Hi
I tried to install latest Nvidia driver on Debian Sid but it won’t work …
I am stuck at following error message :
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Sat Jul 11 12:30:19 2020
installer version: 450.57
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
-a
–kernel-source-path=/home/claude/Kernel/linux
Using: nvidia-installer ncurses v6 user interface
→ Detected 16 CPUs online; setting concurrency level to 16.
→ Installing NVIDIA driver version 450.57.
→ Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: No)
→ Performing CC sanity check with CC=“/usr/bin/cc”.
→ Performing CC check.
→ Using the kernel source path ‘/home/claude/Kernel/linux’ as specified by the ‘–kernel-source-path’ commandline option.
→ Kernel source path: ‘/home/claude/Kernel/linux’
→ Kernel output path: ‘/home/claude/Kernel/linux’
→ Performing Compiler check.
→ Performing Dom0 check.
→ Performing Xen check.
→ Performing PREEMPT_RT check.
→ Performing vgpu_kvm check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; /usr/bin/make -k -j16 clean NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/home/claude/Kernel/linux” SYSOUT=“/home/claude/Kernel/linux”’…
rm -f -r conftest
make[1]: Entering directory ‘/home/claude/src/linux’
make[1]: Leaving directory ‘/home/claude/src/linux’
→ Building kernel modules
executing: ‘cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/home/claude/Kernel/linux” SYSOUT=“/home/claude/Kernel/linux”’…
scripts/Makefile.lib:8: ‘always’ is deprecated. Please use ‘always-y’ instead
SYMLINK /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: acquire_console_sem
CONFTEST: console_lock
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: sg_alloc_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_get_property
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_remove_bus_device
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: backlight_device_register
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: do_gettimeofday
CONFTEST: kernel_read
CONFTEST: kernel_write
CONFTEST: kthread_create_on_node
CONFTEST: of_find_matching_node
CONFTEST: dev_is_pci
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_replace_slot
CONFTEST: radix_tree_empty
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_framebuffer_get
CONFTEST: drm_gem_object_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_present_kthread_create_on_node
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: file_operations
CONFTEST: file_inode
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: backlight_properties_type
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: vmbus_channel_has_ringbuffer_page
CONFTEST: device_driver_of_match_table
CONFTEST: device_of_node
CONFTEST: node_states_n_memory
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: timeval
CONFTEST: mm_has_mmap_lock
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: vm_fault_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_hyperv_available
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: drm_available
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-mlock.o
/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.c: In function ‘nvidia_mmap’:
/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.c:662:9: warning: unused variable ‘i’ [-Wunused-variable]
662 | int i = 0;
/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.c: In function ‘nv_encode_caching’:
/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.c:334:16: warning: this statement may fall through [-Wimplicit-fallthrough=]
334 | if (NV_ALLOW_CACHING(memory_type))
/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.c:336:9: note: here
336 | default:
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-caps.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/procfs_nvswitch.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ampere.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ampere_ce.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ampere_host.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ampere_mmu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu_isr.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_va_space_mm.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_volta_host.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_volta_mmu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_volta.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_turing.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_turing_mmu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_turing_host.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_populate_pageable.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_migrate_pageable.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ats_ibm.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ats_faults.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm/uvm8_thread_context_test.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-prime-fence.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm/nvidia-drm-format.o
LD [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.o
LD [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset.o
ld -r -o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-frontend.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pci.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-acpi.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-cray.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-dma.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-i2c.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-p2p.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pat.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-procfs.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-usermap.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-vm.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-vtophys.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-mlock.o /tmp/selfgz3223/NVIDIA-Linux-x
86_64-450.57/kernel/nvidia/os-pci.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-registry.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-usermap.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pci-table.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-kthread-q.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-memdbg.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-report-err.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-rsync.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-msi.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-caps.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nvlink_linux.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nvlink
_caps.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/linux_nvswitch.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/procfs_nvswitch.o
ld -r -o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.o
MODPOST /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/Module.symvers
ERROR: modpost: “drm_atomic_helper_connector_reset” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “nvKmsKapiGetFunctionsTable” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_atomic_helper_crtc_reset” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_atomic_helper_connector_duplicate_state” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_atomic_helper_plane_reset” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_gem_dumb_destroy” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “vm_insert_page” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_gem_prime_import” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_mode_create” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_atomic_helper_plane_duplicate_state” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “drm_mode_object_find” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “vmf_insert_pfn” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-drm.ko] undefined!
ERROR: modpost: “nvidia_unregister_module” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset.ko] undefined!
