vfs_write+0xa4/0x190
Apr 28 17:44:38 device kernel: [<00000000cc4176cc>] SyS_write+0x4c/0xc0
Apr 28 17:44:38 device kernel: [<00000000481bd1b0>] __sys_trace_return+0x0/0x4
Apr 28 17:44:38 device kernel: notify_prepare: attempt to bring up CPU 1 failed
