Trying to install nvidia-390.run on Ubuntu 16.04 with latest kernel 4.18 rc3
Hello!
Running Lubuntu 16.04, GPU: GTX 750 TI, CPU:i5 4690K 4.8GHZ
I have recently, successfully installed kernel 4.18 rc3 from the mainline ppa and subsequently tried to install the corresponding NVIDIA-Linux-x86_64-390.67.run driver.
http://kernel.ubuntu.com/~kernel-ppa/mainline/v4.18-rc3/
I had to install gcc-7 from the ubuntu-toolchain-r repository, as the nvidia installation script warned me that the kernel was compiled using gcc-7, while gcc-5 was currently installed. After that I created Symlinks for all the gcc-5 binaries to point to gcc-7 in order to fix the cc path error and the script proceeded onward.
Unfortunately, the nvidia kernel module still fails to be created and the log output is simply beyond my level of expertise.
Log:
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Jul  3 09:42:31 2018
installer version: 390.67
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
nvidia-installer command line:
    ./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
-> Installing NVIDIA driver version 390.67.
-> Running distribution scripts
   executing: '/usr/lib/nvidia/pre-install'...
-> done.
-> The distribution-provided pre-install script failed!  Are you sure you want to continue? (Answer: Continue installation)
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Kernel source path: '/lib/modules/4.18.0-041800rc3-generic/build'
-> Kernel output path: '/lib/modules/4.18.0-041800rc3-generic/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
   executing: 'cd ./kernel; /usr/bin/make -k -j4 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.18.0-041800rc3-generic/build" SYSOUT="/lib/modules/4.18.0-041800rc3-generic/build"'...
   rm -f -r conftest
   make[1]: Entering directory '/usr/src/linux-headers-4.18.0-041800rc3-generic'
   make[1]: Leaving directory '/usr/src/linux-headers-4.18.0-041800rc3-generic'
-> Building kernel modules
   executing: 'cd ./kernel; /usr/bin/make -k -j4  NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.18.0-041800rc3-generic/build" SYSOUT="/lib/modules/4.18.0-041800rc3-generic/build"'...
     SYMLINK /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kernel.o
     SYMLINK /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nv-modeset-kernel.o
    CONFTEST: INIT_WORK
    CONFTEST: hash__remap_4k_pfn
    CONFTEST: remap_pfn_range
    CONFTEST: follow_pfn
    CONFTEST: vmap
    CONFTEST: set_pages_uc
    CONFTEST: set_memory_uc
    CONFTEST: set_memory_array_uc
    CONFTEST: change_page_attr
    CONFTEST: pci_get_class
    CONFTEST: pci_choose_state
    CONFTEST: vm_insert_page
    CONFTEST: acpi_device_id
    CONFTEST: acquire_console_sem
    CONFTEST: console_lock
    CONFTEST: kmem_cache_create
    CONFTEST: on_each_cpu
    CONFTEST: smp_call_function
    CONFTEST: acpi_evaluate_integer
    CONFTEST: ioremap_cache
    CONFTEST: ioremap_wc
    CONFTEST: acpi_walk_namespace
    CONFTEST: pci_domain_nr
    CONFTEST: pci_dma_mapping_error
    CONFTEST: sg_alloc_table
    CONFTEST: sg_init_table
    CONFTEST: pci_get_domain_bus_and_slot
    CONFTEST: get_num_physpages
    CONFTEST: efi_enabled
    CONFTEST: proc_create_data
    CONFTEST: pde_data
    CONFTEST: proc_remove
    CONFTEST: pm_vt_switch_required
    CONFTEST: xen_ioemu_inject_msi
    CONFTEST: phys_to_dma
    CONFTEST: get_dma_ops
    CONFTEST: write_cr4
    CONFTEST: of_get_property
    CONFTEST: of_find_node_by_phandle
    CONFTEST: of_node_to_nid
    CONFTEST: pnv_pci_get_npu_dev
    CONFTEST: for_each_online_node
    CONFTEST: node_end_pfn
    CONFTEST: pci_bus_address
    CONFTEST: pci_stop_and_remove_bus_device
    CONFTEST: pci_remove_bus_device
    CONFTEST: request_threaded_irq
    CONFTEST: register_cpu_notifier
    CONFTEST: cpuhp_setup_state
    CONFTEST: dma_map_resource
    CONFTEST: backlight_device_register
    CONFTEST: register_acpi_notifier
    CONFTEST: timer_setup
    CONFTEST: remap_page_range
    CONFTEST: address_space_init_once
    CONFTEST: kbasename
    CONFTEST: fatal_signal_pending
    CONFTEST: list_cut_position
    CONFTEST: vzalloc
    CONFTEST: wait_on_bit_lock_argument_count
    CONFTEST: bitmap_clear
    CONFTEST: usleep_range
    CONFTEST: radix_tree_empty
    CONFTEST: radix_tree_replace_slot
    CONFTEST: drm_dev_unref
    CONFTEST: drm_reinit_primary_mode_group
    CONFTEST: drm_atomic_set_mode_for_crtc
    CONFTEST: drm_atomic_clean_old_fb
    CONFTEST: get_user_pages_remote
    CONFTEST: drm_gem_object_lookup
    CONFTEST: drm_atomic_state_free
    CONFTEST: drm_driver_has_gem_prime_res_obj
    CONFTEST: drm_atomic_helper_disable_all
    CONFTEST: drm_atomic_helper_set_config
    CONFTEST: drm_atomic_helper_connector_dpms
    CONFTEST: is_export_symbol_gpl_of_node_to_nid
    CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
    CONFTEST: i2c_adapter
    CONFTEST: pm_message_t
    CONFTEST: irq_handler_t
    CONFTEST: acpi_device_ops
    CONFTEST: acpi_op_remove
    CONFTEST: outer_flush_all
    CONFTEST: proc_dir_entry
    CONFTEST: scatterlist
    CONFTEST: sg_table
    CONFTEST: file_operations
    CONFTEST: vm_operations_struct
    CONFTEST: atomic_long_type
    CONFTEST: pci_save_state
    CONFTEST: file_inode
    CONFTEST: task_struct
    CONFTEST: kuid_t
    CONFTEST: dma_ops
    CONFTEST: dma_map_ops
    CONFTEST: noncoherent_swiotlb_dma_ops
    CONFTEST: vm_fault_present
    CONFTEST: vm_fault_has_address
    CONFTEST: kernel_write
    CONFTEST: strnstr
    CONFTEST: iterate_dir
    CONFTEST: kstrtoull
    CONFTEST: backlight_properties_type
    CONFTEST: fault_flags
    CONFTEST: atomic64_type
    CONFTEST: backing_dev_info
    CONFTEST: mm_context_t
    CONFTEST: vm_ops_fault_removed_vma_arg
    CONFTEST: pnv_npu2_init_context
    CONFTEST: drm_bus_present
    CONFTEST: drm_bus_has_bus_type
    CONFTEST: drm_bus_has_get_irq
    CONFTEST: drm_bus_has_get_name
    CONFTEST: drm_driver_has_legacy_dev_list
    CONFTEST: drm_driver_has_set_busid
    CONFTEST: drm_crtc_state_has_connectors_changed
    CONFTEST: drm_init_function_args
    CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
    CONFTEST: drm_helper_mode_fill_fb_struct
    CONFTEST: drm_master_drop_has_from_release_arg
    CONFTEST: drm_driver_unload_has_int_return_type
    CONFTEST: kref_has_refcount_of_type_refcount_t
    CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
    CONFTEST: drm_crtc_helper_funcs_has_atomic_enable
    CONFTEST: drm_old_atomic_state_iterators_present
    CONFTEST: drm_mode_object_find_has_file_priv_arg
    CONFTEST: dom0_kernel_present
    CONFTEST: nvidia_vgpu_kvm_build
    CONFTEST: nvidia_grid_build