ERROR: modpost: “nvidia_get_rm_ops” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset.ko] undefined!
ERROR: modpost: “nvidia_register_module” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset.ko] undefined!
ERROR: modpost: “__x86_indirect_thunk_rbp” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-modeset.ko] undefined!
ERROR: modpost: “nvUvmInterfaceSessionCreate” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfacePmaAllocPages” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDupAllocation” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfacePmaUnregisterEvictionCallbacks” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “__bitmap_shift_right” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceEnableAccessCntr” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetP2PCaps” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceChannelAllocate” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfacePmaPinPages” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceRegisterUvmCallbacks” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceAddressSpaceDestroy” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceUnregisterGpu” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceAddressSpaceCreate” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDeviceDestroy” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDupMemory” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceSessionDestroy” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “__mmu_notifier_register” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetPmaObject” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetChannelResourcePtes” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceP2pObjectCreate” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetEccInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfacePmaRegisterEvictionCallbacks” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceMemoryFree” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceFreeDupedHandle” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDeRegisterUvmOps” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceServiceDeviceInterruptsRM” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDeviceCreate” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceInitFaultInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceBindChannelResources” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetGpuInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceReportNonReplayableFault” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceQueryCopyEnginesCaps” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceReleaseChannelResources” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceMemoryAllocFB” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDestroyFaultInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceStopChannel” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “vm_insert_page” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDestroyAccessCntrInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceHasPendingNonReplayableFaults” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceRetainChannel” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetFbInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetNonReplayableFaults” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceP2pObjectDestroy” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceRegisterGpu” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceGetExternalAllocPtes” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDupAddressSpace” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceOwnPageFaultIntr” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceMemoryCpuUnMap” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceSetPageDirectory” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfacePmaFreePages” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceRetainChannelResources” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceMemoryCpuMap” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceMemoryAllocSys” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceReleaseChannel” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceInitAccessCntrInfo” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceUnsetPageDirectory” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceQueryCaps” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceChannelDestroy” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “nvUvmInterfaceDisableAccessCntr” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia-uvm.ko] undefined!
ERROR: modpost: “jiffies_to_timespec64” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “vga_set_legacy_decoding” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “pm_vt_switch_unregister” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “pm_vt_switch_required” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “vga_tryget” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “__virt_addr_valid” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “vm_insert_page” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “pcibios_resource_to_bus” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “ioremap_cache” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “__x86_indirect_thunk_rdi” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “set_memory_uc” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
ERROR: modpost: “cpufreq_get” [/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia.ko] undefined!
make[2]: *** [scripts/Makefile.modpost:111: /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/Module.symvers] Error 1
make[2]: *** Deleting file ‘/tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/Module.symvers’
make[2]: Target ‘__modpost’ not remade because of errors.
make[1]: *** [Makefile:1669: modules] Error 2
make: *** [Makefile:81: modules] Error 2
→ Error.
ERROR: An error occurred while performing the step: “Building kernel modules”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j16 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/home/claude/Kernel/linux" SYSOUT="/home/claude/Kernel/linux" failed with the following output:
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: kbasename
CONFTEST: vzalloc
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: proc_ops
CONFTEST: timeval
662 | int i = 0;
336 | default:
ld -r -o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-frontend.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pci.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-acpi.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-cray.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-dma.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-i2c.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-mmap.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-p2p.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pat.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-procfs.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-usermap.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-vm.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-vtophys.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-mlock.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-pci.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-registry.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/os-usermap.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-pci-table.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-kthread-q.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-memdbg.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-report-err.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-rsync.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-msi.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv-caps.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nvlink_linux.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/nvlink_caps.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/linux_nvswitch.o /tmp/selfgz3223/NVIDIA-Linux-x86_64-450.57/kernel/nvidia/procfs_nvswitch.o
→ Checking to see whether the nvidia kernel module was successfully built
executing: ‘cd ./kernel; /usr/bin/make -k -j16 NV_KERNEL_MODULES=“nvidia” NV_EXCLUDE_KERNEL_MODULES=“” SYSSRC=“/home/claude/Kernel/linux” SYSOUT=“/home/claude/Kernel/linux”’…
→ Error.
ERROR: An error occurred while performing the step: “Checking to see whether the nvidia kernel module was successfully built”. See /var/log/nvidia-installer.log for details.
→ The command cd ./kernel; /usr/bin/make -k -j16 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/home/claude/Kernel/linux" SYSOUT="/home/claude/Kernel/linux" failed with the following output:
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
Any help would be appreciated
