I have a fresh install of Debian 12 VM
The driver fails to install
Any help is much appreciated
root@servilo:/home/nick# cat /var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Tue Feb 13 23:20:13 2024
installer version: 535.154.05
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Unable to load: nvidia-installer ncurses user interface
Using: nvidia-installer ncurses v6 user interface (widechar)
-> Detected 4 CPUs online; setting concurrency level to 4.
-> Installing NVIDIA driver version 535.154.05.
-> Performing CC sanity check with CC="/usr/bin/cc".
-> Performing CC check.
-> Kernel source path: '/lib/modules/6.1.0-18-amd64/source'
-> Kernel output path: '/lib/modules/6.1.0-18-amd64/build'
-> Performing Compiler check.
-> Performing Dom0 check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Performing vgpu_kvm check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.1.0-18-amd64/source" SYSOUT="/lib/modules/6.1.0-18-amd64/build" clean'...
rm -f -r conftest
make[1]: Entering directory '/usr/src/linux-headers-6.1.0-18-common'
make[2]: Entering directory '/usr/src/linux-headers-6.1.0-18-amd64'
make[2]: Leaving directory '/usr/src/linux-headers-6.1.0-18-amd64'
make[1]: Leaving directory '/usr/src/linux-headers-6.1.0-18-common'
-> Building kernel modules
executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.1.0-18-amd64/source" SYSOUT="/lib/modules/6.1.0-18-amd64/build" '...
SYMLINK /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-kernel.o
SYMLINK /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset/nv-modeset-kernel.o
CONFTEST: hash__remap_4k_pfn
CONFTEST: set_pages_uc
CONFTEST: list_is_first
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: set_pages_array_uc
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: ioremap_driver_hardened
CONFTEST: ioremap_driver_hardened_wc
CONFTEST: ioremap_cache_shared
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: pde_data
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: dma_attr_macros
CONFTEST: dma_map_page_attrs
CONFTEST: write_cr4
CONFTEST: of_find_node_by_phandle
CONFTEST: of_node_to_nid
CONFTEST: pnv_pci_get_npu_dev
CONFTEST: of_get_ibm_chip_id
CONFTEST: pci_bus_address
CONFTEST: pci_stop_and_remove_bus_device
CONFTEST: pci_rebar_get_possible_sizes
CONFTEST: wait_for_random_bytes
CONFTEST: register_cpu_notifier
CONFTEST: cpuhp_setup_state
CONFTEST: dma_map_resource
CONFTEST: get_backlight_device_by_name
CONFTEST: timer_setup
CONFTEST: pci_enable_msix_range
CONFTEST: kernel_read_has_pointer_pos_arg
CONFTEST: kernel_write_has_pointer_pos_arg
CONFTEST: dma_direct_map_resource
CONFTEST: tegra_get_platform
CONFTEST: tegra_bpmp_send_receive
CONFTEST: flush_cache_all
CONFTEST: vmf_insert_pfn
CONFTEST: jiffies_to_timespec
CONFTEST: ktime_get_raw_ts64
CONFTEST: ktime_get_real_ts64
CONFTEST: full_name_hash
CONFTEST: pci_enable_atomic_ops_to_root
CONFTEST: vga_tryget
CONFTEST: cc_platform_has
CONFTEST: seq_read_iter
CONFTEST: unsafe_follow_pfn
CONFTEST: drm_gem_object_get
CONFTEST: drm_gem_object_put_unlocked
CONFTEST: add_memory_driver_managed
CONFTEST: device_property_read_u64
CONFTEST: devm_of_platform_populate
CONFTEST: of_dma_configure
CONFTEST: of_property_count_elems_of_size
CONFTEST: of_property_read_variable_u8_array
CONFTEST: of_property_read_variable_u32_array
CONFTEST: i2c_new_client_device
CONFTEST: i2c_unregister_device
CONFTEST: of_get_named_gpio
CONFTEST: devm_gpio_request_one
CONFTEST: gpio_direction_input
CONFTEST: gpio_direction_output
CONFTEST: gpio_get_value
CONFTEST: gpio_set_value
CONFTEST: gpio_to_irq
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: icc_set_bw
CONFTEST: dma_buf_export_args
CONFTEST: dma_buf_ops_has_kmap
CONFTEST: dma_buf_ops_has_kmap_atomic
CONFTEST: dma_buf_ops_has_map
CONFTEST: dma_buf_ops_has_map_atomic
CONFTEST: dma_buf_has_dynamic_attachment
CONFTEST: dma_buf_attachment_has_peer2peer
CONFTEST: dma_set_mask_and_coherent
CONFTEST: devm_clk_bulk_get_all
CONFTEST: get_task_ioprio
CONFTEST: mdev_set_iommu_device
CONFTEST: offline_and_remove_memory
CONFTEST: crypto_tfm_ctx_aligned
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: radix_tree_empty
CONFTEST: radix_tree_replace_slot
CONFTEST: pnv_npu2_init_context
CONFTEST: cpumask_of_node
CONFTEST: ioasid_get
CONFTEST: mm_pasid_drop
CONFTEST: mmget_not_zero
CONFTEST: mmgrab
CONFTEST: iommu_sva_bind_device_has_drvdata_arg
CONFTEST: vm_fault_to_errno
CONFTEST: acpi_video_backlight_use_native
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: get_user_pages_remote
CONFTEST: pin_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: drm_atomic_state_ref_counting
CONFTEST: drm_driver_has_gem_prime_res_obj
CONFTEST: drm_atomic_helper_connector_dpms
CONFTEST: drm_connector_funcs_have_mode_in_name
CONFTEST: drm_connector_has_vrr_capable_property
CONFTEST: drm_framebuffer_get
CONFTEST: drm_dev_put
CONFTEST: drm_format_num_planes
CONFTEST: drm_connector_for_each_possible_encoder
CONFTEST: drm_rotation_available
CONFTEST: drm_vma_offset_exact_lookup_locked
CONFTEST: nvhost_dma_fence_unpack
CONFTEST: is_export_symbol_gpl_of_node_to_nid
CONFTEST: is_export_symbol_gpl_sme_active
CONFTEST: is_export_symbol_present_swiotlb_map_sg_attrs
CONFTEST: is_export_symbol_present_swiotlb_dma_ops
CONFTEST: is_export_symbol_present___close_fd
CONFTEST: is_export_symbol_present_close_fd
CONFTEST: is_export_symbol_present_get_unused_fd
CONFTEST: is_export_symbol_present_get_unused_fd_flags
CONFTEST: is_export_symbol_present_nvhost_get_default_device
