0. nvgpu crash
I have a kernel crash on nvgpu when I’m trying to get images from yavta or v4l2-ctl after using gst-launch-1.0 nvarguscamerasrc. This is the procedure + logs:
1. v4l2
- Start v4l2-ctl and/or yavta to test v4l2 pipeline:
# v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --stream-count=100 -d /dev/video0
# yavta -s 1920x1080 -f SRGGB10 /dev/video0 -c
This works fine.
1.1 Logs
- kernel message output (after stopping the stream): note: same output for v4l2-ctl and for yavta.
[ 355.400571] vb2: counters for queue ffffffc1eb507b58, buffer 3: UNBALANCED!
[ 355.400583] vb2: buf_init: 1 buf_cleanup: 1 buf_prepare: 26 buf_finish: 26
[ 355.400588] vb2: buf_queue: 27 buf_done: 27
[ 355.400595] vb2: alloc: 1 put: 1 prepare: 27 finish: 26 mmap: 1
[ 355.400599] vb2: get_userptr: 0 put_userptr: 0
[ 355.400604] vb2: attach_dmabuf: 0 detach_dmabuf: 0 map_dmabuf: 0 unmap_dmabuf: 0
[ 355.400609] vb2: get_dmabuf: 0 num_users: 0 vaddr: 0 cookie: 26
kworker/0:1-1198 [000] .... 274.735929: rtos_queue_peek_from_isr_failed: tstamp:8972382855 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 274.903933: rtos_queue_peek_from_isr_failed: tstamp:8977382861 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 275.071964: rtos_queue_peek_from_isr_failed: tstamp:8982382867 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 275.071980: rtos_queue_peek_from_isr_failed: tstamp:8982472165 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 346.087887: rtos_queue_peek_from_isr_failed: tstamp:11201811997 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 346.087891: rtcpu_start: tstamp:11201813344
kworker/0:1-1198 [000] .... 346.087893: rtos_queue_send_from_isr_failed: tstamp:11201827802 queue:0x0b4a7258
kworker/0:1-1198 [000] .... 346.087894: rtos_queue_send_from_isr_failed: tstamp:11201827919 queue:0x0b4aad68
kworker/0:1-1198 [000] .... 346.087895: rtos_queue_send_from_isr_failed: tstamp:11201828031 queue:0x0b4ac998
kworker/0:1-1198 [000] .... 346.087896: rtos_queue_send_from_isr_failed: tstamp:11201828137 queue:0x0b4ae518
kworker/0:1-1198 [000] .... 346.087897: rtos_queue_send_from_isr_failed: tstamp:11201828242 queue:0x0b4af2d8
kworker/0:1-1198 [000] .... 346.087897: rtos_queue_send_from_isr_failed: tstamp:11201828347 queue:0x0b4b0098
kworker/0:1-1198 [000] .... 346.087898: rtos_queue_send_from_isr_failed: tstamp:11201828451 queue:0x0b4b0e58
kworker/0:1-1198 [000] .... 346.087899: rtos_queue_send_from_isr_failed: tstamp:11201828554 queue:0x0b4b1c18
kworker/0:1-1198 [000] .... 346.087900: rtos_queue_send_failed: tstamp:11201829016 queue:0x0b4a7258
kworker/0:1-1198 [000] .... 346.087901: rtos_queue_send_from_isr_failed: tstamp:11201831302 queue:0x0b4a7258
kworker/0:1-1198 [000] .... 346.087901: rtos_queue_send_from_isr_failed: tstamp:11201831418 queue:0x0b4aad68
kworker/0:1-1198 [000] .... 346.087902: rtos_queue_send_from_isr_failed: tstamp:11201831524 queue:0x0b4ac998
kworker/0:1-1198 [000] .... 346.087903: rtos_queue_send_from_isr_failed: tstamp:11201831630 queue:0x0b4ae518
kworker/0:1-1198 [000] .... 346.087903: rtos_queue_send_from_isr_failed: tstamp:11201831735 queue:0x0b4af2d8
kworker/0:1-1198 [000] .... 346.087904: rtos_queue_send_from_isr_failed: tstamp:11201831840 queue:0x0b4b0098
kworker/0:1-1198 [000] .... 346.087904: rtos_queue_send_from_isr_failed: tstamp:11201831949 queue:0x0b4b0e58
kworker/0:1-1198 [000] .... 346.087905: rtos_queue_send_from_isr_failed: tstamp:11201832054 queue:0x0b4b1c18
kworker/0:1-1198 [000] .... 346.087906: rtos_queue_send_failed: tstamp:11201832997 queue:0x0b4a7258
kworker/0:1-1198 [000] .... 346.199930: rtcpu_vinotify_event: tstamp:11206437017 tag:ATOMP_FS channel:0x00 frame:1 vi_tstamp:11206436608 data:0x00000000
kworker/0:1-1198 [000] .... 346.199935: rtcpu_vinotify_event: tstamp:11206466511 tag:CHANSEL_PXL_SOF channel:0x00 frame:1 vi_tstamp:11206466117 data:0x00000001
