I’m running a VM RHEL 7 or 8 hosted on ESXi 6.5U3 with a K2 in shared direct mode. The host has been in production fine for all Windows vGPUs. I followed the NVIDIA and RHEL documentation and disabled/blacklisted nouveau driver, installed the development tools group and verified the kernel versions match. The driver is failing in the make section if the installation. Please advise how to proceed. I have a data scientist that is wanting this soon!
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Wed Jan 29 14:20:40 2020
installer version: 367.134
PATH: /usr/lib64/qt-3.3/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
→ Detected 4 CPUs online; setting concurrency level to 4.
→ Tagging shared libraries with chcon -t textrel_shlib_t.
→ License accepted.
→ Installing NVIDIA driver version 367.134.
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Kernel source path: ‘/lib/modules/3.10.0-1062.9.1.el7.x86_64/source’
→ Kernel output path: ‘/lib/modules/3.10.0-1062.9.1.el7.x86_64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-1062.9.1.el7.x86_64/source” SYSOUT=“/lib/modules/3.10.0-1062.9.1.el7.x86_64/build”’…
rm -f -r conftest
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-1062.9.1.el7.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-1062.9.1.el7.x86_64/source M=/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-1062.9.1.el7.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-1062.9.1.el7.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64' /usr/bin/make -C /lib/modules/3.10.0-1062.9.1.el7.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64 \ KBUILD_EXTMOD="/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel" -f /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/Makefile \ clean make[1]: Leaving directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-1062.9.1.el7.x86_64/source” SYSOUT=“/lib/modules/3.10.0-1062.9.1.el7.x86_64/build”’…
/usr/bin/make “CC=cc” KBUILD_OUTPUT=/lib/modules/3.10.0-1062.9.1.el7.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-1062.9.1.el7.x86_64/source M=/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-1062.9.1.el7.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-1062.9.1.el7.x86_64/build NV_KERNEL_MODULES=“nvidia nvidia-uvm nvidia-modeset nvidia-drm” INSTALL_MOD_DIR=kernel/drivers/video modules
make[1]: Entering directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64' /usr/bin/make -C /lib/modules/3.10.0-1062.9.1.el7.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64 \ KBUILD_EXTMOD="/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel" -f /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/Makefile \ modules SYMLINK /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-kernel.o SYMLINK /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nv-modeset-kernel.o CONFTEST: remap_pfn_range CONFTEST: follow_pfn CONFTEST: INIT_WORK CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: list_is_first CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: kmem_cache_create CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: drm_driver_has_set_busid CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_parse_phandle CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: timer_setup CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: mm_context_t CONFTEST: get_user_pages CONFTEST: vm_fault_has_address CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: kref_read CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_functions_have_name_arg CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg CONFTEST: dom0_kernel_present CONFTEST: drm_available CONFTEST: nvidia_grid_build CONFTEST: drm_atomic_available CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv_uvm_interface.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_pci.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ebridge_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ibmnpu_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_stubs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_kepler.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_maxwell.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/nv-kthread-q.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/nv-kthread-q-selftest.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_kernel_events.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_kernel_counters.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_debug_session.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_mmu_mgmt.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_full_fault_buffer.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/mmu_fmt.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/gmmu_fmt.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu_page_fault.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.o In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/drm/drmP.h:81:0, from /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-priv.h:30, from /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c:25: /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c:605:23: error: ‘DRM_CONTROL_ALLOW’ undeclared here (not in a function) DRM_CONTROL_ALLOW|DRM_RENDER_ALLOW|DRM_UNLOCKED), ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/drm/drm_ioctl.h:162:12: note: in definition of macro ‘DRM_IOCTL_DEF_DRV’ .flags = _flags, \ ^ /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c: In function ‘nvidia_register_drm_device’: /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c:743:5: error: implicit declaration of function ‘drm_dev_free’ [-Werror=implicit-function-declaration] NV_DRM_DEV_FREE(dev); ^ cc1: some warnings being treated as errors make[3]: *** [/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.o] Error 1 CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-mmap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-linux.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.c: In function ‘nvidia_drm_gem_new’: /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.c:77:5: error: implicit declaration of function ‘drm_gem_object_unreference_unlocked’ [-Werror=implicit-function-declaration] drm_gem_object_unreference_unlocked(&nv_gem->base); ^ cc1: some warnings being treated as errors make[3]: *** [/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.o] Error 1 CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nv-pci-table.o ld -r -o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-frontend.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-instance.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-acpi.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-chrdev.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-cray.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-dma.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-gvi.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-i2c.o /tmp/selfgz2746/NVIDIA-Linux- x86_64-367.134-grid/kernel/nvidia/nv-mempool.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mmap.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-p2p.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pat.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-procfs.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-usermap.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vm.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vtophys.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-mlock.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-pci.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-registry.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-usermap.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pci-table.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_linux.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_pci.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ebridge_linux.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ibmnpu_linux.o ld -r -o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nvidia-modeset-linux.o LD [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia.o LD [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset.o LD [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm.o make[3]: Target __build’ not remade because of errors.