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_byte_offset
CONFTEST: is_export_symbol_present_nvhost_syncpt_unit_interface_get_aperture
CONFTEST: is_export_symbol_present_tegra_dce_register_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_unregister_ipc_client
CONFTEST: is_export_symbol_present_tegra_dce_client_ipc_send_recv
CONFTEST: is_export_symbol_present_dram_clk_to_mc_clk
CONFTEST: is_export_symbol_present_get_dram_num_channels
CONFTEST: is_export_symbol_present_tegra_dram_types
CONFTEST: is_export_symbol_present_pxm_to_node
CONFTEST: is_export_symbol_present_screen_info
CONFTEST: is_export_symbol_gpl_screen_info
CONFTEST: is_export_symbol_present_i2c_bus_status
CONFTEST: is_export_symbol_present_tegra_fuse_control_read
CONFTEST: is_export_symbol_present_tegra_get_platform
CONFTEST: is_export_symbol_present_pci_find_host_bridge
CONFTEST: is_export_symbol_present_tsec_comms_send_cmd
CONFTEST: is_export_symbol_present_tsec_comms_set_init_cb
CONFTEST: is_export_symbol_present_tsec_comms_clear_init_cb
CONFTEST: is_export_symbol_present_tsec_comms_alloc_mem_from_gscco
CONFTEST: is_export_symbol_present_tsec_comms_free_gscco_mem
CONFTEST: is_export_symbol_present_memory_block_size_bytes
CONFTEST: crypto
CONFTEST: is_export_symbol_present_int_active_memcg
CONFTEST: is_export_symbol_present_migrate_vma_setup
CONFTEST: dma_ops
CONFTEST: swiotlb_dma_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: vm_fault_has_address
CONFTEST: vm_insert_pfn_prot
CONFTEST: vmf_insert_pfn_prot
CONFTEST: vm_ops_fault_removed_vma_arg
CONFTEST: kmem_cache_has_kobj_remove_work
CONFTEST: sysfs_slab_unlink
CONFTEST: proc_ops
CONFTEST: timespec64
CONFTEST: vmalloc_has_pgprot_t_arg
CONFTEST: mm_has_mmap_lock
CONFTEST: pci_channel_state
CONFTEST: pci_dev_has_ats_enabled
CONFTEST: remove_memory_has_nid_arg
CONFTEST: add_memory_driver_managed_has_mhp_flags_arg
CONFTEST: num_registered_fb
CONFTEST: pci_driver_has_driver_managed_dma
CONFTEST: vm_area_struct_has_const_vm_flags
CONFTEST: memory_failure_has_trapno_arg
CONFTEST: backing_dev_info
CONFTEST: mm_context_t
CONFTEST: mmu_notifier_ops_invalidate_range
CONFTEST: mmu_notifier_ops_arch_invalidate_secondary_tlbs
CONFTEST: migrate_vma_added_flags
CONFTEST: migrate_device_range
CONFTEST: handle_mm_fault_has_mm_arg
CONFTEST: handle_mm_fault_has_pt_regs_arg
CONFTEST: mempolicy_has_unified_nodes
CONFTEST: mempolicy_has_home_node
CONFTEST: mpol_preferred_many_present
CONFTEST: mmu_interval_notifier
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_device_list
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_driver_has_set_busid
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_function_args
CONFTEST: drm_helper_mode_fill_fb_struct
CONFTEST: drm_master_drop_has_from_release_arg
CONFTEST: drm_driver_unload_has_int_return_type
CONFTEST: drm_atomic_helper_crtc_destroy_state_has_crtc_arg
CONFTEST: drm_atomic_helper_plane_destroy_state_has_plane_arg
CONFTEST: drm_mode_object_find_has_file_priv_arg
CONFTEST: dma_buf_owner
CONFTEST: drm_connector_list_iter
CONFTEST: drm_atomic_helper_swap_state_has_stall_arg
CONFTEST: drm_driver_prime_flag_present
CONFTEST: drm_gem_object_has_resv
CONFTEST: drm_crtc_state_has_async_flip
CONFTEST: drm_crtc_state_has_pageflip_flags
CONFTEST: drm_crtc_state_has_vrr_enabled
CONFTEST: drm_format_modifiers_present
CONFTEST: drm_vma_node_is_allowed_has_tag_arg
CONFTEST: drm_vma_offset_node_has_readonly
CONFTEST: drm_display_mode_has_vrefresh
CONFTEST: drm_driver_master_set_has_int_return_type
CONFTEST: drm_driver_has_gem_free_object
CONFTEST: drm_prime_pages_to_sg_has_drm_device_arg
CONFTEST: drm_driver_has_gem_prime_callbacks
CONFTEST: drm_crtc_atomic_check_has_atomic_state_arg
CONFTEST: drm_gem_object_vmap_has_map_arg
CONFTEST: drm_plane_atomic_check_has_atomic_state_arg
CONFTEST: drm_device_has_pdev
CONFTEST: drm_crtc_state_has_no_vblank
CONFTEST: drm_mode_config_has_allow_fb_modifiers
CONFTEST: drm_has_hdr_output_metadata
CONFTEST: dma_resv_add_fence
CONFTEST: dma_resv_reserve_fences
CONFTEST: reservation_object_reserve_shared_has_num_fences_arg
CONFTEST: drm_connector_has_override_edid
CONFTEST: drm_master_has_leases
CONFTEST: drm_file_get_master
CONFTEST: drm_modeset_lock_all_end
CONFTEST: drm_connector_lookup
CONFTEST: drm_connector_put
CONFTEST: drm_driver_has_dumb_destroy
CONFTEST: drm_unlocked_ioctl_flag_present
CONFTEST: dom0_kernel_present
CONFTEST: nvidia_vgpu_kvm_build
CONFTEST: nvidia_grid_build
CONFTEST: nvidia_grid_csp_build
CONFTEST: pm_runtime_available
CONFTEST: pci_class_multimedia_hd_audio
CONFTEST: drm_available
CONFTEST: vfio_pci_core_available
CONFTEST: mdev_available
CONFTEST: cmd_uphy_display_port_init
CONFTEST: cmd_uphy_display_port_off
CONFTEST: memory_failure_mf_sw_simulated_defined
CONFTEST: drm_atomic_available
CONFTEST: is_export_symbol_gpl_refcount_inc
CONFTEST: is_export_symbol_gpl_refcount_dec_and_test
CONFTEST: drm_alpha_blending_available
CONFTEST: is_export_symbol_present_drm_gem_prime_fd_to_handle
CONFTEST: is_export_symbol_present_drm_gem_prime_handle_to_fd
CONFTEST: ib_peer_memory_symbols