kworker/0:1-1198 [000] .... 346.199936: rtcpu_vinotify_event: tstamp:11206472568 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:1 vi_tstamp:11206472179 data:0x08000000
kworker/0:1-1198 [000] .... 346.255976: rtos_queue_peek_from_isr_failed: tstamp:11206812428 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 346.255982: rtcpu_vinotify_event: tstamp:11207403085 tag:CHANSEL_PXL_EOF channel:0x00 frame:1 vi_tstamp:11207402298 data:0x04370002
kworker/0:1-1198 [000] .... 346.255985: rtcpu_vinotify_event: tstamp:11207403278 tag:ATOMP_FE channel:0x00 frame:1 vi_tstamp:11207402532 data:0x00000000
kworker/0:1-1198 [000] .... 346.311972: rtcpu_vinotify_event: tstamp:11209214803 tag:ATOMP_FS channel:0x00 frame:2 vi_tstamp:11209214380 data:0x00000000
kworker/0:1-1198 [000] .... 346.311977: rtcpu_vinotify_event: tstamp:11209244323 tag:CHANSEL_PXL_SOF channel:0x00 frame:2 vi_tstamp:11209243890 data:0x00000001
kworker/0:1-1198 [000] .... 346.311979: rtcpu_vinotify_event: tstamp:11209249275 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:2 vi_tstamp:11209248859 data:0x08000000
kworker/0:1-1198 [000] .... 346.367969: rtcpu_vinotify_event: tstamp:11210180860 tag:CHANSEL_PXL_EOF channel:0x00 frame:2 vi_tstamp:11210180071 data:0x04370002
kworker/0:1-1198 [000] .... 346.367976: rtcpu_vinotify_event: tstamp:11210181069 tag:ATOMP_FE channel:0x00 frame:2 vi_tstamp:11210180305 data:0x00000000
kworker/0:1-1198 [000] .... 346.367980: rtos_queue_peek_from_isr_failed: tstamp:11211812412 queue:0x0b4b4500
kworker/0:1-1198 [000] .... 346.423977: rtcpu_vinotify_event: tstamp:11211992575 tag:ATOMP_FS channel:0x00 frame:3 vi_tstamp:11211992154 data:0x00000000
kworker/0:1-1198 [000] .... 346.423984: rtcpu_vinotify_event: tstamp:11212022068 tag:CHANSEL_PXL_SOF channel:0x00 frame:3 vi_tstamp:11212021663 data:0x00000001
kworker/0:1-1198 [000] .... 346.423986: rtcpu_vinotify_event: tstamp:11212028024 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:3 vi_tstamp:11212027605 data:0x08000000
kworker/0:1-1198 [000] .... 346.423989: rtcpu_vinotify_event: tstamp:11212958644 tag:CHANSEL_PXL_EOF channel:0x00 frame:3 vi_tstamp:11212957843 data:0x04370002
kworker/0:1-1198 [000] .... 346.423991: rtcpu_vinotify_event: tstamp:11212958840 tag:ATOMP_FE channel:0x00 frame:3 vi_tstamp:11212958078 data:0x00000000
kworker/0:1-1198 [000] .... 346.480111: rtcpu_vinotify_event: tstamp:11214770344 tag:ATOMP_FS channel:0x00 frame:4 vi_tstamp:11214769926 data:0x00000000
kworker/0:1-1198 [000] .... 346.480118: rtcpu_vinotify_event: tstamp:11214799840 tag:CHANSEL_PXL_SOF channel:0x00 frame:4 vi_tstamp:11214799435 data:0x00000001
kworker/0:1-1198 [000] .... 346.480120: rtcpu_vinotify_event: tstamp:11214805729 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:4 vi_tstamp:11214805316 data:0x08000000
kworker/0:1-1198 [000] .... 346.535973: rtcpu_vinotify_event: tstamp:11215736398 tag:CHANSEL_PXL_EOF channel:0x00 frame:4 vi_tstamp:11215735617 data:0x04370002
kworker/0:1-1198 [000] .... 346.535977: rtcpu_vinotify_event: tstamp:11215736587 tag:ATOMP_FE channel:0x00 frame:4 vi_tstamp:11215735850 data:0x00000000
kworker/0:1-1198 [000] .... 346.535982: rtos_queue_peek_from_isr_failed: tstamp:11216812421 queue:0x0b4b4500
- Start streaming with gst-launch-1.0 nvarguscamerasrc
2. NVIDIA Argus
- command line:
gst-launch-1.0 nvarguscamerasrc \
wbmode=9 \
! 'video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1' \
! nvvidconv flip-method=2 \
! queue ! xvimagesink
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 0.100000, max 2.200000; Exposure Range min 34000, max 550385000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 0
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: PowerService: requested_clock_Hz=27216000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
^Chandling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 0:00:28.006229176
Setting pipeline to READY ...
