ok. but how it’s works for rhel 7u6 because i used the same grid version for rhel 7u9 NVIDIA-Linux-x86_64-390.115-grid.run
In your initial post you had compiler errors, the 390.115 likely being too old to compile against the centos 7.9 kernel. Isn’t there a 460-grid driver available from the portal?
am unable to login the portal. we have our organization account let me try with that.
460-grid driver will resolve this issue ?
It should do the trick
v390.115 released mid-2019
centos 7.9 late-2020
v460 late-2020, after centos 7.9
It also depends on the vgpu manager version and hypervisor you’re running. I don’t know which version you have but you said you’re running on vmware. Please check for vmware downloads and which vgpu manager version you’re running.
vsphere 6.7 using
before we have vpshere 6.0 and recently we migrated to 6.7
VIDIA-vGPU-VMware_ESXi_6.0_Host_Driver 390.113-1OEM.600.0.0.2494585 NVIDIA VMwareAccepted 2019-05-31
so do i need to reconfigure the esxi with latest ?
According to
https://docs.nvidia.com/grid/get-grid-version.html
You seem to be running vgpu 6.4 which is really old so you need to upgrade that in order to have centos 7.9 support.
The grid drivers only run on manager versions equal or higher.
https://docs.nvidia.com/grid/latest/pdf/grid-vgpu-release-notes-red-hat-el-kvm.pdf
You might check if the normal 390.144 graphics driver works on your vpu setup, but I don’t expect that.
https://http.download.nvidia.com/XFree86/Linux-x86_64/390.144/
yes it woks only for 7u6 but not 7u9
Out of curiosity, what errors do the 390.144 give on 7.9 (dmesg output)?
support.txt (122.7 KB)
nvidia-smi vgpu
Not supported devices in vGPU mode
why it’s showing this error
Please check if this applies:
https://forums.developer.nvidia.com/t/solved-m10-with-esxi-6-5-vgpu-device-not-supported/162576/7?u=generix
one more observation.
gpuvm
Xserver unix:0, PCI ID 0:92:0:0, vGPU: Not set, GPU maximum memory 16738636KB
vgpu not set