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pci.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-dmabuf.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-nano-timer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-kthread-q.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-memdbg.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-ibmnpu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-report-err.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-rsync.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-msi.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-caps.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_aead.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_ecc.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hkdf.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_rand.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_shash.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_aead_aes_gcm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_sha.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hmac_sha.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hkdf_sha.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_ec.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_x509.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nvlink_caps.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/linux_nvswitch.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/procfs_nvswitch.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/i2c_nvswitch.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ats_sva.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_conf_computing.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_sec2_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell_sec2.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hopper_sec2.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/nvCpuUuid.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_tools.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_global.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu_isr.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_procfs.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_va_space.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_va_space_mm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu_semaphore.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_mem.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_rm_mem.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_channel.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_lock.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hal.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_range_tree.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_rb_tree.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_range_allocator.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_va_range.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_va_policy.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_va_block.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_range_group.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu_replayable_faults.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu_non_replayable_faults.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu_access_counters.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_events.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_module.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pte_batch.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_tlb_batch.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_push.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pushbuffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_thread_context.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_tracker.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell_host.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell_ce.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell_fault_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_maxwell_access_counter_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pascal.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pascal_ce.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pascal_host.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pascal_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pascal_fault_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_volta_ce.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_volta_host.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_volta_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_volta.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_volta_fault_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_volta_access_counter_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_turing.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_turing_access_counter_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_turing_fault_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_turing_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_turing_host.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ampere.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ampere_ce.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ampere_host.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ampere_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hopper.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hopper_fault_buffer.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hopper_ce.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hopper_host.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hopper_mmu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ada.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_policy.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_utils.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_kvmalloc.