    CONFTEST: drm_available
    CONFTEST: drm_atomic_available
    CONFTEST: drm_atomic_modeset_nonblocking_commit_available
    CONFTEST: is_export_symbol_gpl_refcount_inc
    CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-instance.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gpu-numa.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-acpi.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-chrdev.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-cray.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-dma.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gvi.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pat.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-procfs.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-usermap.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-pci.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-registry.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-usermap.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-modeset-interface.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pci-table.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q-selftest.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-memdbg.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-ibmnpu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-report-err.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv_uvm_interface.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm_utils.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm_common.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm_linux.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/nvstatus.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/nvCpuUuid.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tools.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_global.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_isr.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_procfs.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_space.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mem.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_rm_mem.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_channel.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_lock.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_hal.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_tree.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_allocator.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_range.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_block.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_group.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_replayable_faults.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_non_replayable_faults.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_access_counters.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_events.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_module.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mmu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pte_batch.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tlb_batch.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_push.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pushbuffer.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_thread_context.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tracker.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler_ce.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler_host.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kepler_mmu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_maxwell.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_maxwell_host.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_ce.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_host.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_mmu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_host.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_mmu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_fault_buffer.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_volta_access_counter_buffer.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_policy.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_utils.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kvmalloc.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_sysmem.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_gpu.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_migrate.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_map_external.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_user_channel.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_hmm.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_heuristics.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_thrashing.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_prefetch.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_test_rng.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_tree_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_allocator_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mem_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_rm_mem_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_page_tree_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_tracker_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_push_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_channel_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_ce_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_lock_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_utils_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_pmm_sysmem_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_events_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_perf_module_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_mmu_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_va_block_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nvidia-modeset-linux.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-drv.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-utils.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-crtc.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-encoder.o
   In file included from ./include/drm/drmP.h:82:0,
                    from /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-priv.h:30,
                    from /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-drv.c:25:
   /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-drv.c:637:23: error: ‘DRM_CONTROL_ALLOW’ undeclared here (not in a function); did you mean ‘DRM_RENDER_ALLOW’?