make[2]: *** [module/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel] Error 2
make[2]: Target modules' not remade because of errors. make[1]: *** [sub-make] Error 2 make[1]: Target modules’ not remade because of errors.
make[1]: Leaving directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64' make: *** [modules] Error 2 -> Error. ERROR: An error occurred while performing the step: "Building kernel modules". See /var/log/nvidia-installer.log for details. -> The command cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/lib/modules/3.10.0-1062.9.1.el7.x86_64/source” SYSOUT=“/lib/modules/3.10.0-1062.9.1.el7.x86_64/build”` failed with the following output:
make[1]: Entering directory /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64' /usr/bin/make -C /lib/modules/3.10.0-1062.9.1.el7.x86_64/build \ KBUILD_SRC=/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64 \ KBUILD_EXTMOD="/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel" -f /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/Makefile \ modules SYMLINK /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-kernel.o SYMLINK /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nv-modeset-kernel.o CONFTEST: remap_pfn_range CONFTEST: follow_pfn CONFTEST: INIT_WORK CONFTEST: vmap CONFTEST: set_pages_uc CONFTEST: list_is_first CONFTEST: set_memory_uc CONFTEST: set_memory_array_uc CONFTEST: change_page_attr CONFTEST: pci_get_class CONFTEST: pci_choose_state CONFTEST: vm_insert_page CONFTEST: acpi_device_id CONFTEST: acquire_console_sem CONFTEST: console_lock CONFTEST: kmem_cache_create CONFTEST: on_each_cpu CONFTEST: smp_call_function CONFTEST: acpi_evaluate_integer CONFTEST: ioremap_cache CONFTEST: ioremap_wc CONFTEST: acpi_walk_namespace CONFTEST: pci_domain_nr CONFTEST: pci_dma_mapping_error CONFTEST: sg_alloc_table CONFTEST: sg_init_table CONFTEST: pci_get_domain_bus_and_slot CONFTEST: get_num_physpages CONFTEST: efi_enabled CONFTEST: proc_create_data CONFTEST: pde_data CONFTEST: proc_remove CONFTEST: pm_vt_switch_required CONFTEST: drm_driver_has_set_busid CONFTEST: xen_ioemu_inject_msi CONFTEST: phys_to_dma CONFTEST: get_dma_ops CONFTEST: write_cr4 CONFTEST: of_parse_phandle CONFTEST: for_each_online_node CONFTEST: node_end_pfn CONFTEST: pci_bus_address CONFTEST: request_threaded_irq CONFTEST: register_cpu_notifier CONFTEST: cpuhp_setup_state CONFTEST: timer_setup CONFTEST: remap_page_range CONFTEST: address_space_init_once CONFTEST: kbasename CONFTEST: fatal_signal_pending CONFTEST: list_cut_position CONFTEST: vzalloc CONFTEST: wait_on_bit_lock_argument_count CONFTEST: bitmap_clear CONFTEST: usleep_range CONFTEST: radix_tree_empty CONFTEST: drm_dev_unref CONFTEST: drm_reinit_primary_mode_group CONFTEST: drm_atomic_set_mode_for_crtc CONFTEST: drm_atomic_clean_old_fb CONFTEST: get_user_pages_remote CONFTEST: drm_gem_object_lookup CONFTEST: drm_atomic_state_free CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs CONFTEST: i2c_adapter CONFTEST: pm_message_t CONFTEST: irq_handler_t CONFTEST: acpi_device_ops CONFTEST: acpi_op_remove CONFTEST: outer_flush_all CONFTEST: proc_dir_entry CONFTEST: scatterlist CONFTEST: sg_table CONFTEST: file_operations CONFTEST: vm_operations_struct CONFTEST: atomic_long_type CONFTEST: pci_save_state CONFTEST: file_inode CONFTEST: task_struct CONFTEST: kuid_t CONFTEST: dma_ops CONFTEST: dma_map_ops CONFTEST: noncoherent_swiotlb_dma_ops CONFTEST: vm_fault_present CONFTEST: fault_flags CONFTEST: atomic64_type CONFTEST: address_space CONFTEST: backing_dev_info CONFTEST: kernel_write CONFTEST: strnstr CONFTEST: iterate_dir CONFTEST: kstrtoull CONFTEST: mm_context_t CONFTEST: get_user_pages CONFTEST: vm_fault_has_address CONFTEST: vm_ops_fault_removed_vma_arg CONFTEST: kref_read CONFTEST: drm_bus_present CONFTEST: drm_bus_has_bus_type CONFTEST: drm_bus_has_get_irq CONFTEST: drm_bus_has_get_name CONFTEST: drm_driver_has_legacy_dev_list CONFTEST: drm_crtc_state_has_connectors_changed CONFTEST: drm_init_functions_have_name_arg CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg CONFTEST: drm_driver_unload_has_int_return_type CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg CONFTEST: dom0_kernel_present CONFTEST: drm_available CONFTEST: nvidia_grid_build CONFTEST: drm_atomic_available CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-frontend.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-instance.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-acpi.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-chrdev.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-cray.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-dma.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-gvi.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-i2c.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mempool.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mmap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-p2p.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pat.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-procfs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-usermap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vm.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vtophys.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-interface.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-mlock.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-pci.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-registry.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-usermap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-modeset-interface.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pci-table.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv_uvm_interface.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_pci.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ebridge_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ibmnpu_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_utils.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_common.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_stubs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_kepler.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_maxwell.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_page_migration_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/nvstatus.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/nv-kthread-q.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/nv-kthread-q-selftest.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_kernel_events.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_kernel_counters.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_debug_session.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_mmu_mgmt.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_full_fault_buffer.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/mmu_fmt.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/gmmu_fmt.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tools.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_global.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_procfs.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_space.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu_semaphore.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mem.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_rm_mem.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_channel.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_lock.