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pmm_sysmem.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pmm_gpu.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_migrate.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_populate_pageable.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_migrate_pageable.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_map_external.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_user_channel.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_hmm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_heuristics.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_thrashing.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_prefetch.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ats.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ats_ibm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ats_faults.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_test_rng.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_range_tree_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_range_allocator_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_gpu_semaphore_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_mem_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_rm_mem_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_page_tree_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_tracker_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_push_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_channel_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_ce_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_host_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_lock_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_utils_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_kvmalloc_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pmm_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_pmm_sysmem_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_events_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_perf_module_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_get_rm_ptes_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_fault_buffer_flush_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_peer_identity_mappings_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_va_block_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_range_group_tree_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_thread_context_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm/uvm_rb_tree_test.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset/nv-kthread-q.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-connector.o
/tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-crtc.c: In function '__nv_drm_plane_atomic_destroy_state':
/tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-crtc.c:695:5: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
695 | struct nv_drm_plane_state *nv_drm_plane_state =
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-fence.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-helper.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-gem-nvkms-memory.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-gem-user-memory.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-gem-dma-buf.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm/nvidia-drm-format.o
CC [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-peermem/nvidia-peermem.o
LD [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia.o
LD [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset.o
ld -r -o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pci.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-dmabuf.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-nano-timer.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-acpi.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-cray.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-dma.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-i2c.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-mmap.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-p2p.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pat.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-procfs.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-usermap.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-vm.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-vtophys.o /tmp/selfgz9533/NV
IDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-mlock.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-pci.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-registry.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-usermap.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pci-table.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-kthread-q.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-memdbg.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-report-err.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-rsync.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-msi.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-caps.o /tm
