We are encountering a lot of issues while using the Jetson TX2 Dev Kit embedded camera (ov5693) with Video4Linux (V4L2).
First of all, here is a summary of devices detection by V4L and the supported formats for /dev/video0
nvidia@tegra-ubuntu:~$ v4l2-ctl --list-devices
VIDIOC_QUERYCAP: failed: Inappropriate ioctl for device
vi-output, ov5693 2-0036 (platform:15700000.vi:2):
/dev/video0
/dev/v4l-subdev1
/dev/v4l-subdev0
nvidia@tegra-ubuntu:~$ v4l2-ctl -d /dev/video0 --list-formats
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'RGGB'
Name : 8-bit Bayer RGRG/GBGB
Index : 1
Pixel Format: 'RG10'
Name : 10-bit Bayer RGRG/GBGB
Index : 2
Pixel Format: 'BG10'
Name : 10-bit Bayer BGBG/GRGR
Index : 3
Pixel Format: 'RG12'
Name : 12-bit Bayer RGRG/GBGB
We tried camera acquisition with v4l2-ctl utility for each supported format.
Here are the corresponding test results:
nvidia@tegra-ubuntu:~$ v4l2-ctl --set-fmt-video=width=2592,height=1944,pixelformat=RGGB --stream-mmap --stream-count=5 -d /dev/video0 --stream-to=ov5693.raw
<< 1.00 fps
< 0.99 fps
< 0.99 fps
< 0.99 fps
nvidia@tegra-ubuntu:~$ v4l2-ctl --set-fmt-video=width=2592,height=1944,pixelformat=RG10 --stream-mmap --stream-count=5 -d /dev/video0 --stream-to=ov5693.raw
nvidia@tegra-ubuntu:~$ v4l2-ctl --set-fmt-video=width=2592,height=1944,pixelformat=BG10 --stream-mmap --stream-count=5 -d /dev/video0 --stream-to=ov5693.raw
nvidia@tegra-ubuntu:~$ v4l2-ctl --set-fmt-video=width=2592,height=1944,pixelformat=RG12 --stream-mmap --stream-count=5 -d /dev/video0 --stream-to=ov5693.raw
<< 1.00 fps
< 1.00 fps
< 0.99 fps
< 0.99 fps
It appears that acquisition seems to work only for 10bits Bayer formats. With RGGB and RG12, the camera delivers less than 1FPS.
Last and not the least, the image size and bytes per line values provided by v4l2-ctl seems quite strange.
(RGGB is supposed to be 8bits Bayer but the bytes per line is more than a 16bits image):
nvidia@tegra-ubuntu:~$ v4l2-ctl --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, ov5693 2-0036
Bus info : platform:15700000.vi:2
Driver version: 4.4.38
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 2: no power)
Format Video Capture:
Width/Height : 2592/1944
Pixel Format : 'RGGB'
Field : None
Bytes per Line : 5376
Size Image : 10450944
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
Camera Controls
frame_length (int) : min=0 max=32767 step=1 default=1984 value=1984 flags=slider
coarse_time (int) : min=2 max=32761 step=1 default=1978 value=1978 flags=slider
coarse_time_short (int) : min=2 max=32761 step=1 default=1978 value=1978 flags=slider
group_hold (intmenu): min=0 max=1 default=0 value=0
hdr_enable (intmenu): min=0 max=1 default=0 value=0
otp_data (str) : min=0 max=1024 step=2 value='93b28b1382215ebc0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000570000000000000000001a0000000000' flags=read-only, has-payload
fuse_id (str) : min=0 max=16 step=2 value='93b28b1382215ebc' flags=read-only, has-payload
gain (int) : min=256 max=4096 step=1 default=256 value=256 flags=slider
bypass_mode (intmenu): min=0 max=1 default=0 value=1
override_enable (intmenu): min=0 max=1 default=0 value=1
height_align (int) : min=1 max=16 step=1 default=1 value=1
size_align (intmenu): min=0 max=2 default=0 value=0
write_isp_format (int) : min=1 max=1 step=1 default=1 value=1
sensor_signal_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_image_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_control_properties (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_dv_timings (u32) : min=0 max=0 step=0 default=0 flags=read-only, has-payload
sensor_modes (int) : min=0 max=30 step=1 default=30 value=3 flags=read-only
Would you have any clues or V4L2 working code for the OV5693 camera provided with the dev kit?
Thanks and best regards,
Xavier
