I recently (4 weeks ago) bought a laptop with a Nvidia 3060 RTX. However, I haven’t been able to make it work since, using Ubuntu 20.04.
The problem:
As soon as I install the Nvidia drivers (be it 510 or 470) and restart, the computer won’t run past the loading screen. I tried opening a terminal with CTRL + ALT + F2-7, but I can’t type anything.
The only way for it to launch is to go in recovery mode, root terminal, and type prime-select intel (or plainly removing the driver packages). Only then does the GUI launch.
Already tried:
I tried to install / remove / purge / reinstall the drivers a few times each (470 & 510), through the command line, with the .run file, and with Ubuntu Software & Updates > Additional drivers, with no success.
I also tried switching back and forth to
prime-select intelandprime-select nvidiaafter installing, as I’ve seen a few comments saying it was enough to solve their problem. But no. -
Finally, I tried adding the
graphics-driver/ppaand reinstall the drivers afterwards. But you already know how it ended. -
The .run file actually gave another outcome:
ERROR: Unable to load the 'nvidia-drm' kernel module. ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.By the way, here’s what
/var/log/nvidia-installer.logsays, if it can be of any help:nvidia-installer log file '/var/log/nvidia-installer.log' creation time: Thu Feb 17 14:21:48 2022 installer version: 510.54 PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin nvidia-installer command line: ./nvidia-installer Using: nvidia-installer ncurses v6 user interface -> Detected 16 CPUs online; setting concurrency level to 16. -> Installing NVIDIA driver version 510.54. -> There appears to already be a driver installed on your system (version: 510.54). As part of installing this driver (version: 510.54), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation) -> An alternate method of installing the NVIDIA driver was detected. (This is usually a package provided by your distributor.) A driver installed via that method may integrate better with your system than a driver installed by nvidia-installer. Please review the message provided by the maintainer of this alternate installation method and decide how to proceed: The NVIDIA driver provided by Ubuntu can be installed by launching the "Software & Updates" application, and by selecting the NVIDIA driver from the "Additional Drivers" tab. (Answer: Continue installation) -> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes) -> Install NVIDIA's 32-bit compatibility libraries? (Answer: No) -> Uninstalling the previous installation with /usr/bin/nvidia-uninstall. Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'... Found libglvnd libraries: libGLESv2.so.2 libGLESv1_CM.so.1 libOpenGL.so.0 libEGL.so.1 libGLX.so.0 libGL.so.1 Found non-libglvnd libraries: Missing libraries: libglvnd appears to be installed. Will not install libglvnd libraries. -> Skipping GLVND file: "libOpenGL.so.0" -> Skipping GLVND file: "libOpenGL.so" -> Skipping GLVND file: "libGLESv1_CM.so.1.2.0" -> Skipping GLVND file: "libGLESv1_CM.so.1" -> Skipping GLVND file: "libGLESv1_CM.so" -> Skipping GLVND file: "libGLESv2.so.2.1.0" -> Skipping GLVND file: "libGLESv2.so.2" -> Skipping GLVND file: "libGLESv2.so" -> Skipping GLVND file: "libGLdispatch.so.0" -> Skipping GLVND file: "libGLX.so.0" -> Skipping GLVND file: "libGLX.so" -> Skipping GLVND file: "libGL.so.1.7.0" -> Skipping GLVND file: "libGL.so.1" -> Skipping GLVND file: "libGL.so" -> Skipping GLVND file: "libEGL.so.1.1.0" -> Skipping GLVND file: "libEGL.so.1" -> Skipping GLVND file: "libEGL.so" Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d -> Searching for conflicting files: -> done. -> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (510.54): executing: '/usr/sbin/ldconfig'... executing: '/usr/bin/systemctl daemon-reload'... -> done. -> Driver file installation is complete. -> Installing DKMS kernel module: -> done. ERROR: Unable to load the 'nvidia-drm' kernel module. ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
I come here as a last resort after all this.
Here’s the bug report run from recovery mode:
nvidia-bug-report.log.gz (107.0 KB)
Thanks for your help!
