OK. I found a way.
I basically followed the instructions in bmcbm’s github page.
Only point was … the files I was supposed to copy did not exist at all in the new distro. So I had to pick them from my old one.
Here is a modified script which does the job with missing files all put in one place called TMPL_PATH
Here is how it differs from the one by bmcbm:
- I remove the symlinks pointing to
/dev/null
- I copy the files into
/lib/systemd/system
, because the systemctl enable
command actually links them into /etc/systemd/system/systemd-suspend.service.requires
and similar folders, and does it properly.
TMP_PATH=/var/tmp
TMPL_PATH=/home/user/missing-scripts
echo "options nvidia NVreg_PreserveVideoMemoryAllocations=1 NVreg_TemporaryFilePath=${TMP_PATH}" | sudo tee /etc/modprobe.d/nvidia-power-management.conf
sudo rm -f /etc/systemd/system/nvidia-suspend.service # if /dev/null
sudo rm -f /etc/systemd/system/nvidia-resume.service # if /dev/null
sudo rm -f /etc/systemd/system/nvidia-hibernate.service # if /dev/null
sudo install --mode 644 "${TMPL_PATH}/nvidia-suspend.service" /lib/systemd/system
sudo install --mode 644 "${TMPL_PATH}/nvidia-hibernate.service" /lib/systemd/system
sudo install --mode 644 "${TMPL_PATH}/nvidia-resume.service" /lib/systemd/system
sudo install --mode 755 "${TMPL_PATH}/nvidia" /lib/systemd/system-sleep
sudo install --mode 755 "${TMPL_PATH}/nvidia-sleep.sh" /usr/bin
sudo systemctl enable nvidia-suspend.service
sudo systemctl enable nvidia-hibernate.service
sudo systemctl enable nvidia-resume.service
And here are the 5 files missing to put into /home/user/missing-scripts
nvidia-suspend.service:
[Unit]
Description=NVIDIA system suspend actions
Before=systemd-suspend.service
[Service]
Type=oneshot
ExecStart=/usr/bin/logger -t suspend -s "nvidia-suspend.service"
ExecStart=/usr/bin/nvidia-sleep.sh "suspend"
[Install]
RequiredBy=systemd-suspend.service
nvidia-resume.service:
[Unit]
Description=NVIDIA system resume actions
After=systemd-suspend.service
After=systemd-hibernate.service
[Service]
Type=oneshot
ExecStart=/usr/bin/logger -t suspend -s "nvidia-resume.service"
ExecStart=/usr/bin/nvidia-sleep.sh "resume"
[Install]
RequiredBy=systemd-hibernate.service
nvidia-hibernate.service:
[Unit]
Description=NVIDIA system hibernate actions
Before=systemd-hibernate.service
[Service]
Type=oneshot
ExecStart=/usr/bin/logger -t hibernate -s "nvidia-hibernate.service"
ExecStart=/usr/bin/nvidia-sleep.sh "hibernate"
[Install]
nvidia:
#!/bin/sh
case "$1" in
post)
esac
nvidia-sleep.sh:
#!/bin/bash
if [ ! -f /proc/driver/nvidia/suspend ]; then
exit 0
fi
RUN_DIR="/var/run/nvidia-sleep"
XORG_VT_FILE="${RUN_DIR}"/Xorg.vt_number
PATH="/bin:/usr/bin"
case "$1" in
suspend|hibernate)
mkdir -p "${RUN_DIR}"
fgconsole > "${XORG_VT_FILE}"
chvt 63
if [[ $? -ne 0 ]]; then
exit $?
fi
echo "$1" > /proc/driver/nvidia/suspend
exit $?
resume)
# Check if Xorg was determined to be running at the time
# of suspend, and whether its VT was recorded. If so,
# attempt to switch back to this VT.
if [[ -f "${XORG_VT_FILE}" ]]; then
XORG_PID=$(cat "${XORG_VT_FILE}")
rm "${XORG_VT_FILE}"
chvt "${XORG_PID}"
fi
exit 0
exit 1
esac
I have no experience with the hibernate mode though. I suggest you proceed carefully and backup config files if you try that. No need to claim you lost 10,000 BTC in mining revenues because of me.
Additional edit: in my case, I also had to force the linux kernel to have a less conservative view of the BIOS ACPI capabilities. I used the following script I found here.
VERSION="$(sudo strings /sys/firmware/acpi/tables/DSDT | grep -i 'windows ' | sort | tail -1)"
echo 'Linux kernel command-line parameters required: acpi_osi=! "acpi_osi='$VERSION'"'
config() {
sed -n '/.*linux[[:space:]].*root=\(.*\)/{s//BOOT_IMAGE=\1/ p;q;}' /boot/grub/grub.cfg;
echo "Existing Command Line: ` config `"
sudo sed -i "s/^\(GRUB_CMDLINE_LINUX=.*\)\"$/\1 acpi_osi=! \\\\\"acpi_osi=$VERSION\\\\\"\"/" /etc/default/grub
sudo update-grub
echo "Modified Command Line: ` config `"