                          DRM_CONTROL_ALLOW|DRM_UNLOCKED),
   ./include/drm/drm_ioctl.h:162:12: note: in definition of macro ‘DRM_IOCTL_DEF_DRV’
      .flags = _flags,     \
   scripts/Makefile.build:317: recipe for target '/tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-drv.o' failed
   make[2]: *** [/tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-drv.o] Error 1
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-connector.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-gem.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-fb.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-modeset.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-prime-fence.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-linux.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-helper.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nv-pci-table.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
     CC [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
   ld -r -o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-instance.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-acpi.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-chrdev.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-cray.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-dma.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gvi.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o /tmp/selfgz12433/NVIDIA-Linux-x86_
   64-390.67/kernel/nvidia/nv-pat.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-procfs.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-usermap.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-pci.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-registry.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-usermap.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pci-table.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/n
   vidia/nv-memdbg.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-report-err.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o
   ld -r -o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset/nvidia-modeset-linux.o
     LD [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia.o
     LD [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-uvm.o
     LD [M]  /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia-modeset.o
   make[2]: Target '__build' not remade because of errors.
   Makefile:1505: recipe for target '_module_/tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel' failed
   make[1]: *** [_module_/tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel] Error 2
   make[1]: Target 'modules' not remade because of errors.
   Makefile:79: recipe for target 'modules' failed
   make: *** [modules] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Building kernel modules". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j4  NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.18.0-041800rc3-generic/build" SYSOUT="/lib/modules/4.18.0-041800rc3-generic/build"` failed with the following output:
 CONFTEST: INIT_WORK
 CONFTEST: vmap
 CONFTEST: pde_data
 CONFTEST: write_cr4
 CONFTEST: kbasename
 CONFTEST: vzalloc
 CONFTEST: sg_table
 CONFTEST: kuid_t
 CONFTEST: dma_ops
 CONFTEST: strnstr
 CONFTEST: kstrtoull
   .flags = _flags,     \
ld -r -o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-frontend.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-instance.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gpu-numa.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-acpi.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-chrdev.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-cray.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-dma.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-gvi.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-i2c.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mempool.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-mmap.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-p2p.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pat.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-procfs.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-usermap.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vm.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-vtophys.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-mlock.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-pci.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-registry.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/os-usermap.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-pci-table.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-kthread-q-selftest.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-memdbg.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv-report-err.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz12433/NVIDIA-Linux-x86_64-390.67/kernel/nvidia/nvlink_linux.o
-> Checking to see whether the nvidia kernel module was successfully built
   executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.18.0-041800rc3-generic/build" SYSOUT="/lib/modules/4.18.0-041800rc3-generic/build"'...
     Building modules, stage 2.
     MODPOST 1 modules
   FATAL: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol '__put_devmap_managed_page'
   scripts/Makefile.modpost:92: recipe for target '__modpost' failed
   make[2]: *** [__modpost] Error 1
   make[2]: Target '_modpost' not remade because of errors.
   Makefile:1508: recipe for target 'modules' failed
   make[1]: *** [modules] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Checking to see whether the nvidia kernel module was successfully built". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j4 NV_KERNEL_MODULES="nvidia" NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/4.18.0-041800rc3-generic/build" SYSOUT="/lib/modules/4.18.0-041800rc3-generic/build"` failed with the following output:
  MODPOST 1 modules
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed.  Please see the file '/var/log/nvidia-installer.log' for details.  You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
I hope you guys can help me figure out what is causing this problem.
Thank you in advance!
Cheers
1st you would need that patch: http://mom.hlmjr.com/2018/06/11/nvidia-drivers-390-67-vs-kernel-4-17/
2nd, but with rc3 the symbol __put_devmap_managed_page was GPL’ed, so propritary modules are not allowed to use it. Now it’s up to nvidia to change that.
http://mom.hlmjr.com is down. Is there any place, where I can download this patch?