p/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-frontend.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_aead.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_ecc.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hkdf.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_rand.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_shash.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_aead_aes_gcm.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_sha.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hmac_sha.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hkdf_sha.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_ec.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_x509.o /tmp/selfgz9533/NVIDIA-
Linux-x86_64-535.154.05/kernel/nvidia/nvlink_linux.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nvlink_caps.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/linux_nvswitch.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/i2c_nvswitch.o
ld -r -o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset/nvidia-modeset-linux.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-modeset/nv-kthread-q.o
LD [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-drm.o
LD [M] /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia-peermem.o
MODPOST /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/Module.symvers
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol '__rcu_read_lock'
ERROR: modpost: GPL-incompatible module nvidia.ko uses GPL-only symbol '__rcu_read_unlock'
make[3]: *** [/usr/src/linux-headers-6.1.0-18-common/scripts/Makefile.modpost:126: /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/Module.symvers] Error 1
make[3]: Target '__modpost' not remade because of errors.
make[2]: *** [/usr/src/linux-headers-6.1.0-18-common/Makefile:1991: modpost] Error 2
make[2]: Target 'modules' not remade because of errors.
make[1]: *** [Makefile:250: __sub-make] Error 2
make[1]: Target 'modules' not remade because of errors.
make: *** [Makefile:82: modules] Error 2
-> Error.
ERROR: An error occurred while performing the step: "Building kernel modules". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.1.0-18-amd64/source" SYSOUT="/lib/modules/6.1.0-18-amd64/build" ` failed with the following output:
CONFTEST: pde_data
CONFTEST: write_cr4
CONFTEST: icc_get
CONFTEST: icc_put
CONFTEST: mmgrab
CONFTEST: crypto
CONFTEST: dma_ops
CONFTEST: proc_ops
ld -r -o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pci.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-dmabuf.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-nano-timer.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-acpi.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-cray.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-dma.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-i2c.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-mmap.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-p2p.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pat.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-procfs.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-usermap.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-vm.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-vtophys.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-mlock.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-pci.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-registry.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/os-usermap.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-pci-table.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-kthread-q.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-memdbg.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-ibmnpu.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-report-err.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-rsync.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-msi.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-caps.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv-frontend.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_aead.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_ecc.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hkdf.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_rand.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_shash.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_aead_aes_gcm.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_sha.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hmac_sha.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_hkdf_sha.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_ec.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/libspdm_x509.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nvlink_linux.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/nvlink_caps.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/linux_nvswitch.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/procfs_nvswitch.o /tmp/selfgz9533/NVIDIA-Linux-x86_64-535.154.05/kernel/nvidia/i2c_nvswitch.o
-> Checking to see whether the nvidia kernel module was successfully built
executing: 'cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.1.0-18-amd64/source" SYSOUT="/lib/modules/6.1.0-18-amd64/build" NV_KERNEL_MODULES="nvidia"'...
-> Error.
ERROR: An error occurred while performing the step: "Checking to see whether the nvidia kernel module was successfully built". See /var/log/nvidia-installer.log for details.
-> The command `cd ./kernel; /usr/bin/make -k -j4 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/6.1.0-18-amd64/source" SYSOUT="/lib/modules/6.1.0-18-amd64/build" NV_KERNEL_MODULES="nvidia"` failed with the following output:
ERROR: The nvidia kernel module was not created.
ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com.
