Continuing the discussion from Enabling disk encryption and secureboot on internal device 36.3:
What is the status on using disk encryption with UEFI secureboot in release 36.3? We require both features.
hello robert70,
may I know what’s the failure you’ve seen,
please double check you’ve all UEFI payloads been signed with UEFI security keys.
Hi JerryChang,
I have attached the boot log:
uefi-secureboot.log (43.0 KB)
The Jetson Orin NX reboots after this failure.
I have followed the UEFI payload signing instructions using the db key.
Update: I just figured out how to solve the problem.
I was including an in_sym_key
of all zeros as it was setup in the ekb generation example:
python3 gen_ekb.py -chip t234 -oem_k1_key oem_k1.key \
-in_sym_key sym_t234.key \
-in_sym_key2 sym2_t234.key \
-in_auth_key auth_t234.key \
-out eks_t234.img
By removing the line, -in_sym_key sym_t234.key \
, the L4T UEFI loader no longer expects the kernel payloads to be encrypted, so they verify just fine.