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_hal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_tree.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_allocator.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_range.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_block.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_group.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu_page_fault.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_events.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_module.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mmu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pte_batch.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tlb_batch.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_push.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pushbuffer.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_thread_context.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tracker.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler_ce.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler_host.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kepler_mmu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_maxwell.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_maxwell_host.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_ce.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_host.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_mmu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_policy.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_utils.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kvmalloc.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pmm_gpu.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_migrate.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_map_external.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_user_channel.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_hmm.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_heuristics.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_thrashing.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_prefetch.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_test_rng.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_tree_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_allocator_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mem_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_rm_mem_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_page_tree_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_tracker_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_push_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_channel_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_ce_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_lock_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_utils_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_kvmalloc_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_pmm_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_events_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_perf_module_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_mmu_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_va_block_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm/uvm8_range_group_tree_test.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nvidia-modeset-linux.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.o In file included from /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/drm/drmP.h:81:0, from /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-priv.h:30, from /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c:25: /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c:605:23: error: ‘DRM_CONTROL_ALLOW’ undeclared here (not in a function) DRM_CONTROL_ALLOW|DRM_RENDER_ALLOW|DRM_UNLOCKED), ^ /usr/src/kernels/3.10.0-1062.9.1.el7.x86_64/include/drm/drm_ioctl.h:162:12: note: in definition of macro ‘DRM_IOCTL_DEF_DRV’ .flags = _flags, \ ^ /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c: In function ‘nvidia_register_drm_device’: /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.c:743:5: error: implicit declaration of function ‘drm_dev_free’ [-Werror=implicit-function-declaration] NV_DRM_DEV_FREE(dev); ^ cc1: some warnings being treated as errors make[3]: *** [/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-drv.o] Error 1 CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-utils.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-crtc.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-encoder.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-connector.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-fb.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-modeset.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-mmap.o CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-linux.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.c: In function ‘nvidia_drm_gem_new’: /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.c:77:5: error: implicit declaration of function ‘drm_gem_object_unreference_unlocked’ [-Werror=implicit-function-declaration] drm_gem_object_unreference_unlocked(&nv_gem->base); ^ cc1: some warnings being treated as errors make[3]: *** [/tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nvidia-drm-gem.o] Error 1 CC [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-drm/nv-pci-table.o ld -r -o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-frontend.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-instance.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-acpi.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-chrdev.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-cray.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-dma.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-gvi.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-i2c.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mempool.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-mmap.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-p2p.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pat.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-procfs.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-usermap.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vm.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-vtophys.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-mlock.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-pci.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-registry.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/os-usermap.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv-pci-table.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_linux.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/nvlink_pci.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ebridge_linux.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia/ibmnpu_linux.o ld -r -o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset/nvidia-modeset-linux.o LD [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia.o LD [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-modeset.o LD [M] /tmp/selfgz2746/NVIDIA-Linux-x86_64-367.134-grid/kernel/nvidia-uvm.o make[3]: Target __build’ not remade because of errors.
make[1]: Leaving directory `/usr/src/kernels/3.10.0-1062.9.1.el7.x86_64’
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