GST_ARGUS: Cleaning up
GST_ARGUS:
PowerServiceHwVic::cleanupResources
CONSUMER: Done Success
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
3. nvgpu crash (log)
After stopping gst-launch-1.0, the kernel message like the one is printed after stopping streamming when using v4l2 is not shown.
Then, I can still trigger gst-launch-1.0 and get images but if I try to get images again with v4l2-ctl/yavta I can’t. Looks like
the v4l2 application is waiting and then, if you decide to cancel it there you have the kernel crash:
[ 806.628341] ------------[ cut here ]------------
[ 806.633039] WARNING: CPU: 0 PID: 8086 at drivers/media/v4l2-core/videobuf2-core.c:1667 __vb2_queue_cancel+0x198/0x238
[ 806.644056] ---[ end trace c89faff01b7873e5 ]---
[ 806.643653] Modules linked in: bnep fuse bcmdhd cfg80211 nvs_bmi160 nvs mymodule nvgpu bluedroid_pm ip_tables x_tables
[ 806.643745] CPU: 0 PID: 8086 Comm: yavta Not tainted 4.9.140 #974
[ 806.643753] Hardware name: quill (DT)
[ 806.643764] task: ffffffc1c0fa7000 task.stack: ffffffc176800000
[ 806.643780] PC is at __vb2_queue_cancel+0x198/0x238
[ 806.643794] LR is at __vb2_queue_cancel+0x48/0x238
[ 806.643805] pc : [<ffffff8008ae4860>] lr : [<ffffff8008ae4710>] pstate: 60400045
[ 806.643812] sp : ffffffc176803ad0
[ 806.643820] x29: ffffffc176803ad0 x28: 0000000000000009
[ 806.643839] x27: ffffffc176803de8 x26: ffffffc1df6e8cc0
[ 806.643856] x25: ffffff8009354000 x24: 0000000000000001
[ 806.643873] x23: ffffffc1eadfb850 x22: ffffffc1eb507018
[ 806.643888] x21: ffffffc1eb507b58 x20: ffffffc1eb507bb8
[ 806.643904] x19: ffffffc1eb507b58 x18: 00000000fffffffe
[ 806.643919] x17: 0000000000000002 x16: 0000000000000000
[ 806.643933] x15: 0000000000000001 x14: ffffffffffffffff
[ 806.643948] x13: ffffffc176803a10 x12: ffffffc176803914
[ 806.643963] x11: 000000000000000b x10: ffffffc1768038d0
[ 806.643978] x9 : 0000000000000002 x8 : 0000000000000002
[ 806.643993] x7 : ffffff8008f67290 x6 : 0000000000000090
[ 806.644008] x5 : 000000000000008d x4 : 0000000000000001
[ 806.644022] x3 : 0000000000000000 x2 : 0000000000000000
[ 806.644036] x1 : 0000000000000000 x0 : 0000000000000008
[ 806.648689] Call trace:
[ 806.648709] [<ffffff8008ae4860>] __vb2_queue_cancel+0x198/0x238
[ 806.648727] [<ffffff8008ae4e74>] vb2_core_queue_release+0x2c/0x58
[ 806.648742] [<ffffff8008ae702c>] _vb2_fop_release+0x84/0xa0
[ 806.648758] [<ffffff8008aecb40>] tegra_channel_close+0x58/0x130
[ 806.648775] [<ffffff8008ac0fc4>] v4l2_release+0x4c/0x98
[ 806.648795] [<ffffff8008256668>] __fput+0x90/0x1c8
[ 806.648808] [<ffffff8008256818>] ____fput+0x20/0x30
[ 806.648827] [<ffffff80080d89e8>] task_work_run+0xb8/0xd0
[ 806.648844] [<ffffff80080b8cc4>] do_exit+0x3ac/0xa10
[ 806.648858] [<ffffff80080b93b4>] do_group_exit+0x3c/0xa0
[ 806.648874] [<ffffff80080c6970>] get_signal+0x2a0/0x580
[ 806.648890] [<ffffff800808af64>] do_signal+0x7c/0x530
[ 806.648904] [<ffffff800808b598>] do_notify_resume+0x90/0xb0
[ 806.648918] [<ffffff8008083754>] work_pending+0x8/0x10
Any idea about this issue?
Thank you in advance for your support.
